Question about Nokia E50
Lock code Hi .. My mobile was not working properly so I did a format .. But I didn't know that it will ask for the lock code which I don't know .. Now The format is done but my mobile is locked on the lock code screen .. I can only recieve calls and nothing more .. How can I unlock it ..
  • Nokia Master
  • 1,800 Answers
Its ok give it 12345
plz do rate this post
Posted on Sep 24, 2008
No it not accept
Posted on Feb 02, 2011
Nokia 6600, Imei no. 359365004705343. Two viruses are in my mobile.so i will reset it. but i don't have lock code. Send me the solution.
best result : just download unlockme.sis application & install it on your nokia 6600 and open it after 10 to 15 minute lock code appear on display .
to remove virus you have to formatt your phone , frist switch of your phone & start the device by pressing combination key green key ,' * ' , ' 3 ' , ' power on/off switch ' you will show formatting on display , make sure that procees remove contacts messages etc. so please back up your data before formatting
Jul 19, 2012 | Nokia 6600
Videocon v1575 qruz2 phone lock code
44162121413064 try this one, will definetely work for videcon mobiles
Jun 08, 2012 | Cell Phones
Unlock pantench cellphone
hi,
here you didn't mention about the mobile model and to which network your mobile got locked?..k you can unlock your mobile using unlock codes through network providers or through online providers.according to me online providers is better to unlock your mobile.don't go for free because sometimes the code generated by them may goes wrong.here i know one good provider namely prounlocking.com where i had bought the code for my mobile.here they are providing code at affordable prices and just you need to give your mobile IMEI number to them and they'll provide you code with simple step by step instructions.hope it helps you.
Nov 09, 2011 | Cell Phones
I don't know the samsung sim lock code.... i need the code to unlock my phone.
Hi you can use codes to unlock the mobile .to get the unlock codes visit here
mobileunlocksolutions
Here they ask the following details before rendering the unlock codes they are
1. Mobile model
2. Country from where you brought the mobile
3. Provider to which the mobile is locked
4. Imei number of the mobile
Finally they will send you the unlock codes .once
you entered the code in your mobile as for the instruction
given by them .your mobile get unlocked and it accepts any network sim.
Aug 18, 2011 | Samsung B3410 Cell Phone
Just installed this lock - second one we tried (first didn't close all the way) Backlite is not working. did we oversee something?
I have reviewed the on-line installation instructions for this lock, and it requires attention to detail to properly install.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
For instance, the first one may have not closed all the way if your door has a 2 3/4" setback instead of 2 3/8", and you did not extend the bolt and adjust the latch as shown in figure 2 of Step 1.
Also, if you don't run the door handling routine properly as in Section 8, the lock won't work properly.
But I believe that you are past that learning curve after the second installation, and I don't know why the backlight won't work on your new lock.
I didn't see any option to enable/disable it in the instructions. So my suggestion: If the lock is otherwise working properly such that the backlighting is the only problem, I'd give a call to the Customer Service number 1-800-677-5625 and discuss it with them. They will let you know if and what the problem is, and a new lock is certainly under warranty!
Jul 23, 2011 | Kwikset 907 90715 Satin Nickel SmartCode...
Unlock network code e63 optus
You can get the Unlock code from service provider....
Jul 19, 2011 | Nokia E63 Cell Phone
I NEED A PUK CODE BECAUSE I HAVE NO OTHER PHONE AROUND AT THE MOMENT
Hi, What your problem was? PUK or Phone security code... Actually, PUK refers on the simcard that you use... To unblock the PUK lock code, you can ask your telco services to get your PUK code... If you referring to phone security code, your can sent your phone for format at mobile services... For default nokia code, you can use "12345" if you didn't set any code otherwise you should go to mobile services to reset for you Other phone you can try "00000"... I hope it work... :)
Jul 01, 2011 | Cell Phones
I have forgotten my lock code of Nokia 6630
My brother had put an lock code on my 6630 mobile, but now he has forgot the password. i want to format my mobile, i tried it by *#7370# code, but it asked the lock code and i don't know the code, can any body please help me regarding my problem.
Aug 16, 2009 | Nokia 6630 Cellular Phone
Reg restriction code
To enter the code to the phone (switch on without SIM card). Input the Code in the phone as follows:
#pw+??????????????+1#
#pw+??????????????+2#
#pw+??????????????+3#
#pw+??????????????+4#
#pw+??????????????+5#
#pw+??????????????+6#
#pw+??????????????+7#
Here: ?????????????? You should enter generated code.
_-_ first code in the end of the string must be added + 1#
_-_ code number 7 in the end of the string must be added + 7#
If You have proper software and You know on which lock, phone
is closed just simply enter proper CODE.
If YOU DONT KNOW - which lock is closed do the following:
1. Enter the first code, if it’s the wrong code - WAIT 30 seconds!!! And then:
2. Enter the code number seven this will open all locks.
How to get 'p' 'w' '+' signs?
Press
* several times on keyboard of phone...
ATTENTION!!!
If the codes don’t work after entering 5 codes You will lock the ‘CODE UNLOCK FUNCTION’ and it will be possible to unlock the phone only by using a cable/device.
Here are your codes:
IMEI: 358648013665611
Network: 23430000
#pw+229125355703024+1#
#pw+123974050131176+2#
#pw+737950263501053+3#
#pw+143914670171415+4#
#pw+413317243165511+5#
#pw+893271725144273+6#
#pw+125874454360171+7#
Feb 29, 2008 | Nokia 6300 Cellular Phone
Nokia E50 Logo
116 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
