HE3 front-loading automatic washer
Our washing machine runs through a cycle, then once it's done, it starts to fill back up with water. So once the wash cycle is done, I take the clothes out and about 20 minutes later the washer is filling up with water again. Do you think this is a problem we can fix ourselves - what could it be? Thanks for your help
  • 1,543 Answers
Sounds like the water valve is not turning off 100%. Replace the inlet water valve. (where the hoses connect onto the machine)
Posted on Aug 28, 2008
Sears washer elite he3 fills back up with water when off
You have to shut your wall inlet pipe after your wash is over. If the leak persists you only have to change the inlet valve, which you can do yourself, see internet for spares quoting your washer number, model. It is good to keep the valve closed when the machine has finished it's wash.
For unlocking hold down "end of cycle" button at right side of panel for 3 - 5 seconds. The door remains locked when there is water in the machine, it does not want to wet your floor. Today's machines are smart. Helped?
Mar 05, 2013 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Tip
SMELLY FRONT LOAD WASHER
MAKE SURE YOUR WATER IS HOT WHEN STARTING THE FILL CYCLE YOU MAY HAVE TO FILL IT UP ONCE THEN DRAIN IT THEN FILL IT UP AGAIN TO MAKE SURE ITS HOT THEN ADD 1 CUP OF AUTOMATIC DISHWASHER SOAP AND RUN AN EMPTY CYCLE. THIS WILL REMOVE ALL ENZIMES AND SMELLS FROM WASHER
on Jan 12, 2010 | Washing Machines
Washer fills with water after the cycle is over
check the pressure senser ,if this ok check the pcb assy
Jun 20, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My HE3 washer fills up with about 3 inches of water on its own when it is not in a washer cycle
Fill valve is not sealing correctly when it is switched off
If your machine is hot & cold fill, try turning off the cold water at the inlet and see if the machine still fills up if it does then it is a faulty hot valve if it does not then it is the cold one
They are easy to change and easy to buy from dealers or third party suppliers
Jun 19, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
IT wont start washing
if it fills with water or has filled and wont go any further then suspect the door switch< latch assembly has switch> if it doesn't fill then possibly water valve not working,if neither of these seem accurate then please give more info
Apr 20, 2009 | Kenmore 42822 Front Load Washer
KENMORE ELITE HE3 WASHER
2 things you may try if you haven't already ..let washer fill with hot water ..pause and open door pour in about 2 cups chlorine bleach before starting back up..with rag soaked in bleach/water clean inside front door boot ..be sure to roll boot toward front and clean out accumilation under it wash as much as possible off door seal..allow to finish cycle (normal wash should be fine)..may also try removing lower panel remove pump acess plug and clean pump out thoroughly..you are not alone ALL front washer have same issue and if some sort of routine cleaning isn't done problem reoccurs also leaving door slightly open between usues will help ..by the way that is a german made washer
Sep 12, 2008 | Kenmore Elite 45986 Front Load Washer
Mold & Smelly in Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3 washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
The Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Mar 27, 2007 | Zanussi F1245W Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
