Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water & ice
Ice and water spout nothing comes out, ice maker works find
  • pradip1976 Aug 28, 2008
    I have sub zero referigerator. Water and ice will not come. If I disconnect referigerator from Power supply, water comes for a second, something clicks and water stops coming. Supply line and water presuure is fine.
    How do I trouble shoot this?
  • 74 Answers
If it is both ice and water not operating then it could be the connector at the bottom of the door , the door light switch inside the freezer as this acts as an interlock or the micro switch that is operated when you insert your glass.
Posted on Aug 28, 2008
I have water frozen where the ice comes out of the ice-maker. This prevents ice from being made.
Your water valve is dripping like a leaky faucet. This forms a chunk of ice in the fill spout. Change the water valve and thaw out the fill spout and it should start going again.
Aug 21, 2010 | Whirlpool Refrigerators
Need info on how to hook up ice maker lines
OK the ice maker is the boss. It calls for water. Nothing else in the ice box controls the ice maker water but the ice maker itself. How? Fancier models use capacitance of ice mold to correctly fill the ice mold. On board intel monitors the temp of the ice mold by sending power through it and checking for differences in capacitance in the mold. When it hits the sweet spot it monitors the temp till it temps inside the mold determine ice is there and kicks in the harvest cycle. Older styles simply put a measured amount of water into the ice mold at the end of each harvest cycle. You gotta first run a water line to the water valve and then run a line from the water valve up to the Ice Maker fill spout behind the ice box. Nothing to it.
May 02, 2010 | Refrigerators
There seems to be ice stuck in the little slide to
the best way to defrost this is use a blow dryer in the comparment and th a towel or shop vac to soak up the water
Sep 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water isn't coming out of the spout on the ice maker. The ice is working, just not the water.
Sounds like you have a bad water valve. Look and see it the spout where the water comes out to fill your icemaker has ice in it. If so, you have a seeping water valve.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water not getting to ice tray
Sherman usually (not always) the problem is a frozen delivery spout coming in back of the freezer. look where your ice maker and on the back wall and up behind that you will see the delivery spout area. The water valve may be bad or not opening also but it most likely has 2 solenoids 1 for water in the door and 1 for the ice maker. If you have checked and have the ability turn off the water and reverse the water inlet lines on the water valve. This is just to make sure the water passage is open. Hit the cold water cupplunger then look and see if you have water that cam into the ice maker if not your problem is in the valve or the line to the ice maker. Next hit the same plunger with the water line disconnected if you have water then your problem is in the freezer delivery and needs defrosting and cleaning if its a plastic spout it probably has lime covering it inside and freezes over or the water valve is leaking by a little and refreezing. with the water line off yuo will quickly know if its leaking by. and cover with a towel to prevent a mess if it sprays out when you try the plunger. If it still dosnt work try to check the coil on the water valve both coils should read about the same. If after all this works and you have water everyplace (thats why I said use the towel) the problem is in the ice maker circut. Either it is the main power, the ice maker motor its self, or or most likely its the fill valve switch.In any case if you purchase a new replacement Ice amker head all this will be new.OR Either replace the switch if it checks open or if its loose or there are broken parts. It requires a cam to open and close the switch so it only opens for about 5 to 15 seconds. .Hope this helps you let me know if I need to tell you more. Rate me accordingly please and Good luck.
Mar 12, 2009 | Refrigerators
My ice maker doesn't make ice but i have water in the door
Your machine has a dual water valve. The ice maker side coil is dead most likely. You can confirm this by loading your ice maker with a glass of water. If it chunks out a batch but fails to make anymore then that is a sure sign of a bad water valve solenoid.
Mar 08, 2009 | Refrigerators
Refridgerated water spout suddenly stopped producing water
Have you changed the water filter. It should be located in the front loer grille of the refrigerator.
Jan 10, 2009 | Refrigerators
Water spout to ice maker frozen
defrost ice maker fill tube and replace duel water valve valve for i/m is sepping water
Dec 14, 2008 | GE Profile Arctica Stainless Steel Top...
Frigidare side by side Gallery fridge
sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Oct 10, 2007 | Frigidaire GLRS237ZA Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
47 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
