Question about Speed Queen CGS68AWF Gas Dryer
Speed queen gas dryer uses pay cards
Our complex uses speed queeen dryers that use a prepaid card 9 sort of pay at the pump) thwhen drying the heat comes on for one minute then off one minute then on one minute and so on instead of coming on for three minutes at a time. the result being that clothes are not getting dry. we have about 5 dryerswiththe same pproblem. we have replaced the cpoils but it doent fix the problem. Is this a programming issue or any advice?
  • 550 Answers
Overheating and shutting off,
usually is a blockage in the venting
check the exhaust lines to the wall vent/exits, there may be lint build up in those dryers that are shutting off
Posted on Aug 28, 2008
Speed queen gas dryer, at least 20 yrs old: the igniter begins to glow, then fades out, there doesn't seem to be gas ignition as the chlothes are not drying...so?
Sounds like you may need some coils. Mine would heat up for a minute then go out. The coils were my problem. They are located close to the igniter. They come 2 in a pack and you have to replace both. Probably $20
Oct 07, 2017 | Speed Queen Dryers
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
Problem is blowing cold air not heating up,its a speed queen dryer on bottle gas ?.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 14, 2011 | Speed Queen Dryers
My speed queen model# AES68AWF doesnt heat what could it be?
heatman101
Jul 16, 2011 | Speed Queen AES68AWF Dryer
My speed queen dryer model #AES68AWF doesnt heat what could it be?
heatman101';
Jul 16, 2011 | Speed Queen AES68AWF Gas Dryers
Speed Queen gas dryer model #AGM499W. Replaced the igniter but did not fix the problem. Dryer will not heat.
burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
Sep 02, 2010 | Speed Queen AGS28AWF Gas Dryer
My speed queen AGS17AWF isn't getting any heat, a friend said that it could be the ignitor or fuse but I cannot find the fuse on diagrams and I don't know how to get to it based on the diagrams, any help...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 05, 2010 | Speed Queen AGS17AWF Gas Dryer
Dryer does not heat. Electric ignition does not "spark" lighting
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
Speed Queen CGS68AWF Gas Dryer Logo
88 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
