SOURCE: dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
SOURCE: It's 102F outside and the Danby dpac120068 air
I have heard other people do this I am not sure
SOURCE: Air intake via hose & window or intake from room only?
Hello artrey3 The answer is yes, BUT the unit will be exausting room/basement air outside ruining any efficency the unit is rated for.Also you will need makeup/fresh air in the basement. The unit exausting air can put the basement in a vacuum/negitive pressure pulling in air from the chimney!
SOURCE: Relative Humidity reading is always
I will advice you first make sure the humidistat isn't set too high by adjusting it to
the lowest humidity setting and running it again. Next, test the
dehumidifier by placing it in a closed bathroom with a hot shower
running. If you don't see water collecting in the unit after several
minutes, turn the unit off and clean all dehumidifier filters and
coils. If, after adjusting the settings and cleaning the unit, you
still don't see water collecting, you may have a refrigeration issue. In this case, you will need to get a technician to help check because it is beyond what you can do.
SOURCE: looking for an online manual
Karen, the following link is to the Owner's Manual for your Model Danby AC. You can download and print it for future reference. http://www.danby.com/cms/uploads/products/en_manual/dpac7099_web.pdf
I hope this helps you and thanks for choosing FixYa.
