Question about Macromedia Flash MX
Micromedia projector wlhen i try to open games ect...my screen says a problem has caused micromedia projector to stop working correctly
  • Deion Powell
    Deion Powell Sep 13, 2008
    I tried to play Hall of Justice on Cartoonetwork and It said my Macromedia Projector stopped working
    Problem Solver:
  • 6 Answers
Check with ur flash player, if it is ok then the project file may be corrupt.
Posted on Sep 23, 2008
Green light on prjector PRM 35 will not stop blinking and the projector will not come on
open the case, and reseat the ribbon cable at both ends.
5 screws on the bottom and 3 screws inside the lamp housing to open the case. Be careful not to break the 2 plastic clips in the back.
Also check the micro switch on the lamp door is working correctly.
Mar 10, 2014 | Promethean Board Promethean PRM-35 DLP...
I down load princess and the pauper cd rom but receive an error "micromedia projector stopped working"
http://www.ehow.com/how_5913367_fix-_macromedia-projector-stopped-working_.html Follow this guide it should help you fix your problem.
Jun 05, 2011 | Vivendi Universal Barbie Princess & The...
The HDMI port doesn't have a picture. I tried my PS3 and my HD DVR, which both used to work fine.
Depending on the Version HDMI cable you using this may not work.
some units use a lower bandwith cable such as 1.0, 1.2 ect ect
Yes this does make a diffrence.
Let me know if you have any questions.
Aug 31, 2010 | InFocus IN72 Multimedia Projector
Oregon trail 5th edition vista
Please check the compatibility of the game with Vista, and am not sure if this compatible at first place. Secondly you can run programs or games in XP mode by right clicking on the exe file of the game, goto properties and select compatibility, and then select to run in XP mode. Hope this helps
Nov 05, 2009 | The Learning Company Oregon Trail 5th...
It just stopped working I do not know what happened I could play games at king.com and now i get this message that I dont have micromedia plugin what happened
you may be infected with a viruse but first plese check if any overheating is happening in your machine or somthing like that while working or when the problem happened
Oct 26, 2009 | Acer Computers & Internet
Colors look smeared on screen
If the colour wheel on your projector is out of sync, you will get incorrect colours.
If it is out of focus, focus the lens assembly, if misaligned colours, perform a re-convergence procedure at a fully equipped work shop with a qualified Toshiba engineer.
Oct 31, 2017 | Toshiba TDP-T30U Multimedia Projector
Ds lite stops working with stylus
you screen is what might be the problem
Nov 08, 2008 | Nintendo DS Lite Console
Connecting cinego projector to hp laptop
don't know much about the cinego ( resolution ect)
but on most laptops you will have a "F" button or function key near the top row.. mine is F5 that has 2 square icons to show 2 monitors, 1 black, 1 white, when your projector is hooked to your laptop, hold down the FN key probably lower left or right, and tap the F5 or f7 which ever has the 2 montiors on it, it should be a 3 position switch, 1..laptop only, 2 laptop and projector, 3rd position projector only.
that cingo is pretty low-end so you may have to goto display properties on your laptop and reduce the resolution to 800 x 600 or 1024 x 768.
if you can't get a setting that works, try the 3rd position with just the projector display on, and laptop display off, since your laptop screen is higher resolution it corrects a lot of issues.
Jul 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
Macromedia projector has stopped working
My Micromedia projector has stopped working. I tried to play Mystery Case Files Huntsville and it will not open due to this erra. What do I do to fix it? I've been online all morning trying to fix this but I have not had any luck.
Apr 24, 2008 | Computers & Internet
Starts up but turns onto standby straight away
There could be a problem with the flip down iris protector. If the Sanyo is on and you flip the protector down manually then the projector will go into standby mode. This is obviously to protect the system incase it ever gets flipped down accidently and the system is on. There could be a faulty switcher inside the protector mechanism which is not working properly and the machine thinks that the screen is down when in fact it is open!
Switch off the entire projector at the mains and open and close the screen a few time manually. If you feel comfortable doing so try and force the screen up a little bit past its stopping point when it is supposed to be fully open. Be careful and don't break it. Now keeping it open plug it back in a see if that works and don't touch the protector ever again! If it doesn't try opening and closing a few more times to try and release the triggering button that is inside the projector screen.
I had the same problem and that worked for me.
Sep 27, 2007 | Sanyo PLV-Z2 Multimedia Projector
Macromedia Flash MX Logo
159 people viewed this question
Top Macromedia Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Tony
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
