Whirlpool Model ET18NK
Water leaks out onto floor - today, enough to soak two kitchen towels.A couple of days ago I removed the two vegetable crispers and found the bottom well full of water. I cleaned it all out and it is still dry. The tray that sits on top of the condenser unit is bone dry. I can't figure out where the water is coming from.
SOURCE: frigidaire refrigerator with ice maker leaks water
It sounds like your ice maker is leaking.
If you are able, try opening up the ice maker for a visual inspection.
just remember to unplug first.
Apparently there is a leak somewhere.
Sometimes ice makers will over flow if the float gets stuck or a connection has come loose.
If you cannot work on it yourself, then I suggest looking up a service technician on the Fixya website.
SOURCE: outside of fridge condensation; hissing boiling noise
under the compressor there will be rubber bushes which would have got damaged so change the rubber bush and ur problem may get solved
SOURCE: water is collecting in bottom
check the drain off the coil inside the fridge you can usually find it by looking at the back of the fridge and locating the hose running down to a tray either on top of the compressor or its own receptacle it will probably be blocked,air pressure back up this line usually removes the offending object and allows it to drain again
SOURCE: Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
DITTO!!!???
water builds under crispers whirlpool refrigerator et18nk
