Question about Altec Lansing AVS 500 Computer Speakers
Speaker popping when computer is on or off.
Altec Lansing AVS 500 Speakers
Realtec high def audio
I'm getting an annoying popping sound whether the compter is on or off. This is constant fairly non stop. If I unplug it then plug it in later it stays off for awhile then starts again.
I saw somewhere else that it might be the internal amp?
Is there anyway to salvage these speakers or are they pretty much gone. They have worked fine up until recently. All of the other speakers work fine its just the subwoofer.
  • Anonymous Nov 12, 2008
    I have the same issue with my set. It is a great set of speakers but recently the subwoofer started making a constant thump thump noise. It will do it even if i press the power button on the speaker to turn it off. Please help. I don't really want to invest in another set of computer speakers and throw these out.
I have the same issue. Speakers were working fine then the sub-woofer just starts err...pulsing/popping/ The speaker cone is actually moving and it's like it's in a kind of loop. Powering off kills it for a while, but then it comes back making the whole speaker system unusable.
Mic is on, but no boost.
Not coming through all speakers, just the sub-woofer.
These were a good set of speakers, seems a shame to have to junk them.
Posted on Oct 02, 2008
    Sergeant:
  • 241 Answers
I use to get that same sound but only when I first booted up.
Is this only happening when you have the volume up and does it happen if you turn down the sound all the WAY not off
Your MIC could be enable and on boost level.
If you sound is popping from the music or other source is it from all the speakers???
I can try and help
Posted on Aug 28, 2008
My altec Lansing avs 500 speaker system was working fine, until I inadvertently used iobit driver updater to update the drivers. Now the speakers don't work. The speakers don't show as a device.
Remove the audio driver and then have your machine do a search for drivers...you can also do an update which should do the same thing. It should see you don't have an audio driver and will download the proper one.
Semper Fi,
Z
Aug 02, 2017 | Acer Computers & Internet
Drivers for altec lansing 300 avs speakers
Hello there,
i have never seen a hard wired speaker need a driver, but with the right model number i am sure i could find a driver for it .
don't forget to Rate
Jan 26, 2011 | Altec Lansing AVS 300 Computer Speakers
AVS 500: The two surround speakers a re working, the other two (including the surround & volume control) are not. What could be wrong? I have tried reseating the plugs, but no change.
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 06, 2010 | Altec Lansing AVS 500 Computer Speakers
Altec avs500 speaker sound in 2 speaker only and not the rest
Try making sure the surround sounds knob is turned all the way to the right and that the switch on the subwoofer is on stereo and not gaming.
Mar 13, 2009 | Altec Lansing AVS 500 Computer Speakers
I have altec lansing speakers AVS500 and have no sound
It sounds like the subwoofer speaker has blown. If you are comfortable working with a soldering iron and speakers then you can open the case and replace the speaker with a replacement subwoofer speaker. A good online store for replacement speakers is PartsExpress.com
Dec 28, 2008 | Altec Lansing AVS 500 Computer Speakers
What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Nov 20, 2008 | Altec Lansing AVS 300 Computer Speakers
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing Altec AVS 500
If you are using windows media player check if your player is configured to have an echo. If it is configured remove it. If it is not configured to have an echo and if you are using any soundcard have that sound card check by an expert or by your vendor and let them check it out if it is still under warranty.
Jun 24, 2008 | Altec Lansing AVS 500 Computer Speakers
AVS 500 subwoofer speaker
If you have a digital tester just select DC voltage then connect the positive leads of the digital tester to any of the wire coming out of the 18V adapter (WARNING do not connect to the wire connected to the main) and then the other lead of the digital tester which is the negative connected to the other wire of the 18V adaptor. If in the screen of the digital adapter reads a negative value, then it indicates that the other wire is the negative and the other is positive. Otherwise if the tester reads a positive value then your tester's leads have got the right connection.
P.S. please rate me.
Jun 10, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing computer speakers model AVS500
18VDC 1000mA Center Positive.
Altec-Lansing
Part Number: AVS500-A6860
Model Number: 9701-00648-1UND
Jun 02, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing AVS 500 Computer Speakers Logo
336 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
