This is a problem with aspect ratio. You need to find the correct combination of settings between your Comcast menu settings and the television menu settings. I personally have Directv, but there should be something of the same effect in the Comcast menus. On the remote control that came with your cable box, press the menu button and navigate to the settings, and from there display or picture. There should be a setting relating to the aspect ratio, and the same applies for the built-in TV menus using your Visio remote. A typical widescreen LCD has a ratio of 16:9 or 16:10. I hope this helps in some way!
You might look for a format button on your remote. This will cycle through the different image formats available for that channel. Also you might try talking to Comcast to see if their remotes have this feature.
Which menu? The menu on the Vizio or Comcast? The Comcast HD box should have an option for you to choose output resolution, choose something like 720p or 1080i. Your Vizio TV (and I think mine does also, but I'm not watching TV of course) may have a Zoom feature; zoom back out if that's the case. Some TVs also have a feature to change the ratio, choose 16:9. Somewhere along this line should be your solution.
With everyone's help, the problem is finally fixed. Thank you very much. The picture is perfect at last. I'm so happy!
