Question about Kodak Easyshare M753 Digital Camera
Kodak digital camera won't turn on
Kodak Easyshare M753 Digital Camera won't turn on.i tryed new batteries still no power.any clue of what problem could be.camera wasn't damaged in any way .
  • 8 more comments
  • Anonymous Sep 09, 2008
    wont turn on and lens wont go in .
  • Anonymous Sep 11, 2008
    i have the wall charger and mine wont come on period wether the battery is in or out and even if it's plugged in the wall or not =\
  • kaeluh17 Sep 23, 2008
    i push the on and off button put nothing happens.
    i've tried getting a new battery but it does not work either.
    and my camera hasn't been damaged.
    even when i charge it my computer will not recognize it and will not charge it.
  • spacekitty24 Oct 20, 2008
    Tried using my M753 camera and it wouldn't come on. Brought it home and hooked it to the computer and still nothing. Hopefully a new battery will help, but by reading these responses I'm not sure.
  • Anonymous Oct 23, 2008
    camera was working fine yesterday and today it wont turn on, wont charge and my computer wont recognise it!!!
  • NavyWife07 Nov 06, 2008
    I have the same problem. I was using the camera and it was working fine and the next day it wouldn't turn on. I tried charging it on the printer dock but it wont even recognize it, so I went out and bought a new battery but it still wont turn on. Very frustrating!
  • ChristieB Nov 27, 2008
    Same identical problem w/ not only my M753 but also 2 other EasyShares that are a little older. I needed one for Thanksgiving and had to go out and buy a new one tonight. I got the M1063... I just fully charged it and inserted my memory card. Keeping fingers crossed....
  • tfbrady Nov 30, 2008
    My camera started doing the same thing two months ago. It seems like this a fairly common problem. You would think that Kodak would look into it and do something about it.
  • Anonymous Dec 04, 2008
    I have the same problem. after charging it with the usb it wont power up. If I wait for a day it seems to fix itself and will start working again. So frustrating if I want to use it right away. What is the problem ?
  • rosepetal159 Dec 23, 2008
    My Kodak Easyshare M753 camera will not charge with the USB. I cannot get any power either. I took it to Best Buy and they said that the problem is not the charger, but the camera. I got the camera last year for Christmas, the one year manufacturer's warranty is up and now I am going to need to buy a new camera. I have probably only used it 5 times total.
    President:
  • 2,761 Answers
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 15, 2009
Habubnik
  • 114 Answers
SOURCE: transferring pictures from my Kodak EasyShare digital camera to my computer
This error message means that the preferences in EasyShare software are set to save pictures to the CD-ROM drive or some drive other than your hard drive. To correct this, follow these steps: Start EasyShare software. Select Tools > Preferences. Select the Transfer tab. Below "Select the location on your hard disk where you want to copy transferred pictures," select Browse. Browse to the desired location on the hard drive where you want to transfer your pictures. The default location is: For Windows 98/Me Operating Systems: c:/My Documents/My Pictures/Kodak Pictures For Windows 2000/XP Operating Systems: c:/Documents and Settings/user name/My Documents/My Pictures/Kodak Pictures Select OK to return to Preferences, then click Apply and OK to save and close the Preferences. Reconnect the camera, and transfer the pictures.
Posted on Aug 29, 2005
SOURCE: Kodak EasyShare C743 Digital camra has cracked LCD
Buy a used camera on eBay that has a good screen and change it yourself. It is very simple to do and here are the instructions on how to do it.
http://www.clickondavid.com/LCD7430.pdf
I have done this and it works just fine if you follow the instructions.
Posted on Jan 07, 2008
SOURCE: Kodak Easyshare camera turns on and off
Yes you are. My wife denied that she dropped in the sand but I found a list of photos that she wanted to print on a post-it paper in the cover and it had sand all over the sticky part. Used the pressure air spray to clean the rings and it is back to life. Well It worked but there was some problem during zoom in&out, so I spray the rings while zooming and out and that cleaned it. I hope I don't have to open it to clean the mechanism. Thank you.
Posted on Jun 08, 2009
drifterK
  • 4924 Answers
SOURCE: my kodak easyshare M753 has pink tint and lines
its obvious a malfunction that didn't occur by bad handling ..and if the device it is still in the warranty period , my advice is to go for it if you never open it or other things that you wouldn't suppose to do
Posted on Jul 15, 2009
  • 68 Answers
SOURCE: Lens error 10e,1,10- Kodak EasyShare M753
this is an hardware error. I'm sorry but you can't fix it by yourself. You've to contact kodak for a repair.
Posted on Oct 16, 2009
How long will the batters last on kodak m753 iv had the camera for 7 years
The battery life is quoted as 250-350 pictures in auto mode. This would be for a new battery and camera and it is likely that the number of recharging cycles on a 7 year life will have led to some deterioration in the battery life. The two links below take you to pages from which you can download the Users guide and getting started guide in a pdf format.
http://www.manualslib.com/download/348740/Kodak-M753.html
http://www.manualslib.com/download/89260/Kodak-Easyshare-M753.html
Good luck
Aug 25, 2014 | Kodak Easyshare M753 Digital Camera
I have a easyshare M753 kodak digital camera I have a new battery it will not charge whn I plug it into my computer and charger it will not charge the green light does not come one and the battery is in...
Hello Barb, I am not sure if you are dealing with a bad battery or you are having problems with the camera, I would suggest trying a new battery as this is the cheapest route to take,then will will know for sure if it is battery related or a camera failure.
Best Regards, Russell
Dec 12, 2012 | Kodak Easyshare M753 Digital Camera
Kodak m753 camera will not turn on
Here are the steps for no power issues: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 07, 2010 | Kodak Easyshare M753 Digital Camera
Just won't power up! Tryed the battery from my sam
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Oct 27, 2009 | Kodak Easyshare M753 Digital Camera
Oct 16, 2009 | Kodak Easyshare M753 Digital Camera
My Kodak EasyShare M753 wont turn on at all, but when i tried charging it, it still wouldnt turn on. I have tried lots of different charging methods, like my USD port that came with the camera and my...
This problem is frequently due to corroded battery terminals inside the camera. Before you purchase new batteries, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
It uses a simple Q&A format to diagnose problems and propose solutions.
Jun 28, 2009 | Kodak Easyshare M753 Digital Camera
Kodak Easyshare M753 is not charging.
You LI-Ion battery is bad and not holding a charge. Buy a new one.
Apr 08, 2009 | Kodak Easyshare M753 Digital Camera
Camera wont turn on
Clean battery contacts. Use "small" flat had screw driver, and pry up "GENTLY" on battery contacts. Replace battery. Hit a few times with knuckle "NOT HARD" next to lens. Turn camera on. Camera will work forever.
Aug 28, 2008 | Kodak Easyshare M753 Digital Camera
Kodak m753
to remove the purple tint on your LCD screen, all you need to do is:
1. Turn the camera off.
2. Take out the batteries and wait about 10 seconds.
3. Replace the batteries with new or freshly charged batteries.
4. Remove the memory card from the camera.
5. Turn the camera back on.
If the issue is not resolved, send cam for repair. Kodak cameras have 1 year warranty
Aug 06, 2008 | Kodak Easyshare M753 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
4,073 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
