Question about Canon imageCLASS D761 Copier
Platen is open message, What is the platen? - Canon imageCLASS D761 Copier
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Platen is usually referred to as the Copy glass ( Platen Glass) this is where you lift the top to put it onto the glass to make a copy.
Never heard of this message , was it serviced? usually the techs open it to clean the Optics (mirrors) inside.There should be a metal plate with 2-4 screws that hold it.
Posted on Aug 28, 2008
Solution to platen is open problem
this is how to open the platen.
usually there is paper jam under the platen or cartridge (black)
Feb 21, 2013 | Canon imageCLASS D761 Copier
PRINTER SHOWN PLATEN CAL CABLE IN T6306
if your platen calibration is not done.
1 Resat All Platen Connection of cabal
2 Replace Logic Card
3 Check Platen Moving proper
4 Than Check Sensor And Platen Aliment
5 Than replace Platen Sensor
6 Please Check Platen Motor
Regards
yogendra Sharma
Nov 27, 2010 | Tally 6312 Matrix Printer
How do i clean underside of platen glass Canon MP160
for mp160, flip the cover open, the one that you open to gain access to the ink cartridge. you will see two screws at the underside of the scanner base. unscrew both. gently pull down at the front control panel and pop up the front lip of the plastic that holds the platen glass. then, at the back of the printer, adjacent to the paper loading tray, just below the platen glass cover, you will see two clip like stuff. remove the tray by pulling it upwards vigorously but firmly. then, get a flat screw driver to pry these up to release the lock. then, facing the printer, gently pull the whole of the platen glass, together with its plastic frame, towards you. do this while gently rocking the platen glass up and down, or left and right. to return the platen glass, reverse the process.
Jan 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Every i try to print i get an error message 53 stating the ink cartridge is not installed properly or not compatible with the printer
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Nov 30, 2009 | Canon PIXMA iP1600 Printer
Platen Cover is open
if you open the platen cover, on the rear middle there is a little opening, that is where a little actuator sensor sit, and it is sticking... take a little flat screw driver and kinda flicker it.... that should take care of your problem
Jun 20, 2009 | Panasonic PanaFax DF-1100 Laser Printer
Canon image class 620
the platen moves to the left side ,for changing the cartridge,move the platen to the right.if you have a flat cable broken rear of the machine.
Dec 27, 2008 | Canon imageCLASS D761 Copier
057 close platen error message
Its located in the adjustment section of the platen control or in the platen itself.
Lexmark may still be supporting this model printer.
Dec 02, 2008 | IBM 6400 Matrix Printer
Platen opeo error
CLEAN THE PLATEN SENSOR IF NOT SOLVED CHANGED THE PLATEN SENSOR.
Sep 15, 2008 | Tally T6218 Matrix Printer
Error message
Hi there
4.Close The Cover
Jun 30, 2008 | Canon PIXMA iP1600 Printer
Canon imageCLASS D761 Copier Logo
158 people viewed this question
old marine
old marine
