Question about Lands Phones
Samsung DS 24D Phone System
Our voicemail is picking up only after 2 rings we would like it to be at least 4 or more. Can you help?
  • 24 Answers
You need to lengthen the "next port" Timing in MMC 601. 15-17 second should do it. I don't want to go into program access here as anyone could reprogram your system and possibly mess it up.. If you wanted to call me I could walk you thru it in under a minute. 909-496-5887
Posted on Dec 27, 2008
How do I reset the time on the display ?
1. Press the transfer button and enter 200
2. Enter password ** 1234** default.
3. Enter 1 to enable
4. Press SPK button and enter 505
5. Display will read
OLD: 1040703: 1125
For Monday April 7. time 1:00p.m
enter the following
104070313:00 and then press the Transfer button.
6. Display will return to normal..
Jun 12, 2014 | Samsung Ds-24d 24 Button Display Phone For...
My Vtech phone answering machine no longer records incoming messages on its base. Help
From the sound of it it I think its either: your mailbox is full or the feature has been turn off accidentally.
Vtech's support recommend the following (I've removed things like 'make sure its plugged in' and 'is your answering system is turned on' etc..)
1 Some answering systems have an announce only option, which plays your greeting but won't record messages. Make sure your system is set to record messages.
2 Your answering system's message capacity may be full. You must erase old messages to make room for new ones.
3 If you have voicemail service in addition to your answering system, your caller's message may be going into voicemail before your answering system picks up the call. Program your voicemail to pick up at least 2 rings after your answering system is set to answer the call.
May 05, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
Turn off voicemail 6408D+
Turning off voicemail is usually done by the voicemail administrator, they can reset passwords and add or delete a mailbox on an extension. The number of rings before going to voicemail is usually system wide, and that program is changed by whoever programs your phone system.
Apr 21, 2014 | Avaya Definity PBX Phone 6424D+ Gray
We have a Uniden DECT 6.0 series phone and voicemail service through AT&T. For some reason, the base answering system has been picking up calls, seemingly at random. Sometimes the base picks up, s
Hi Jessica,
I would suggest contacting Uniden rather than AT&T. I included their contact information below as well as 3 issues that may be going on here.
Uniden Technical Support
M-F 8:30am-11:45pm CST & 2:30pm-4:45pm CST
Ask a Question:
1. Are you getting messages? If not, the voicemail may have set to "Announce Only." This means the Answering system will answer the call, but will not allow callers to leave a message. If so, there may be an LED "A" lit up on your base. You can change this setting in the Answ setup --> record time.
2. Does it occur after a particular number of rings? You can set the voicemail to answer after 2, 4, or 6 rings. This may be the problem.
3. Does the phone ring at all? It is possible the phone is in Silent Mode. You can set silent mode to last anywhere between 1-9 hours or keep it on all the time. If it is set to a particular number of hours, the phone will exit silent mode automatically. If not, you need to hold # to deactivate it. I don't think you can set silent mode to turn on automatically on a schedule, but this is something you could ask Uniden about.
I hope that helps. Good Luck!
Jan 08, 2014 | Uniden D16602 Twin Cordless Phone
Samsung ds 24d - how to set the hold time before it rings again
hi, this is a feature which is in engineering programming, if you have access to this the MMC required is 501 the codes are 'Sys Hold' and 'Trans Hold', If you don't have access, you will need to contact your Telecoms maintainer. Alternatively you could use the exclusive hold, check out this site for more information -
Aug 02, 2011 | Samsung Prostar DCS-24B-LCD Corded Phone
Our DECT2015 phone only rings 4 times and then stops.How cane I adjust the ringing time of our phone? Thanks Peter
Do you have voicemail or an answering machine? This is usually a sign that another device (fax, answering machine or voicemail service) is set to answer the call after 4 rings. You will need to lengthen to number of rings before the service/device in question picks up. (The method to reset this will depend on the service/device that is picking up.) Another possibility is a call forwarding service that is enabled at 4 rings.
I hope this helps. Please write back with details on the device that could be picking up for details on setting the number of rings. If you have voicemail or call forwarding, check with your telephone service provider to lengthen the number of rings before the service kicks in. (There are too many for me to know all of the providers instructions.)
Apr 16, 2011 | Uniden Lands Phones
this is an option to ring or not to ring while on a call. Your local phone man should be able to help you with that basic programming
Dec 09, 2008 | Lands Phones
It sounds like you are using a voicemail service from a provider, meaning you did not buy the voicemail system with the phone system. If you confirm, I can tell you how to fix this.
Apr 29, 2008 | NorStar M7310 Corded Phone
Lands Phones Logo
311 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
