Question about Car Audio & Video
In buying an amp, what does 2way and 4 way mean?
    Novelist:
  • 100 Answers
I am not quite sure if I understand your question but by 2 way and 4 way, I'm assuming that you mean 2 channel and 4 channel. In this case the number of channels means the number of speakers you can hook up to that particular amp. Also, if you meant 2 way and 4 way speakers, then it is the number of "speakers" in the speaker system. Meaning that with one speaker you could have a few tweeters attached to it. I hope I could help.
-Andrew Hawkins
Posted on Aug 29, 2008
2way come on both work cant talk to each other both on same chan. & sub chan.
It can be transmitter of one device doesn't work. There are special testers...
Nov 12, 2013 | Cobra MicroTalk FRS 220 (14 Channels)...
When armed, alarm will chirp 10 times every 1-2 minutes
Wrong section
Look them over & repost
Your in motor vehicles
Jul 23, 2013 | 3203 2way Security System
Which speakers (Front/Rear) to buy that match Kenwood KAC-M846 4/3/2 Channel Amplifier.
I don,t no where you are reading thease articles from,I installed car audio equipment for over 40 years, Untill i retired a couple of months ago, Who ever is writeing those sort of articles does not have the slightest clue what they are talking about, It is the opposite way around, It is allway better for yor (Speakers) To handle more power then what your amp puts out, Then you will not blow the spaekers, It is best to get speakers at least 20 watts more then what your amps maximuin (RMS) Watts are, Hope this helps you out, (PS) 50 watts (RMS) Is what most people go for, It is in no means (Under) Powered.
Nov 05, 2012 | Kenwood Kac-m846 4/3/2 Channel Amplifier...
My hp proliant dl380 g7 server shows non disk error
Enter RBSU create Raid & Select Direct Attached Storage option in boot controller,
May 17, 2012 | HEWLETT-PACKARD HP ProLiant DL380 G7 Entry...
Non disk error
enter into bios & select boot controller order Smart Array card
We need 16amps 3pin 2way sockets. please help me from where we can procure (my mob: 09989588208
It depends on which country you are in.
It also depends on what you mean by a socket.
I'm in Australia and a normal power outlet can handle up to 10 amps.
If you put multiple appliances on one outlet and exceed 10 amps in total then you will likely blow a fuse.
If you are trying to connect an appliance that requires more than 10 amps on its own like an air conditioner then you will need to have a qualified electrician install a dedicated 15 amp circuit for you.
A 15amp wall socked (in Australia) has an over sized earth pin so that you can not connect a 15 amp appliance to a 10 amp circuit.
If you are trying to do something else then please post more information about your problem.
Jul 11, 2009 | 10 10 Computer 15 ft. Token Ring Cable...
2way remote for Python 872 not working
Make sure that the responder is set for your car. this responder can work for multiple cars...The owners manual tells you how to check.
Dec 29, 2008 | 872 Responder LE Security Remote Start
Turn signal flasher replacement
It is probably tucked up high and clipped out of the way of other wires.
Look for a silver fuse around the area of where you kneecap rides, behind the panel.
Try locating the 4-way (emergency) flasher by its sounds, since it will continue to work if your 2way is out, then try to find the other one --- I had a hard time finding my 2way and never did see the 4-way (I just heard it).
You may have to stand on your head but you'll find it.
Dec 04, 2008 | 1999 Buick Riviera
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
