Question about HP iPAQ H1910 Pocket PC
Synchronizing problem Trying to sync ipaq with my computer. Checked and confirmed all need requirements and programs. Continues to ask for missing file: Setup 1.INI Please help if anyone has solution. Thanks
    Master:
  • 450 Answers
Uninstall and reinstall Activesync is where I would start.
Posted on Sep 08, 2005
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
Im download app into my hp ipaq,then it hang/jam...it not running like usual..
For hanging/Jam problem, few factors can be involved, First of all you have to check, how much space is being left in phone memory after installing particular applications, To check the settings, Go to settings, Memory,
Solutions:
1. Soft Reset,
Try resetting the device while hold down the End Key for few seconds, when the phone is switched off take off battery for few minutes, then try putting the battery again, It will clear the memory used by the softwares,
CAUTION: Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.
2. Hard Reset
Hard reset will restore your Ipaq to factory default settings, Perform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.
settings.
NOTE: The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center). bilalseham_6.jpg
if you require more assistance feel free to reply to this post
Thanks for using FixYa
Regards-BA
Jan 27, 2011 | HP iPAQ 510 Voice Messenger Smartphone
HP Ipaq h1940 won't sync with Vista
use microsoft windows mobile device center
Jun 11, 2008 | HP iPAQ H1940 Pocket PC
HP Pocket 2003. Need to restore information but not recognising profile. Where do I find the files on PC to copy mobile devise. Using XP student edition
Syncronation profile? you should make a new active sync profile.
or do you mean something else? please be more spesific.
if your device was hard reset and you need to restore something.
tell me what exactly.
Mar 28, 2008 | Computers & Internet
Same IPAQ -New Computer
you should just be able to sync it with the new computer. The data from the IPAQ will be synced to the new computer.
Sep 14, 2005 | HP iPAQ HX2755 Pocket PC
Synchronizing with Outlook
It has to be set upo to be your defualt email program for the sync to work..... In OUTLOOK on your PC click on Tools, Option, Other check the box 'Make Outlook default Email Program'
Sep 14, 2005 | HP iPAQ RZ1715 Pocket PC
Reinstallation of app onto iPAQ upon hard reset
In activesync under Tools/Add REmove programs you can check the box and click "ok" that will install the program. For the most part it's best to do it one program at a time. Obviously your PDA should be cradled or this. Most programs will re-install fine this way. Some programs though do require you to re-install from the installtion program directly since active sync doesn't pick up some important parts of the program. The two programs I have that require the special install are: CLC Journal since it has an outlook component and sets up a sync for the Outlook Journal. The Stowaway Keyboard driver since it had to ask me what language (the new driver doesn't do this...) The other 30 odd programs I have install straight from active sync.
Sep 11, 2005 | HP iPAQ HX2110 Pocket PC
Sync problems
Try to uninstall and reinstall Activesync.
Sep 11, 2005 | HP iPAQ H1910 Pocket PC
Hx4700 not sync all items in calendar
So make sure that you are displaying all categories.... If while on Calendar screen, you click on Tools, Categories... then all category boxes shown , should NOT be checked. If any of them are checked, then you will only be seeing that category of appointments.
Sep 08, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ H1910 Pocket PC Logo
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
