Question about Whirlpool Dryers
I have a coin op dryer modle cem2760kq0 i put im a new timer in but it dose not stop runing?
  • 550 Answers
Mechanical coin op timers come without the shut off cam installed
there are slots around the edge corresponding to different times, that take a pin cam. the pin cam is in the box for the installer to insert to the owners specification, between 24 and 60 minutes in 6 minute intervals usually, hope you retained the packaging, or the old timer which should have its cam pin still in it
electronic coin op timers have to be programmed
Posted on Aug 28, 2008
GE commercial coin op dryer only runs when start button is depressed. The second you let off the buton the dryer stops.
hows the timer unit on doing when you push on it the timer is suppose to start..
Apr 15, 2011 | GE Dryers
My Roper Dryer stopped working , what might I check to see what the problem is.
first make sure you have 220 going to the dryer.next put the timer on time cycle.next put your ear up to the timer and see if you hear the timer moter runing.if you do than you have a bad thermal switch.you will nead to remove the back panal and the power cord cover.on the lower left you will see a white plastic switch with two blue wires going to it.this is the thwermal switch,if you use a meter and this switch is open than you nead to replace it
Nov 12, 2009 | Roper REX4634KQ Electric Dryer
Coin-operated dryer won't turn off at end of cycle.
A dryer timer is a real simple device. Take the whole thing out and give it a good inspection. A little wd 40 can do wonders. A bad coin in the works can jam it on. Put a coin thru the works, watch the action. The timer motor can fail or get stuck, spray and test.
Apr 22, 2009 | Maytag PYE2300AY Electric Dryer
Coin-op dryer: changing the length of the cycle
that is correct, there a re multiple "cams"/discs that will increase/decrease times, they should be inside the lock box atop the machine, they come with the unit when delivered and that s the likely storage spot for them
Mar 25, 2009 | Whirlpool ET8CHEXSQ Dryer
I just bought a house that included in the sale a Maytag Coin-op Washer and Dryer. The coin box on each contains a key. How do I disable the need for putting coins in the washer and dryer so that I can...
  1. purchase a coin insert and blank the slot that coins fit in, then the slide will slid in without coins, just acting like a button, if you examine the slide you wil notice that there are plastic inserts in unused coin slots, any maytag commercial dealer has them.
  2. replace coin slide with 'free operation' converter, which is just a button plate that pushes the striker on the timer switch
  3. take top cover off and just push the striker on the timer, (this is NOT) a recommended option, 220v is enough to spoil you whole day)
Oct 24, 2008 | Maytag Washing Machines
Ge Commercial Coin-Op Dryer.
When you replaced the motor, did you replace the relay? It sounds like you have done everything reasonable. I would try bypassing the coin operation part and see if that changes anything. Go back to the motor relay. It may be incorrect application. the part guys only know what the computer tells them. it may need a different one. I am assuming that when the unit shuts off you checked for power from the timer to the next place, according to the diagram.
Mar 13, 2008 | Dryers
How to access rear of dryer
Need to know brand and model number.
Nov 19, 2007 | Dryers
Whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Sep 06, 2007 | Washing Machines
Open Questions:
Dryers Logo
219 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
