Question about Toshiba e800 Pocket PC
Applications After using some applications I turn them off only to find that they are still running in the background. Is there any setting or software that would allow me to exit an application and NOT have it using up battery power in the background?
    Master:
  • 903 Answers
I use e800 too and I switch them off manually. You are right. All used applications running in background. All of them are listed in “running” tab. Like I said you can switch them off manually singly or all of them with “select all” option.
Posted on Sep 08, 2005
SOURCE:
Why does my new cell phone get too hot to hold?
It probably has a lot of applications running in the background, and if you are using the GPS, wireless connections, and some other applications that are running simultaneously the battery will get warm as it provides the current to operate the phone.
To reduce some of this, you may want to try adding a battery monitoring app, and an app to manage the other applications use. These are available from the Play Store.
If there are apps running that you do not use or need all the time, you may want to force them off [settings/apps] to reduce the draw on your phone.
Mar 31, 2015 | Cell Phones
Tip
Run iPad Apps in the Background
<span style="font-weight: bold;">Instructions on how to run iPad applications in the background!!</span><br style="font-weight: bold;" /><br style="font-weight: bold;" /> <ol style="font-weight: bold;"> <li>Jailbreak your iPad. You find instructions on how to do that here: Windows, Mac. You can also check to make sure you are using the latest tutorial with the iClarified Jailbreak Wizard.</li> <li>Clique Cydia</li> <li>choose Sections from the tabs at the bottom of the screen.</li> <li>Press to select System from the list of Sections.</li> <li>Press to select Backgrounder from the list of Packages.</li> <li>Press the Install button at the top right of the screen.</li> <li>Press the Confirm button to begin installation.</li> <li>installation has completed successfully you can press the large Restart Springboard button.</li> <li>open the application you would like to run in the background. Press and hold the Home button until you see a "Backgrounding enabled" message. <br />To stop an application from running in the background press and hold the Home button until you see a "Backgrounding disabled" message.</li> <li>Soon there will be background managers available in Cydia. These will let you see which applications you have set to run in the background and help you switch between them with ease.<br /></li></ol><br />
on May 07, 2011 | Cell Phones
My nokia 6230i freezes when am using its camera, what can i do?
Sometimes,such issues occurs when other pograms
are running simultaneously. Therefore when your
phone freezes again,check and see whether there
are programs running in the background.
gain... and no applications in background. It happens mainly with flash when there's few light. Up to now no problems with sun and flash is not used.
urn off sensors on settings menu..
it will solve camera and musicplayer issue with 6210. accelerometer application tends to conflict with camera and musicplayer.
hope turning off this helps..
contact me anytime if u have any more doubt
Feb 14, 2012 | Nokia 6230i Cellular Phone
My battery dies half way through the day without even using it, is there something running on the phone draining the battery?
Hi
BBM ( blackberry messenger) could be a drain, especially with that many contacts pinging you all day long. Is your brightness on high? That is another big power drag. What apps are you running?
What themes have you installed? You can try reinstalling the OS. Check what applications are running on your device in the background, press the Menu key then choose Switch Applications. You will see the icons of each application there.
There are commonly four or five applications that will always be running (Messages, Call Logs/Phone, BlackBerry Messenger, Home screen, and the Browser; there are other third party applications such as Bee Jive, and BlackBerry Alerts which will also run in the background which you cannot close if you want them to operate). Make certain that the browser is NOT on an active webpage (open the browser and choose Menu > Close). Close any other applications that do not need to be running (the camera or a game you were playing or Google Maps).Also make certain BlackBerry Maps is not running in the background.
Do a simple reboot: With the BlackBerry device powered ON, remove the battery a few seconds and then reinsert the battery to reboot.
Now, watch your battery use the next few days again and see how it goes. Make sure you close or exit ALL applications properly: If you just hit the red "end call" key to go back to the home screen the application actually stays open and running in the background. If you do this repeatedly you will have lots of apps open and consequently your memory will get used up. Lack of memory is the biggest reason your BlackBerry slows to a crawl or locks up. If you get into the habit of actually using the menu key to close the applications this will at least slow down this battery drain and memory-clogging process.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Mar 19, 2011 | RIM BlackBerry? Tour 9630 Smartphone
How to increase my laptop speed?
Well try to remove unused applications and delete unnecessary files in your computer. Set desktop background to solid color. Close memory-eating processes running in background. Perform a disk defragmentation. Good luck!
Mar 06, 2011 | Computers & Internet
Try to install comes up with error about firewall settings
1. Reboot your computer.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Jan 31, 2011 | Yahoo Messenger
Pls help for yahoo messenger 10 for cannot started . authomatic in my window for video call ,i exiting to see my family and here
check ur connection setting and reinstall yahoo messenger Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab. 3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation. 4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list. 5. Click the "End Task" button. This will temporarily close all background applications on your system. 6. Click the "X" in the upper right corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should not experience the same issue that you had before. 8. After Yahoo! Messenger is installed,run registry cleaner reg in out also reboot your system. All other background applications will return to their original configurations.
Oct 12, 2010 | Yahoo Messenger
Blackjack 2 speed
If your phone is going slowly you probably have multiple applications running in the background.
1. go to start ->applications -> task manager
2. there will be a list of applications that are running
3. press "stop" for the applications that you arent using
hope this solves you problem
Oct 26, 2008 | Samsung BlackJack II Smartphone
Htc mobile pc
Make sure that all programs you have been using are closed when you press the cross (X). The factory settings are se to minimize the application instead of closing the program. This will keep all the applications running on the background instead of actually being closed. There are options under the menu setting options that give you the option of closing the applications by taping X or by pressing and holding X. I set tapping on mine.
The more programs running on the background the more memory usage.
Jan 11, 2008 | HTC Touch P3450 Smartphone
Toshiba e800 Pocket PC Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
