Question about Kenmore 42822 Front Load Washer
Whirlpool HE3T washer
My washer is coding the door locked code.how can i open it to get my clothes out so they dont mold.
  • 4 more comments
  • pmoujabber Oct 01, 2008
    my 3 year old Kenmore Elite HE3T is not draining or spinning, and to make matters worse the door is locked shut and I can't open it to take clothes off. It is Tuesday and the repair man will be here on friday...time enough for everything to mold!! help??
  • mlaxcoach Jan 04, 2009
    same problem how can we get the door to release to at least get the clothes out. No chance of a repairman until Wednesday it happened last night(Saturday) bad outcome by Wednesday.
  • megadad6 Mar 16, 2009
    Same problem here, I tried pulling down on the ring and nothing happens, Just to be sure, the wing pulls along with some white plastic. It pulls about an inch or so. Nothing. when the washer ends the cycle, there is the normal click.
    Just
    Just a quick question
    I noticed the ring on the bottom of the black plastic locking mechanism. It had pink and blue wires attached. I pulled the ring down and nothing happened, any suggestions?
    Scholar:
  • 31 Answers
To unlock the door:
1) Take off bottom access panel on front of washer. (3 screws hold it on the bottom)
2) Reach up between the cabinet and the front weights on the tub. You will feel a small plastic ring hanging down. It's a bit of a way up, (the bottom of the cabinet is at about my elbow, it's easiest to lay on the floor and look up, you might even be able to see it)
3) Pull that small ring and it will release the door lock.
Good luck. Let me know if you get stuck.
Posted on Feb 12, 2009
Error dl f: door will not lock to start wash
This is obviously a door lock/switch assembly failure. The fault code FdL flashes if the door locking routine fails, after six attempts, to lock the door. You should hear the door lock clicks six times before the fault code flashes. Replacing the door lock/switch assembly is the only viable solution and it's a do-it-yourself repair. You only need a pair of needle-nose pliers to stretch the door gasket retaining hoop and a Phillips-head screwdriver to remove the screws securing the door lock/switch assembly to the front panel. Click on the link below for the detailed instructions on how to replace the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Front Load Washers
Jun 17, 2011 | Kenmore HE3T Washer
Kenmore elite he3t washer door will not open, always showing as f22 error code
it is your safety latch on your door. On the front load washer it will lock the door and if there is a problem with the latch it will keep it closed to prevent injury. If you have cloths in there try unplugging for about fifteen minutes or so and then plug it back in.
May 07, 2011 | Washing Machines
He3t washer door is locked with clothes inside. Manual release doesn't work; and disconnecting DP21 doesn't work.
Possibly an item of clothing between the door and frame. Unplug the washer.
Press gently against the door latch while you pull on the emergency cord.
Dec 27, 2010 | Kenmore HE3T Washer
Kenmore elite hE3 washer has f32 code flashing. Door is locked and would not open.
F/32 error code; this indicates a pressure switch failure. The Sud error code indicates a suds lock condition. Be sure that you are using HE laundry detergent & the drain hose is not too low.
Dec 09, 2010 | Kenmore HE3T Washer
I have a Kenmore Elite Quiet Pak 4 HE3T Washer. The door is locked with clothes in it. The displays is saying F dL. What has happened and how can we open the door.
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Apr 12, 2009 | Washing Machines
My HE3 washer, about 4 yrs old is locked , showed error code 6
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the control is unable to properly detect motor speed. Due to this the machine shut itself down.
Nov 11, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Fdl Code on whirlpool front load washer
remove bottom panel reach up to bottom of door lock there is a small tab pull it down door will come open..if after opening you finda lot of water still in machine suspect pump plugged worse case bad control bd
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE
1.Unplug machine
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Mar 29, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool duet washing machine
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Aug 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 42822 Front Load Washer Logo
140 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
