Question about GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in won't turn on
Used a voltmeter to check that the unit is getting power. It is.
Checked to see if motor was getting any power and it wasn't.
No matter what setting I set the dial to no power gets to the motor.Nor does it try to take in water.
  • rogus Sep 02, 2008
    The metal switch that the door lever pushes on to start the dishwasher was worn. Repaired it. now works fine.
  • 1,543 Answers
Take phillips screws out to seperate door and check door latch switch(es). Also inspect wires as they pass into door for broken wire, and check the wire nut connections where power enters dishwasher. (Hold a wire nut and tug on each wire to make sure none are loose.)
Posted on Sep 01, 2008
Dishwasher won't fill with water
Check the power supply to the water pump through a pocket electrical line tester or volt meter.
Poer reaches and the pump mot rotating, check the capacitor associated with the motor.
May 27, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus wont start
Looks like you need to replace the timer/cycle panel on your appliance.
Try first unplugging machine for 20 minutes, to see if this reset can fix the problem.
Aug 28, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Ge Triton will not drain.
there is a small float switch it could be internal in the pump,, you will need toget the numbers off the pump and check them with a referance guide on the make of the pump not the unit it is in,, get the serial number also
Jun 17, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Built-In Dishwasher
This would be the motor that spins the dish washing unit in the bottom. The noise you hear might mean that the motor will need to be replaced.
Sep 17, 2008 | GE Nautilus 24" Built-in Dishwasher
Motor
The only reasons to replace a pump motor are very loud motor or leaking water from the seal of the pump / motor assembly. The motor comes as the pump / motor assembly, and is not real cheap and not particularly easy to replace, so you may want to consider cost of replacing the entire unit. Appliance repair locations can order for you, or you can order directly from GE over the phone. (GE answer center 800-626-2000) Make sure you have complete model number, located on the sticker on the left side of the tub just inside the door.
Sep 01, 2008 | GE Nautilus 24" Built-in Dishwasher
Nautilius not running
drain motor doesn't work, yo cn hear a little noise but maybe to hot, th motor doesn't turn.
Jun 29, 2008 | GE Nautilus 24" Built-in Dishwasher
Dish washer has no water.
Check the faucet first, turn off the faucet, disconnect the dishwasher copper hose, re-open the faucet and check you faucet see if there is water come out, sometimes there is a small stone or sand block the faucet. Good luck, hope this can help, if not we check the others.
Jun 16, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 4800 Dishwasher/Shuts off/ No water draining out
It may be the motor start capacitor or the motor or the wiring to it. Some units have a built-in switch that shuts the unit off if the motor doesn't start turning after a short interval. However, if it drains it usually means the motor runs enough to pump it out. These units usually stop draining when the fill switch opens at the lower level.
Nov 29, 2007 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
180 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
