We are able to send faxes, but not recieve them and our setting show correct
    Genius:
  • 2,120 Answers
Call your cell phone from the fax machine to make sure the senders are using the right phone #
Make sure the phone line is ANALOG not DSL
Posted on Aug 29, 2008
4 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: Faxjet 525 will not send faxes
it is never getting a dial-tone. Phone line should be plugged into the LINE port.
Posted on Jan 29, 2009
SOURCE: fax can not recieve. It sends okay. Hp fax 1010
Most likely the machine has been set to "manual receive" from either "fax/tel" or "automatic" receive. check your manual to check/ change the setting.
Posted on May 26, 2009
  • 3594 Answers
SOURCE: How can I test that my fax machine can send and
Use the fax to make a copy if the copy is bad the fax you send will be bad.
DickyO
Posted on Nov 18, 2009
Hoe do I set up fax functions on Canon Pixma MX452
My incoming fax issue was resolved when I enabled the answering machine function on my phone. All this time my answering machine was turned off. I have yet to send a fax. My model is the Canon Pixma MX452.
Apr 05, 2013 | Canon PIXMA Office Equipment & Supplies
Can't receive faxes from my fax machine. I can send out faxes but can't recieve any faxes in. I was told that My fax machine did not ring when someone was trying to send me a fax. They could dail my number...
Go to settings and enable Rx.
The fax machine doesn't
receive documents
automatically.
Make sure that the reception mode is set to
FAX. If you subscribe to a distinctive ring
service, make sure that the Distinctive Ring
function is set to the correct ring pattern. If you
do not subscribe to a distinctive ring service,
make sure that Distinctive Ring is set to OFF
SETTING. (See
Distinctive Ring
in Chapter 7.
This machine can also block faxes from certain numbers if you wish. Your manual is here;
http://pdf.textfiles.com/manuals/FAXMACHINES/Sharp%20UX-460%20Plain%20Paper%20Fax%20with%20TAD.pdf
Nov 20, 2017 | Sharp UX 460 Plain Paper Thermal transfer...
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Fax can not recieve. It sends okay. Hp fax 1010
May 26, 2009 | HP 1010 Plain Paper Inkjet Fax
Cannot recieve or send faxes
Check out the Easy Setup Instructions available here. If you can neither send nor receive faxes, you may not have the phone line connected to the correct port, see page 34 of the guide. Also check what receive mode the machine is set for. Pages 42 and 43 explain the different options and how to change the receive mode.
Mar 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How to send and recieve faxes
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_775_EN_86.PDF
Aug 01, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Just bought and install fax machine (MFC640cw) I can send faxes but cannot recieve any. Phone rings, it recieves but it does not print.
It was installed on a VOIP connection. The Modem speed was changed to BASIC (9600 bps) which turns the error correction mode (ECM) off. Standard speed -14400 bps which may creat errors.
Steps: Menu/set - Fax - Miscellaneous - Compatibility - BASIC - Menu/set - Stop/Exit
May 21, 2008 | Brother Office Equipment & Supplies
Still can't get fax not to pick up when answering machine is connected.
if you have the fax-575 there should be a TAD setting.
This is the setting you would use if you're using an answering machine on the same phone line as your fax machine.
To set the Recieve Mode :
Press Recieve Mode. The LCD display shows your current selection.
Continue to press Recieve Mode until your new selection appears. After 2 seconds the screen returns to the date and time display, along with your new Recieve Mode setting.
The 4 Recieve modes are Fax Only, Fax/Tel, TAD:Answering Machine, Manual.
Hope this helps!!!
Jan 30, 2008 | Brother FAX-575 Plain Paper Thermal
Hp officejet 7310 fax problem
Just change below settings
Press setup on the all in one. Navigate to Advanced Fax Setup using arrow key. Set the FAX Speed to Slow and turn off the ECM (Error Correction Mode). Try sending fax. Please simply send a fax (single page black and white text) (1-888-473-2963 . Check for the result.
Dec 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
35 people viewed this question
jasbo
jasbo
