Question about Canon FAXPHONE L80 Laser
KEEP SHOWING WRONG PAPER SIZE
I AM SURE IT IS ON THE CORRECT PAPER SIZE BUT SAME PROBLEM
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
There is no previous post for your problem please restate.
Are you trying to Rx a fax and it's showing wrong size? do you have a manual? I can give you a link for a free one.
Posted on Aug 28, 2008
Print out of the "fax parameters". then check "rec.paper size" is setting correct.
Posted on Dec 16, 2008
HpC309g printer keeps gaming -reason Wrong size paper but it is not
The document you are trying to print is set to a different paper size than the printer has. It is looking for paper of the correct size to be installed so it can print the document.
Aug 28, 2014 | HP Photosmart C309g Premium All-in-one...
I am unavailable to connect via network
Most likely paper size is wrong. Push the cont. button on printer.
Adjust paper size on trays correctly. Make sure document size is same as paper size esp for PDF and postscript documents
Jul 08, 2014 | Edimax Computers & Internet
Paper keeps jamming
I would look to see if the paper tray's Dials are set to the correct paper size as the paper in the paper tray.. LTR size set to LTR or LTR-R set to LTR-R if the dial is set to the wrong size the copier will jam all the time. Due to a timing issue, the copier thinks it has one size, but actually is try to make a copy on different size... Good Luck
Jun 08, 2012 | Canon imageRunner C3100N Copier
Lexmark T632 has 2 (ea) 500 sheet drawers, but once the paper runs out in Drawer 1 it will not automatically pull from Drawer 2. Please advise how to fix this problem.
go to Menu, reports, and print out the top report.
This will show you what the printer sees as the default tray, and what paper size and type are set for each tray.
If you have plain paper in each tray, make sure that the setting page also shows that each tray is set to letter, plain.
This printer sets the tray type automatically, based on the way the tray is set. There are little tabs on the side of the tray that change as you change the size of the paper with the paper guides.
If the paper guide is set even one click off, this can cause the printer to read the paper size incorrectly, and thus will not change to the next tray. ( if it thinks that tray 2 is A4 paper, but you are printing letter, it will not change to tray 2).
if the trays ARE set correctly, but the printer is still reading it wrong, then there could be something wrong with the sensor ( metal fingers and switch ) inside the printer.
Feb 15, 2011 | Lexmark T632 Laser Printer
Our Canon imageRUNNER 2270 is copy/printing sidways instead of normal. what happened?
I would look to make sure the paper tray's are set correctly in the paper trays... There is a knob that moves at will.... just kidding... Make sure that when you press on the diplay for paper size's, that if it shows LTR make sure the paper is in the tray going the short way.. LTR or you may have the paper tray set for LTR-R and you have the paper in the tray as LTR. I believe that the paper trays are set wrong. You may have figured it out already.. Good Luck
Nov 29, 2010 | Canon imageRUNNER 2270 Copier
Papper gets stuck while printing,shows on the scren paper size,41.3 unexpected paper size.
Make sure the paper stops in the paper tray are set to the correct paper size. If one of them is not in the correct location the printer thinks it is a different size of paper. Also make sure the selector on the tray is set to the correct size. If all these are good you should reset all the settings to default.
Mar 08, 2010 | HP LaserJet 4100 Printer
Wrong size paper jams
Take a trip into the Printer Driver for this printer and then select "Printer Properties"
Review the settings for the paper setup. Also, from your application, make sure you have "Letter" set as the desired page size.
Finally, if your printer has a "Paper Menu" go into that and set tray size to Letter.
Don
Oct 21, 2009 | Ricoh Aficio AP610N Laser Printer
Printer is saying the wrong size paper , wont print... Is that a setting in printer or is it software
depends on the printer. check the printer menus. check the printer trays. if they are not set correctly, they will show as wrong paper size.
Aug 06, 2009 | Office Equipment & Supplies
I keep getting the message to align the cartridges. It prints 2 lines then says it's a paper mismatch
make sure that the the paper size set on the paper tray is correct. try to move the paper guides to another size and move it back to the correct size
Jul 21, 2009 | HP PSC 2210 All-In-One InkJet Printer
Canon FAXPHONE L80 Laser Logo
333 people viewed this question
old marine
old marine
