Question about Compaq Presario X1000 Notebook
Computer running real slow and then shuts down
My computer will run real real slow when plugged in, the battery will not charger completely. When computer is on I can here a slow "clicking" when the processor is running (I am assuming it is the processor". I have tried restoring to a earlier date in case of a virus but it is not letting me do that either. Real slow at boot up and shut down, I can hear fan running.
  • Texpope Oct 05, 2008
    having the same problem, minus the clicking. When not plugged in, and running off battery, the computer runs at normal speed. When plugged in, it suddenly runs super slowly. Mine is a Dell 620, btw.
  • Roberta Smith
    Roberta Smith May 11, 2010
    Is the fan running full time ?
    Also feel the bottom of the case... is it getting extremely hot ?
    Robert
    Scholar:
  • 62 Answers
Virtually infinite number of possibilities. Anything from a virus to simply having an overfilled hard drive could do that. You could do a few checks, and when you do those checks you can set a new Restore Point before trying each new step. First check the empty space on your hard drive, it's recommended you have at least 5GB if you're running Windows XP/2k. Do a Disk Cleanup from System Tools. Empty your hard drive as much as possible. Make sure you don't have too many things running on the Task Bar. Do CTRL-Alt-DEL and enter Task Manager to see what's currently running, if you have 50 or more processes running it's probably too much. Uninstall programs you never or very rarely use. Do an updated antivirus scan. Scan for spyware, adware, malware etc... using many available free tools. Defragment your hard drive. If you're still having problems, insert your windows installation disk, pull up the Command Prompt and type "sfc /scannow" without the quotes. Windows will scan all the system files and replace the missing and corrupted ones with fresh ones from the disk. You'll have to click on OK whenever a message window pops up telling you that windows wants to copy the system files from the windows disk. Reboot the PC. If still having problems, obtain a registry cleaner program like RegCure or similar (one that has good reviews) and run it. Reboot the PC after running such program. Backup your PC with something like Acronis True Image or at least set a new Restore Point before going any further. Run Windows Updates if not yet fully updated. By the way that clicking you're hearing that's your hard drive, processors don't make sounds, unless it's the cooling fan of course :)
Posted on Aug 28, 2008
I am guessing from the "clicking" noise that the some sort of anti-virus app trying to scan the HDD and the HDD is virus-infected. If you do not have much stuff on the PC, do you think it is possible to reformat the HDD and re-install the OS? (this is obviously last resort - I am sure expert folks here will come up with better solutions)
NEW HP Spectre 13T-3000, 13.3" Touch will not run with the battery and shuts down randomly
you can use the unit without the battery. Remove the battery, plug in the charger/power supply and turn on the unit and wait for the result. if the problem persist?..... maybe the fault is in CPU fan. check the fan...overheating the processor. Cleaning the heat sync and reapplying silicon compound on CPU's can cure the problem.
Sep 02, 2014 | Computers & Internet
I have the same problem with my computer not shutting down, it just stays on, even all night saying it is shutting down (blue screen). I have a laptop HP Pavilion Entertainment Notebook PC w/XP. It is also...
This sounds like a hard drive error. You should deliver it to a professional, or test it by yourself it that is possible. If you have some kind of warranty for your computer, you should deliver it were you bought it.
Nov 14, 2011 | HP Computers & Internet
I have a Satellite L300 running Windows 7. I can charge the battery up using the OEM charger that came with the laptop. However, the computer will not operate if the charger is plugged in. I can do...
right off the bat, i would suspect a bad power adapter for the computer. or perhaps a faulty computer. your best bet is to call toshiba and talk to them directly.
Sep 06, 2011 | Toshiba Satellite Pro L300 Notebook
When I plug in my Dell Inspiron 1521 laptop, I get an error message saying it does not recognize my charger, will not charge and will likely slow down my computer's speed/performance. Everything...
Same topic on Dell official community, may it will help.
http://en.community.dell.com/support-forums/laptop/f/3518/t/7311465.aspx
There is high possibility that your adapter is stuffed. Dell have built in a recognition circuitry into the 65w adapters and when that goes, the system will no longer recognize it as a 65w adapter even though it is still putting out 65w. The system then shuts off the battery recharge circuit and to make matters worse it won't even charge the battery when the computer is off. It also speedsteps the processor down to half its speed so everything runs slower. Only option is to stick with a slow computer that can't be used on batteries or buy another ac adapter.
If you do not want to pay $80 for a original adapter directly from dell, there is an alternative choice to get an 3rd party charger, check this link below:
http://www.chargerbuy.com/replacement-dell-inspiron-1521-ac-adapter-19-5v-3-34a.html
Aug 02, 2011 | Dell Inspiron 1521 Laptop
No power
Try disconnecting the power supply and start it on battery only.
After you see a screen display of some kind, the power supply can be reconnected.
If this does not work, then remove the battery and start the computer using the power supply only.
After the computer start up sequence is complete, the battery can be re-inserted into the computer.
If the computer continues to misbehave on later restarts, then follow the more rigorous BATTERY RECALIBRATION Procedure below.
1. Now, after the system is up and running with both the battery inside and the power supply connected, after taking note of the current settings so that they can be restored later, set the power plan to High Perfomance, set the computer to Never Sleep on Battery and on Power Supply, disconnect the power supply and allow the computer to run until it shuts itself off due to a low battery condition. This will discharge the battery and performs phase one of battery re-calibration.
2. Next, plug in the power supply, while leaving the battery in place and restart the computer. Allow the battery to fully recharge while leaving the power plan at High Performance and the Sleep to Never. This performs phase two of battery re-calibration.
3. Then, disconnect the power supply and allow the computer to run until it shuts itself off due to a low battery condition, again, now that it has a possibly better, fuller charge than in the previous charge/discharge cycle.
4. Again, restart the computer, connect the power supply and allow it to completely charge the battery.
5. Shut down the computer, disconnect the power supply.
6. Restart the computer and allow the computer to run until it shuts itself off due to a low battery condition again.
7. Now the battery has been recalibrated. Connect the power supply, restart/resume the computer and allow the battery to fully charge again. The Power Plan and Sleep Mode can be set back to their original settings at this time.
8. The above procedure should only need to be performed every six to twelve months to recalibrate the battery.
This condition sometimes happens to my HP Presario when I have left the power supply plugged into the computer with the battery in for several days or weeks at a time, without running on the battery alone for a while to discharge and recharge it a little bit.
HP recommends that when running your computer for more than two weeks from the power supply, the battery should be removed to slow the aging of the battery, which can cause the battery to lose capacity or fail prematurely.
May 23, 2011 | HEWLETT-PACKARD Hewlett Packard HP 15.6"...
Toshiba Satellite a205 Battery Will Not Charge
You did what all should not have been done. your battery works as a buffer between high surge of electricity which comes through electrical supply i.e. it protects your smps from burning up. From your current position it seems your smps fuse has blown. If they have given one or else your smps itself has gone. I'll tell you for your future usage of battery. Whenever you get any electronic equipment with chargable battery you should never switch it on unless and untill you have charged it for continuous 24 hours. Never try to run such equipment directly through dc or ac power. Hope your fuse has gone its not costly.
Jun 19, 2009 | Toshiba Satellite A205-S4607 Notebook PC
Machine shuts down, might start again in a day or so
This may solve your issue:
The PMU is a microcontroller chip that controls power functions for the computer. The PMU is a computer within a computer, as it has its own memory, software, firmware, input/output, a CPU, and more. Its function is to:
  • Tell the computer to turn on, turn off, sleep, wake, idle, etc.
  • Manage system resets from various commands.
  • Maintain parameter RAM (PRAM).
  • Manage the real-time clock.
Over time, the settings in the Power Manager may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, or not seeing devices plugged into the USB and FireWire ports, among others.
Resetting the PMU is not intended for resolution of a stall or situation in which the computer is unresponsive. A PMU reset should not be necessary except as a last resort in cases where a hardware failure of the power management system is suspected. Performing a PMU reset returns the computer hardware, including NVRAM, to default settings and forces the computer to shut down.
http://support.apple.com/kb/HT1939
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | Apple iBook G4 Mac Notebook
Compaq Presario X1000 Notebook Logo
123 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
