Question about HP iPAQ RX3115 Pocket PC
IPAQ rx3115 would not bypass the screen aligning
After a hard reset the device is not able to align its screen. The target cursor seems to be going in a loop and the aligning never ends. I tried the soft reset, the hard reset - nothing works. My screen doesn't have a screen protector on it or any visible dents, scratches or other defects. I've had this device for only two weeks. Any advise?
    Master:
  • 450 Answers
I experienced the same problem with my rx3115 after having it for 3 days. It is working again, fortunately. I removed the battery from the device and left it alone for 24 hours. I then reinstalled the battery and connected the charger. When it powered up, it went through the initialization process in the same way that it did when I first used it. I hope this helps you out with your iPAQ.
Posted on Sep 08, 2005
SOURCE:
I cannot get past the align screen page is there a way of bypassing it?
If it just keeps asking you to calibrate, then that means the touch screen is faulty.
Oct 24, 2009 | HP iPAQ RZ1710 Pocket PC
Align screen on IPAQ
Tap the target firmly and accurately at each location on the screen.The target will continue to move until the screen is aligned,
pls help.what can i do.
Jul 23, 2009 | Compaq iPAQ H3955 Pocket PC
When i do hard reset hx2490b screen calibration does not appear
Try using your finger to calibrate the screen at first. (If you have difficult to navigate to the alignment screen use the stylus & keyboard to feel out your way) when calibrated to an accepable degree use the stylus to calibrate the sreen, if the target doesn't respond to stylus at any specific piont use your finger. Continue this process till u get it aligned as best as possible. I suspect this problem is caused by specific points on the screen going bad.
Feb 24, 2009 | HP iPAQ HX2490 Pocket PC
Ipaq rx-3115 stops at align screen after reset
This happened to me and i got so mad that i broke the screen. But that was a good idea because then i got a new screen and now it works fine. Just get another screen and it should work fine. or you can just get the digitizer part and swap out your LCD parts.
Feb 17, 2009 | HP iPAQ RX3115 Pocket PC
Ipaq rx-3115 stops at align screet after reset
Sounds like u need a replacement LCD
Easily found on ebay
Replacement screens usually come with instructions.
Please note u will need a hollow t8 or t9 tool to open the ipaq case.
IPAQ rx3115 continuously, "screen alignment",
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3115 (or RX3715) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
Feb 26, 2008 | HP iPAQ RX3115 Pocket PC
Ipaq rx3115 frozen
Red LED light means a major problem at the charging of the battery.
You have several options to repair it:
1. Leave several hours the PDA with not battery and unplugged from the AC power adapter, then put the battery and leave charging it.
It's more likely that the red light will appears again, but leave plugged it. Sometimes will start charging and blinking with orange color after 30 minutes or so. After that, it will work normally.
2. Use other good working battery to test it.
3. If the above two steps fail, then there is a good chance that the mainboard has a problem, and needs to be fixed or replaced.
Best regards,
Jan 25, 2008 | HP iPAQ RX3115 Pocket PC
Ipaq rx3115
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
Best regards,
HP rx3115 hard reset
Had the same problem with my hp rx3115 . Worked fine, then the next day dead. power button, lower buttons, or outter reset button didn't work to turn it on. Okay so, i thought it just needed to recharge. Used computer cable for active synchronizing that also recharges, still dead. Then cable just for recharging. Finally comes on. Charged it all the way up, synchronized it, unplugged it, few minutes......dead. The battery is no good.
Nov 16, 2007 | HP iPAQ RX3115 Pocket PC
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
HP iPAQ RX3115 Pocket PC Logo
221 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
