Question about Konica Minolta Maxxum 7D / Dynax 7D Digital Camera
CAMERA SHUTS DOWN
I will be taking pictures and it just Shuts down will not turn off I have to take the battery out to get it to shut off ... and the screen starts flashing squiggly lines.. I have had the camer for 4 years and it has just now started this....
  • acimdreamer Aug 31, 2008
    Mine works fine with no card in it, but turns on briefly with the card inserted, and then shuts down. An electronics repair service found two bent pins in the card slot, straightened them, but the problem persists.
    Novelist:
  • 208 Answers
AFTER FOUR YEARS OF SERVICE, YOUR CAMERA MIGHT BE IN NEED OF A REPAIR VISIT TO CLEAR THESE PROBLEMS BEFORE YOU HAVE A COMPLETE FAILURE. I HAVE ENCLOSED A COUPLE OF SITES FOR YOUR INFORMATION AND BOTH GIVE FREE ADVICE AND ESTIMATES ON REPAIRS. PROBABLY YOUR BEST BET FORM YOUR POST. GOOD LUCK!
www.precisionCamera.com
www.xtra-range.com/camera.repair/Minolta2.htm
BOTH ARE HOTLINKS SO JUST CLICK ON THE SITE. IF YOU NEED MORE HELP, REPLY TO: ARCLIGHT1217. THANKS!
WHILE I DON'T ENDORSE ANY WEBSITE, I PROVIDE THEM FOR YOUR INFORMATION.
Posted on Nov 18, 2008
Camera shuts down when try to take picture
You can try using NIMh batteries instead of using of using the conventional. Most other cameras with similar problems have turned to function normally by using the above mentioned cameras.
Dec 15, 2011 | Sony Cyber-Shot DSC-F707 Digital Camera
Camera shuts off immediately after turning on.
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
Mar 06, 2010 | Kodak EasyShare V1073 Digital Camera
Olympus 7010 shuts down in picture mode - not a battery problem
I will tell you how I did it for the same price you were going to charge me for a solution. To ask how I did it once I found a solution without a fee goes against your business model.
Dec 28, 2009 | Olympus Stylus 7010 Digital Camera
Easy Share V1003 Turns on, then shuts down.
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Aug 23, 2009 | Kodak EasyShare V1003 Digital Camera
Camera sony s930 shuts down after taking 2 or 3 pictures
when you purchased the battery minimum charging is 48 hours.please charge fully battery and then use it.I hope your problem will be solved.sometimes we are not charged the full battery and then battery life is also effects.
Aug 22, 2009 | Cameras
Lens error M425-12 (7f80) appears/ camera shuts down
yea.. i also got sand in my camera and i have thje same problem... there is no help anywhere on the internet for us :(
Feb 18, 2008 | HP Photosmart M447 Digital Camera
Mustek DV-3500 DV Digital Camcorder /keeps turning off
Be sure the batteries are not the rechargeable types.  I had this problem when I first got my camera about 4 years ago.  Also, try adjusting the quality settings for the functions.  For example, set the photo function at normal rather than fine.
Dec 14, 2006 | Mustek DV-3500 DV Digital Camcorder
Help me n my digital camera !
you're using the wrong type batteries
Jun 07, 2006 | Fuji FinePix A400 Digital Camera
Coolpix 8800 shuts down
Make sure to use good NiMH batteries. Another possiblity is a problem with the card. Borrow a card and see if it has any effect. check to see that the pins in the card slot are all aligned, none out of place. check that the card door and the battery door close firmly, with some pressure. The camera can shut down when it has a problem detecting that the doors are closed. When it does turn on, play with the zoom without taking pictures, zoom in and out, if during zoom the camera shuts down then you might have a lens problem, something is malfunctioning in the lens mechanism and the camera shuts down to prevent damage. Good luck
May 19, 2006 | Nikon Coolpix 8800 Digital Camera
Konica Minolta Maxxum 7D / Dynax 7D Digital Camera Logo
116 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
