Question about Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint Ultima Fridge/Freezer keeps leaking underneath
I keep getting a pool of water underneath my Hotpoint Ultima fridge/freezer.
What is wrong, and how do I fix it?
Thanks
Ian
  • ianlewis23 Aug 29, 2008
    There is sometimes a bit of ice on the freezer floor, but not the fridge. I noticed when I took out the panel covering the freezer pipes inside the freezer, that the hole leading down out of the freezer was frozen over. Is this to blame?
    Thanks
    Ian
  • douglas smith May 11, 2010
    do you have a layer of ice on the floor of the freezer and also on the floor of the fridge?
    tresilla
    President:
  • 1,462 Answers
Yes this is probably the source of the problem - the defrost water doesn't flow down the drain.
melt the blockage with hot water till you get free flow down the drain - takes a bit of patience
tresilla
Posted on Aug 29, 2008
Water pool on fridge floor
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 04, 2011 | Hotpoint Refrigerators
Fridge and freezer are working just fine. But, I keep getting pools of water inside my fridge. These pools stay to the back of the fridge on all levels and they sometimes turn to ice. I notice ice layer...
Your defrost drain is most likely blocked with ice or sludge. Now when your refrigerator goes into defrost it pours into base of freezer or just anywhere it can to pool up. Click Here=> Leaking Refigerators, just what may be happening Click here also=> Leaking Refrigerator's? Please let me know if you still have questions, Thanks, Sea Breeze
Mar 19, 2011 | Whirlpool Refrigerators
1996 Frigidaire Fridge/Freezer.... The fridge is leaking underneath suddenly, soaking a full sized towel every 2 hours. The water rung out of the towels is slightly brownish in color. No leaks can be...
I'd check the water supply line to the fridge. If kinked of damaged, may be the source of the leak (make sure that the the connection point to the building's cold water pipe isn't leaking - and simply running down the supply line to the fridge!)
Of course, it could be a cracked solenoid valve (turns water on and off when the ice maker calls for water for ice), loose or broken clamp, broken filter (if equipped), etc. All these connection points in the water supply lines should be visible.
Unplug the fridge as soon as you can reach it before working on a wet floor with live electricity.
Please rate my reply if it was helpful - good luck!
Aug 19, 2010 | Frigidaire FRT21P5A Top Freezer...
I have a Frigidaire model number FRT18G4AWA refrigerator that leaks water from the top of the refrigerator part and has trouble keeping cold.
Make Sure Your Fridge is Properly Sealed
One of the most common causes of a "leaking" fridge isn't a leak at all. It's the direct result of your fridge not sealing properly, and as a result running overtime to keep things cool. A fridge that runs excessively will build up extra condensation on the coils, which in turn can lead to the pool of water on the floor that's causing alarm. Check the rubber door seals on your fridge and freezer to make sure you're getting a proper seal. If you find a problem, wash the seals with warm water and soap and apply a thin film of lubricant (petroleum jelly works best). If this doesn't solve your problem, you may need to replace the gaskets. Also, check the adjustable legs on your fridge and make sure the fridge tilts a little to the rear. If it's leaning even a little bit forward, a proper door seal can be compromised.
Check the Drain Pan
Your leaking refrigerator may just have a cracked or damaged drain pan. Your fridge regularly drains water into this pan to prevent water pooling in the fridge itself. Evaporation takes care of the rest. Look underneath your fridge where the drain pan sits and pull it out for inspection. If it has a crack or is otherwise damaged, contact the appropriate retailer about getting a replacement as soon as possible.
Check the Defrost Drain
If your leaking refrigerator is draining inside as opposed to onto your floor, you're probably dealing with a clogged defrost drain. Your fridge is constantly producing condensation inside the freezer, and that condensation drips down the defrost drain into a drain pan underneath the unit. This defrost drain can become clogged with debris or, more often, it freezes shut. Look in your refrigerator manual to locate your defrost drain, and take the appropriate steps to unclog it (inundating your drain with warm water will often do the trick).
Check Your Ice Maker for Leaks
If none of these other quick fixes solve your problem, check your icemaker for leaks. It's a bit unusual, but sometimes the water line to the icemaker fails or comes loose, letting water into your freezer. Try tightening all connections, and if necessary, replacing the line that feeds the icemaker.
Hope this helpout....
Aug 13, 2010 | Refrigerators
Water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Jun 17, 2009 | Refrigerators
Hotpoint ultima fridge freezer
It's just simple.Keep the refrigerator open for few days with power on.After when the electricity bill comes,eveerything will be cooled.
May 28, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
1,258 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
