Question about HP PSC 750 All-In-One InkJet Printer
Open Door. Clear carriage jam, and then press Enter
My HP PSC 750 inkjet printer keeps giving me the above error message. It starts out with a grinding sound, then flasses the error message. I have reinserted the cartridges, but beyond this I don't know what to do.
Please email Anne at: annereuther@hotmail.com
  • 2 more comments
  • Anonymous Aug 31, 2008
    Open Door. Clear carriage jam, and then press Enter problem,
  • annereuther Sep 05, 2008
    I checked for paper, pieces of paper, anything that may cause a jam - but I don't see anything. The noise and the error message happen when I first turn on the printer.
    Thanks for your idea.
  • bernie12345 Sep 06, 2008
    I checked for paper,i checked ink catridge,cleaned head with alcohol swabe i don,t know what else to do
  • assistancepz Oct 02, 2008
    After 'initializing' message upon turning the machine on, the 'OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS ENTER" message appears continuously beginning with the loud noise as described previously on this posting.
    The cartridges move about halfway across the front when I press copy.
    I have looked throughout the machine (including from the rear) for loose paper ... anything and have found nothing.
    This machine has worked perfectly previously.
    I would appreciate your assistance. Thank you.
Sounds like you have a jam. Open the back of the printer and checl for any paper large or small. If there is no paper, just opening the door and closing it may get rid of the message. All it takes is a piece of paper the diameter of a pea to send a signal that there is a paper jam. After yuou have finished close the door and push enter to let the printer know you are finished. See if this helps. I don't think it has anything to do with the ink cartridges. It sounds more like something stuck causing the jam. Be sure not to have anything like a staple attached to the paper you are printing on to. A speck of dirt could casue a jam message too.
Posted on Aug 31, 2008
HP PSC 2210 has the error message 'Open Door, Clear Carriage Jam, and then Press Enter'. No paper jams present?
Check door for paper stuck in front of sensor. There is a door in the back look to see if paper shred is in there infront of the back door sensor.
Jul 27, 2010 | HP PSC 2210 All-In-One InkJet Printer
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I keep getting a message: open door. clear carriage jam and press Enter. what do i do? I checked the cartiage and closed it and pressed enter and still get the same message
Dear,
Its a problem of purging unit it is in a right hand side of printer clean the surface properly and then check the printer.
bye
wasim
Jul 20, 2009 | HP PSC 1610 All-In-One InkJet Printer
Cartridge jams
remove the cartridge and directly off the printer let the carriage remain in center.then with your hand manually move the carriage from left to right.3 to 4 times.then on the printer and insert the cartridge after cleaning it with dry tissue.then check out.also in the back side of the printer there is access door to remove the paper if jammed so check out there also if any paper jammed.
thanks.
Apr 01, 2009 | HP PSC 2210 All-In-One InkJet Printer
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Printer Problem
Unplug the printer.
Move the carriage back to the home position, all the way right.
Plug back in the printer.
Apr 21, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
986 people viewed this question
Ben Johnson
