Hobart 42 in. AM14C-154 Free-standing Dishwasher
Problem for Hobart 42 in. AM14C-154 Free-standing Dishwasher
Pressure release keeps draining hot water
By ctrimble785 on Aug 28, 2008
I have a hobart 14c-model 32615 commercial dishwasher. we have two drain lines. when the washer isn't being used, the 1/2 inch line drains every 5 minutes or so. Why?
Thanks
Solution #1
posted on Sep 12, 2009
Not Rated)
Rob-OES
Rank: Guide
Rating: 100%, 3 votes
The 1/2" drain line you are referring to is probably the 3/4" line from the booster heater located to the left of the pump motor. The temperature/pressure relief valve is bad.
The booster heater could be overheating (bad thermostat), or you may not have an expansion tank on your building hot water system. The heating and explanding water in the booster has no where to expand to, causing a pressure spike high enough to pop the valve.
First, change the valve. I use a heavier-duty Watts XL40 valve, I purchase them from International Commercial Supply or Johnstone. Even if there is a cause for them to leak, once they start leaking they need to be replaced.
Once the new valve is in, power up and test the unit. Power up and fill the unit, then let the booster recover until it cycles off. Run a cycle, and check your rinse temperature. I like to see 190-192 degrees. If it went higher than 195 I'd turn the thermostat down. If it didn't shut off at all, and the relief blew, time to replace the thermostats in the booster heater.
Was this helpful?
Yes
No
Solution #2
posted on Sep 18, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
change the company
Popular Solutions for Hobart 42 in. AM14C-154
Questions and Unsolved Problems for Hobart 42 in. AM14C-154
Do you recommend Hobart 42 in. AM14C-154 Free-standing Dishwasher?
Answer
Answer
My global 300 wont start, it original started and rinsed but then stopped and wouldnt restart... (More)
Answer
we would like someone to come out and service our washer. It is on a boat in Newport Harbor
Answer
amx-r q keeps filling and dosnt seem to come to temp, and few other problems please help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hobart 42 in. AM14C-154...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
