Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Renewing the cutting line
How do you put the cutting line in the trimmer?
  • 3 more comments
  • geekay63 Aug 28, 2008
    how do you spool replacement nylon onto spool of trimmer
  • Anonymous Aug 29, 2008
    re-spooling weed eater rte 115c
  • rgrabon Sep 01, 2008
    the string keeps retreating into the spool while i am using it. help. please. its annoying.
  • Anonymous Sep 08, 2008
    i can not get the head off to replace the cutting line
  • Anonymous Sep 24, 2008
    respool line
I need to get thr instructions on how to put the string on my Prolan Pro-link 31cc gas String trimmer
Posted on Sep 26, 2008
Bull
Posted on Sep 15, 2008
This product is driving me nuts - if someone can't help then its going into the bin
Posted on Aug 29, 2008
Echo SRM225 line trimmer continually feeds line
If the line feeds with out bumping it nay be the line gas been put on the wrong way
Apr 30, 2017 | Echo Garden
How do you refill the string on the homelite electric, straigh shaft, 13 in Trimmer?
Is the sting the cutting line at the bottom of the trimmer? If it is pull the spool out. At the bottom of the spool there is an arrow pointing in the direction that the line should be wound. When you first put in the line be sure to place the cutting line in the grove (V shape) and then when you put enough line around the spool. Thread the end of the line thru the hole on the side of the spool. Slide the spool over the shaft of the trimmer and it will click in. When the line is short just tap the spool lightly on the grass and it will feed out more line.
Good Luck.
Jan 06, 2010 | Homelite Garden
Try to replace fuel line craftman weedwacker 32cc/1.9c.u -trimmer-hose all rotten cant figure how to replace
You will need to get some TYGON fuel line. Match it up to the size of each fuel line, some of these trimmer use two different size lines, and remember which size went on which connection. You will want about a foot of each. Cut one end of each line at a 60 degree angle. With a pair of needle nose pliers, feed the angled end of the fuel line into the hole going into the tank and feed it into the tank untill you can see at the tank fill. You cut the angled end off and put your filter on the line. Pull it back until the filter lays at the bottom of the tank. Hook this line up to the supply side of carburetor. Take the other line and put it in the tank about 1" or 2"
then cut it off to fit on the carburetor. HTH
Good Day.
Nov 10, 2009 | Craftsman 25cc Gas Line Trimmer
Replacement of Cutting Line! How to do? anneodello
There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Oct 21, 2009 | Black & Decker Garden
Installing new line on my string grass trimmer
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Load new line onto the mighty vt26 17" curved trimmer
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Adding trimmer line to spool on husqvarna trimmer-two strings
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 19, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Jim
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
HOW DO I REPLACE THE FUEL LINES ON MY 32CC CARFTMAN LINE TRIMMER? THERE ARE TWO LINES FROM THE TANK, TWO TO THE PRIMER BULB, AND TWO TO THE CARB.
Take them off and put new ones on. Cut the old ones if they are hardened. Make sure you change the fuel filter too.
Jun 11, 2009 | Craftsman 25cc Gas Line Trimmer
How do load a dual line trimmer for a husqvara 223L
Cut two separate pieces of string, about 7 ft. each. Stick the end of the lie in the hole on the inside of spool. Wind clockwise onto spool, putting the line that is closest to the ground on first. Once you have winded this piece on, lock the last 4 inches of line through the slits on spool. Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece. Put the spool on the trimmer, feeding the end of lines through either hole on trimmer. Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 10, 2009 | Husqvarna 28cc Gas Line Trimmer
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
595 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
