Question about Conair DPP1500 Iron
Conair Dpp1500 wont heat up
There is power to the iron as the heat lights are on but no heat is generated.
2 Suggested Answers
  • 48486 Answers
SOURCE: CAN I CLEAN FLAT IRON?
try running distilled white vinegar thru it works on coffee pots
Posted on Mar 10, 2015
Mar 10, 2015 | Conair Irons
Flat Iron is not heating up
There is no fuse. If you connected it to 220 which is common power in a lot of countries, then you ruined the heating element. time for a new iron.
Feb 21, 2014 | Conair BABINKW2091 White Babyliss Pro 1...
Hose
Either jammed up with limescale or the heating element is faulty. contact Conair to confirm
Feb 09, 2014 | Conair GS10RHR Deluxe Fabric Steamer
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
My conair deep waver wont heat up
check your plug and wire connection to iron.
Apr 26, 2012 | Irons
Moded cs327 wont turn on any more
FIRST CHECK PLUG FUSE HAS NOT BLOWN , THEN CHECK ELECTRICAL WIRE FOR ANY BURNS OR BREAKS.
Oct 27, 2009 | Conair Infiniti Instant Heat Ceramic Hair...
Hair straighner .
Does not seam to "light up" ?
Light goes on ??
Not heating - but the light on ??
If so - the heating element has failed..
Time for a new one I am afraid ;o(
Aug 20, 2009 | Conair Professional Ceramic Hair...
Iron Randomly turns off
I know in this economy, fixing a small appliance is always something to look at before buying a new one, but in this case, that is what I am going to suggest. An iron is an appliance that has the potential to burn your house down when it is in GOOD working order. It sounds like there is either a bad component, or there is an internal short. Either way, I would be safe and get a new one.
Hope this helps,
Chad
Nov 09, 2008 | Conair DPP1500 Iron
Hi i have an edbs920 steam generator iron, my problem is that it will dry iron but wont steam up anymore, after turning the system on the power indicator light should turn from the flashing orange pre...
it can be that one of the thermostats controlling the water flow pump into the steam generator has become open circuit, caution is advised as this can potentially overheat the steam generator for there being lack of water, depending on your system design...i could be wrong just a guess !
Apr 30, 2008 | Euro-Pro Steam Generator EP8001 Iron
Conair steam cleaner sc20 - plugged in, pushed button, no steam
If you need instructions go to www.HandBookLive.com. There are videos for GS4 and GS10 under Appliances category. It says that steam is produced in about 5-6 minutes after you turn power on. Also there is a low water indicator light on GS10 that kills power to teh unit if the water level is low. Maybe that's the problem... Not sure if sc20 is similar
Apr 15, 2008 | Conair Compact Garment Steamer Iron
Conair DPP1500 Iron Logo
27 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
