Question about AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800)
PC Start up problems
Following a major crash, HDD wipe and XP re-install I now have a pop up window on start up telling me to insert the Blueyonder (ISP provider) installation disc. I don't need this but cannot permanantly get rid of the message. I can close it down but it reappears on start up every time. I've run the registry cleaner with my Bitdefender Security suite and been all through my start up menu's but nothing works. Any ideas?
Sy
  • Canary94 Aug 28, 2008
    no option to untick Blueyonder in msconfig so still no solution!
    President:
  • 2,961 Answers
Click start, then in start search type run, then click on run in the list.
Type msconfig then enter, choose start up tab and untick blueyonder, then apply then restart pc
Posted on Aug 28, 2008
I need to re install the XP but do not reconigze the HDD
hey
u can do it but if u r seeing blue screen then its some problem in ur hardware like check ur ram
secondly u cn install ur windows xp
1st take out ur hdd from ur laptop
2nd put ur hdd to someanother laptop then insert the windows xp cd
let all the files get copied and all the formating do it
LASTLY when the system restarts THEN take out ur HDD and insert back to ur laptop from where u had took out then start ur laptop let it run all the procedure then windows will configure ur specification of ur laptop then install al ur drivers and enjoy it
if any whre u get stuck inform me let me know where do u got stuck
Jun 14, 2011 | Gateway CX2724 Notebook
HP Pavilion laptop freezes daily and i force manual shutdown
It sound's like there could be a compatibility problem, maybe corrupt file's, or missing start up file's, have you tried doing a window's update, or doing a disc check on the hard drive, go to my computer right click the drive then go to propertie's, click on tool's then click check now for drive error's. if that do'es not work you may need to reformat back to the original xp os.
Apr 16, 2009 | HP Pavilion dv1000 Notebook
Install Win XP SP 2
Yes you can, Do I recomend it, no, Why?
Windows easily uses up to 756MB of RAM to run the O/S alone but can run at a minimum of 512MB.
I have personally seen it run on as low as a 900Mhz processor, 256MB of RAM and on a 10 gig hard drive.
If you decide to install windows XP on the specs you describe above please note the following.
1. System will be very slow and have lengthy start up times.
2. Applications may crash or take a long time to open.
3. With all the updates for WinXP you will easily use 8 gigs for installing XP and its updates. Not to mention whatever software you will use/install.
4. On a system with those low specs, you probably have a low end video card whcih may result in: A. chooppy windows, screen freezing, system crashes and lock ups, low video graphics all around.
I would probably go with windows 2000 instead. If your bent on having XP, at least upgrade the RAM to as much as possible. Then install windows and only install the programs you really need, remove any other junk.
Hope this is of some help to you, good luck
Feb 17, 2009 | Dell Inspiron 4000 Notebook
Do i need to change my harddisk?
It sounds like UBUNTU formated your hard drive where xp does not reconized the drive. When you go into BIOS setting, do you see your hard listed? If so, you should be able to put a clean install of XP to the drive. When you start the install, you must select REFORMAT drive and install XP. If this still fails, you may need to fdisk your drive first using DOS command and reinstall XP. Let us know if you incounter any more problems after doing this. Good Luck.
Feb 08, 2009 | HP Pavilion dv6000z Notebook
Sata problem
WHEN BOOTING TO LOAD WINDOWS XP START AFRESH BY FORMATING YOUR HDD FIRST AND WHEN U DONE BOOT YOUR SYSTEM UP FROM YOUR CD ROM THE DRIVERS WILL GET DETECTED AUTOMATIC AND THAN START YOUR INSTALLION.
Feb 06, 2009 | PC Chips M955G Motherboard
Can't reboot dell 4100 dimension desktop
First put the hdd installation cd into the cd drive and try to boot. This should install the hdd driver as well as start formatting the new hdd. After the drive is formatted take out the hdd cd & insert the Windows installation cd into the drive. Boot. Windows should start installing on your new drive. After Windows is installed check the Dell support site for updated drivers for your system. Install drivers as needed. Any other software you had on your old drive will need to be reinstalled to the new drive. Hope this helps & please rate my answer. Thanks.
Dec 27, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Crashed computer. \WINDOWS\system32\config\SYSTEM is corrupt or missing. We dont have the original setup cd-rom. All we have is a windows xp disk for a different computer. Is there anyway this can work? I...
you have a registry problem! that could be result of a hardware problem.. there is a good article of things you can try, it's usually suggested for you use the same xp cd that you use to install the os, otherwise is risky business using a different cd... you may want to find a cd that has the same service pack you have before starting... if you can't get that cd, read my suggestiong below
http://www.help2go.com/Tutorials/Windows/C:%5Cwindows%5Csystem32%5Cconfig%5Csystem_missing_or_corrupt.html
I strongly suggest the following:
first of all if possible, take your hard drive out, using and enclosure or another machine try to back up your data so it things go wrong or it's just taking too much time, you can just wipe out the hard drive and start fresh with a clean install, you may find it this to be the easiest and fastest way... back up your data regardless then start troubleshooting.
Sep 18, 2008 | Compaq Presario 5000 PC Desktop
I m not able to install win xp sp2 on my compaq notebook
windows xp cant detect ur hdd bcoz its SATA hdd.
Solutions:
1. Install vista instead of XP
2. You need to disable this SATA feature in BIOS to install OS.
SATA disable steps.
1. Restart the computer and start tapping F10 key.
2. Choose System Configuration tab.
3. Disable SATA native support.
4. Save and Exit the BIOS by pressing F10 key
Aug 21, 2008 | HP Compaq Presario V5000Z Notebook
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Reformat HP pc hard drive.
to perform a clean install of your XP. follow this steps.
1.    Start your computer from the Windows XP CD-ROM. To do this, insert the Windows XP CD-ROM into your CD drive or DVD drive, and then restart your computer.
2.    When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD-ROM.
3.    At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4.    When you see the End-User License Agreement, press F8.
5.    Follow the instructions on the screen to select and format a partition where you want to install Windows XP. This would be your c:\ drive
note: when formating the drive do not choose the quick format option.
6.    Follow the instructions on the screen to complete Windows XP Setup.
Nov 01, 2007 | Computers & Internet
AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800) Logo
42 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
