Zebra Printer Serial Number.
How can I find the serial number of a Zebra printer from remote using the IP address of the printer and accessing the firmware of the printer?
SOURCE: printer unable to obtain IP address
Reset the TCP/IP information. To do so, Turn off the printer power. With the cartridge door open, hold down both cancel and continue buttons and power the printer on. Hold the buttons until the lights cycle. The TCP/IP information should be cleared. Wait a few minutes.The printer should pick up a new IP address from the network, or should set a default IP. Press the Continue button to print a new test page, and you should see the new address.
Posted on Mar 26, 2008
SOURCE: Part needed Zebra PAX 170 print engine
wow i love it, i place a post in the "forum" and hours later im asked to join a Preimum service for a fee, that im expected to feel good that for the feel my search can be solved............ oh but wait in the same breath im asked if i solved my own problem to post what i did to solve it............. for FREE,
yeah guess i came to the wrong web site, thanks but no thanks
Posted on Aug 30, 2008
  • 53 Answers
SOURCE: Unable to reach the device for a statics IP address fro this Zebra TLP 2844-Z printer
I work for zebra. you should user zebra net bridge, its the current network tool and the best to use
Posted on Sep 03, 2008
  • 45 Answers
SOURCE: Trying to setup a Zebra TLP 2844-Z on serial port
Two possibilities are the port configuration and the type of serial cable.
The printer has a feature that will try to match itself to the PC's configuration. Press and hold the feed button until the green status led flashes three times. While the led flashes send a ZPL format to the printer (hopefully you can do this through Design Pro by trying to adjust the printer or print labels, but the labels will not print). When the printer and PC are synchonized, the led changes to solid green.
If you can synchonize but still can't print, the problem might be the serial cable; not all serial cables will work. You should use a full null model cable (all pins connected except 1 and 8).
Posted on Sep 20, 2008
SOURCE: where is the serial number on canon pixma mx310?
The serial number is located inside the maching, behind the tape attached to the cartridge carrier. When the cartridges are all the way to the left side (position for changing cartridges), the serial number is visible at the center-right position. Open the maching as if you were going to change cartridges.
Posted on Mar 11, 2009
My Zebra 105Se printer keeps printing blank labels
There are several reasons why this could be happening. If the computer accessing the printer changed then I assume the new computer was recently set up with software to send print information to the printer. I would start with simple calibration and move from there. Zebra Technologies 105SL Printer Calibrating the Printer With Video
Jun 04, 2014 | Zebra 105Se Thermal Printer
Zebra S600 - Printer pauses after each printed numbered label, if I don't number them it works fine?
It sounds like your labelling software is re-sending the entire print job each time. Do some research with your software and see if you can change the defaults so that everything BUT the serial number is stored inside the printer, and only the new serial number is sent.
It's difficult to be more specific because every software package is different...
Feb 10, 2012 | Zebra Stripe S600 Thermal Label Printer
What is the defult ip address for the zebra tlp2844?
When received or when a reset is performed, the default IP address is: The best way to confirm this is to force the printing of a configuration label. Look at the configuration label that is printed. That will contain the "current" IP assigned to the printer. You can download the manuals for this from the Zebra web site using the model number to get to the printer specific page. Choose the download tab.
May 25, 2010 | Zebra TLP 2844-Z Thermal Label Printer
How do I change the IP address on my zebra zm400. The one that is in there now is incorrect but it is set permanently. How do I release the permanent status and then change the IP to what it should be?...
Press on setup button
Press on the - button until you see protocol
Press on select and choose permanent and save
Press on the + button until see the IP Address
Press on select and use the + button to change numbers and Press the - button to move to the next number.
Press selects to save restart the printer by switching the printer on and off.
Test a print job to the Printer.
Jan 22, 2010 | Zebra 203DPI Printer
Where is the serial number on an HP Officejet J6480 All-in-One printer
Usually the serial number can be found either in the back or in the bottom of the printer.
If your printer is working you can print a self diagnostic page which would have the serial number.
To print the Self-Test Diagnostic Page
• Device control panel: Press Setup, select Print Report, select Self-Test Report,
and then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print a Test Page.
Sep 09, 2009 | Office Equipment & Supplies
Zebra Z4m w/print server II has Netware enable, How do I turn it
The print server has a web access if you know the IP address. You may need to have a Username (root) and password to gain access to what you wish to change.
Apr 02, 2009 | Zebra Z4Mplus Label Printer
Zebra QL 420+ wireless printer works only without cipher/TKIP
With Label Vista
  • Go to Printer Tab
  • Define the com Port settings (use serial or usb)
  • Go to Printer settings
in network tab :
  • Put your network configuration ( IP address or DHCP,submask, gateway; ESSID, port number .....)
In 802.1X WPA
  • Select WPA WPA2
  • Authentification PSK
  • Put the username and password in EAP section
Mar 16, 2009 | Zebra QL 420 Plus Thermal Label Printer
I have a brother printer, Model Number HL-2700cn, serial no u60767M4S142278. I just bought a lap top and wireless broadband router. In order to connect the printer to my wireless lap top I need the IP...
The Automatic Private IP Addressing (APIPA) protocol
automatically assigns an IP address from the range: to If the APIPA protocol is
disabled, the default IP address of a Brother print server is To change it, use the printer control panel (if
applicable), the BRAdmin Professional, Web BRAdmin software
or let your DHCP server allocate an IP address to the printer.
2 Refer to chapter 10 of this User’s Guide to learn how to
configure the IP address on your printer.
3 The default password for Brother print servers is access.
4 Windows® 2000/XP users can print using TCP/IP using the
standard Network Printing software and IPP protocol software
built into any Windows® 2000/XP installation.if you need manual just email me at or
Mar 27, 2008 | Computers & Internet
2,161 people viewed this question
