Question about Cameras
Javelina TM audit 760/1150 rear view camera in my motor home
Glass cover broken and pressure was lost so camera does not work
3 Suggested Answers
  • 848 Answers
SOURCE: javelina camera glass cover broken
provide in more detail about your problem ..........
Posted on Aug 28, 2008
VOTIT
  • 2071 Answers
Just click below for free estimate;
http://www.advancecamera.com/repair/
hope this may help;
Regards,
VOTIT
How do i remove a rear window
hard top or convertible.?
I guess at hard.
Not side rear. or doors., but rear rear. as in rear view.
rear window. glass out? why not say why so can see JOB ? at hand.
eg: my rear view glass is broken.?
is covered in the FSM, (like all cars made)
the factory service manual. or alldata.com (clone) log in read.
ok ill past the FSM words here.
Stationary Windows Stationary glass is removed and installed using the same procedure as the windshield. Refer to Windshield Glass Removal and Installation. (first hit ,btw)
https://www.youtube.com/watch?v=5dp2VVvPlXc
ever seen a front windshield changed out, sure.
same
best solution is......
Call the same company to come out and point to rear .?
they sell a special tool to get out a window.
it has 2 , "T" handles and rod saw. to cut out the glue/caulk.
the glue comes out more easy on a hot day.
its not really glass, it's an occupant containing device, today.
the best caulk is.
3M 08693 Auto Glass Urethane Windshield Adhesive Cartridge
how is my guess.... on car, and glass and reasons.
Dec 04, 2014 | 1992 Suzuki Swift
Javelina camera glass cover broken which dspresserized the camera
Aug 28, 2008 | Cameras
Why porsche cayenne 2009 rear view camera is not opening cover is stuck
As with most vehicles the rear window and tailgate gets covered in dirt, salt etc. which is thrown up from the rear wheels and by the wind swirling out and up. The cover on the camera needs cleaning and lubricated regularly. I washed the cover, dried it with high pressure air and lubricated it with a silicone spray. When I first did it, there was a fine dirt in the crevices that needed to be dug out. I used a small blade to scrap it out, then lubricated it. Good luck.
Aug 16, 2014 | 2009 Porsche Cayenne
Glass of the cover is broken
Sorry, you can't fix that. You need to contact the manufacturer.
Mar 23, 2014 | Gordon Ramsay 6 qt. Nonstick Low Pressure...
I CANT SEE MY SCREEN ON MY PHONE
What kind of phone?
It will help to put your model here.
With out the model, we are somewhat lost.
General ideas....
Make sure the battery is charged.
Go to the menu options and make sure the LCD is on, if there is an option to shut off the lcd.
The screen LCD may be broken or cracked.
One way to test for a cracked or broken screen is to put it in the sunlight with the power off. Slowly turn the phone from side to side and up and down looking at the screen. If it is broken or cracked you may see a difference in coloring of the surface under the glass or plastic cover.
If the phone works at all, and if you have a camera on it. take a picture, then down load it to your computer to view it. If the picture takes okay, then your lcd is either broken or cracked or disconnected within the phone, or some cable could be loose as well.
Anyway, hope it works.
Jul 10, 2011 | Cameras
How to replace a broken wing mirror on a Volvo S40 1980 model
Power Dr Mirrors Diagnosis & Testing
Removal & Installation
Motor
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    Disconnect the negative battery cable. The mirror inside cover trim The door panel The electrical connector to mirror motor The nut attaching mirror assembly to door frame The outside rear view mirror
    Fig. Removing cover trim and nut
    Fig. Removing mirrored glass from assembly
  3. Remove the mirror glass:
    1. Fold the mirror glass forwards and inwards as illustrated.
    2. Grasp and pull the mirror glass lengthways until it releases.
    3. Work the glass out.
  4. Remove electric motor:
    1. Remove the 3 screws from behind the mirrored glass.
    2. Separate the connectors
      NOTE Remember the positions of the connectors.
    3. Remove the mirror motor.
      Fig. Removing connectors and screws holding mirror motor
To install:
  1. Install or connect the following:
    The electric motor The electrical connections The 3 screws that go behind the mirror Install the terminal pins Fold out the mirror mounting on the motor Hook the mirror glass into the inner mounting Press the mirror glass into place. Place mirror in position in door
    Fig. Reattaching mirror and electric motor connectors
  2. Install or connect the following:
    The nut attaching mirror assembly to door frame The connector The door panel The mirror inside cover trim The negative battery cable
Oct 23, 2010 | 2000 Volvo S40
Need a diagram for installing a drivers side electric power mirror on a 1995 mercury villager van
here's 1996, all I have. Please rate.
Mirror, Power — Outside Rear View NOTE: This procedure applies to both RH and LH power outside rear view mirrors.
Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws and the outside rear view mirror mounting hole cover (17K709) from the front door (20124).
  1. Remove the wire clip.
  1. Disconnect the power outside rear view mirror electrical connector.
  1. Remove the three power outside rear view mirror bolts and the power outside rear view mirror.
Installation
To install, reverse the removal procedure. Tighten the three power outside rear view mirror bolts to 3-4 Nm (27-35 lb-in). Glass, Outside Mirror
Refer to the glass replacement procedures in Manual Mirror for power outside rear view mirror glass (17K707) Trim Cover
Removal
  1. Remove the front door trim panel. Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws.
    Remove the outside rear view mirror mounting hole cover.
Installation
To install, reverse the removal procedure. Mirror Control
Removal
  1. Use a small flat-blade screwdriver to pry the power outside rear view mirror control switch from the instrument panel (04320).
May 13, 2010 | 1995 Mercury Villager
Is it possible to fix the view screen if just the glass (not the ldc) is broken? Fuji FinePix Z5fd
There is a plastic cover over the LCD. Is only the cover broken? The plastic cover is easily replaceable.
But there is also a sheet of glas over the LCD. This is a part of the LCD assy and cannot be replaced without replacing the entire LCD.
Feb 08, 2010 | Fuji FinePix Z5fd Digital Camera
Passenger side mirroe is broken from the neck...
is it just the glass that broke?
Exterior Mirror Glass Removal
  1. Position the inner edge or the exterior rear view mirror glass to its maximum travel.
  1. s1h~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Place a shop towel between the exterior rear view mirror glass and the hand to avoid personal injury in the instance of glass breakage.
    Grasp the outboard edge of the exterior rear view mirror glass and pull outward.
  1. Remove the exterior rear view mirror glass.
    • If equipped, disconnect the heated rear view mirror glass electrical connectors.
Installation
  1. If equipped, connect the heated rear view mirror glass electrical connectors.
  1. NOTE: An audible click will be heard during installation.
    Press firmly in the center of the exterior rear view mirror glass until it snaps onto the exterior rear view mirror motor.
Jul 01, 2009 | 2001 Ford Taurus
Cameras Logo
155 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
