Question about RCA P61310 TV
New direct tv dish not recongized
The new hd dish from direct tv is not recongized and teh new channels are not able to be viewed. is the a fix or sofeware upgrade?
Did you also get a new sat Box? you will need this with the new 5 lb dish
Posted on Sep 26, 2008
I have extra view but my parents are still controling my chanels
That is a very broad question. I need to know things like is it the TV itself or is it the cable channels i.e. Comcast direct TV dish network?
May 30, 2014 | Televison & Video
Black screen
Possible causes
  • Your TV is not receiving or displaying the signal from your DIRECTV® Receiver.
  • Your receiver has correct guide information, but is not processing video correctly.
  • You are viewing a channel where an upcoming sporting or special event is scheduled or has recently ended.
Solutions
  • Turn TV off and on.
  • Make sure light on front panel of receiver is lit.
  • Press the "TV/DSS" button on the remote control or front panel of the receiver (not all receivers have this option).
  • Reset the receiver by unplugging the power cord for 15 seconds.
  • Check all cable connections between the dish, receiver and TV.
If the picture is black, but the program title and description display in a banner the top of the screen:
  • If the problem is only occurring on a few channels, check the detailed description of the program through the on–screen guide on those channels. Often, we display a blank screen with a banner before and after a high–profile event to alert customers about the event.
  • Reset the receiver by turning off and unplugging the power cord for 15 seconds.
  • Run a signal meter test to check your signal strength (press "menu" and look under "setup" or "installation").
If your signal strength is below 70 (or below 60 on HD receivers) in clear weather on transponders 1 and 2, see our troubleshooting steps for "Searching for satellite signal. Please stand by." You may see zero strength on transponders 4, 12, 18, 20, 26 and 28. This is normal in many areas. Your system manual shows how to run cables and point your dish.
Oct 24, 2007 | Toshiba 30HF66 30" TV
Trying to hook up a digital antenna but no channels coming in
You need to get a connection from a local cable or wireless service with a set top box to be connected to the input. Please check with your local operator and see if the set top box is needed for the digital feed.
Otherwise you might need a dish with the LNB to be used to the TV. Digital tuner means that the tuner is working to scan and memorising the full band width of the channels with digital processing and thus faster and crisp.
Check the details of the TV from a forum:
http://reviews.cnet.com/direct-view-tvs-crt/philips-32pt9100d-32-crt/1707-6481_7-31473699.html
Oct 22, 2011 | Philips 32PT9100D 32" TV
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
Can i hook up an old tube type tv to a new high satellite dish? i dont care if i get high def picture just want a regular picture.
Yes there is an option for ouptuting 480i signal from most hd receivers. You will need to check the specifics for the satellite dish receiver as to the channel that the TV should be on as well as how to set it to the resolution that you need. (I know some Dish receivers need channel 60 for the SD TV (coax (RF) connection) when it is TV 2 but channel 3 or 4 for TV 1.) Also check your TV so that you can use the best possible input available.
However, you may not be able to read the closed captions unless you enable them on the receiver. (Apparently, the encoding has changed.)
The manuals for some satellite company receivers are on their website. For example, Dish network manuals are here: http://www.dishnetwork.com/supportsection/manuals . Their manual for the Solo VIP 211k describes connecting the receiver to a SD TV on page 91 (page 97 in the PDF version).
I hope this helps.
(I'm not aware of any satellite system that doesn't use a set-top box. If you do not have a receiver, then the above does not apply and you may not be able to get a signal.)
Apr 13, 2011 | Televison & Video
I need to get to channel 73 to connect to Satellite Dish network, but it keeps telling me there is no channel in list ???? what do i do..Thanks
We would be happy to help with that. Some TV's are not ableto go as high as channel 73. This sounds like you're having an issue with yourTV2, this would be the TV located in a different room than your DISH Networkreceiver. Go to the main TV by the receiver, press the menu button located onthe top left of your DISH remote. Once in the main menu, press the numbers6-1-5, this will take you to the "Modulator Setup" screen. Once there we want to highlight the "Air"option located below "TV2 Out" then press the select button. TheChannel should change from 73 to 60. Change the channel of the TV you arehaving an issue with to channel 60; you should get the DISH Network programmingat that point. We hope these steps help you get that fixed. Thank you for beinga valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 16, 2010 | Haier HTF20 20" TV
Can this tv view in hd?
Unfortunately the answer to your question is 'NO'
You require a TV with either a HDMI / DVI .Component connections on it.
If you looking to purchase a New tv to be able to watch HD on then I would get a TV with HDMI ports on the back.
Hope this helped you out. Please Leave a Thumbs up it this did.
Cheers Little Dish Fitter
Oct 06, 2009 | Sharp 36R-S50 36" TV
I HAVE A SUMSUNG THAT IS HD, BUT IT'S NOT HDMI,i GET REGULAR CHANNELS, BUT WHEN I SWITH TO A HD CHANNEL, IT IS ALL SCRAMBLED? WHY?
I assume you have cable. The cable HD and digital channels are usually sent in Quadrature Amplitude Modulation (QAM). The cable companies are required to send local channels in the clear but not so for any others. Regular (basic) channels may be clear or scrambled. USA many not be but HBO will be.
So you have 1 of 2 problems: (1) your TV does not do QAM or (2) they have scrambled the channels you want to see. Questions: (1) Have tried direct Over-the-Air (OTA, ATSC) reception for your locals? (2) Can you see the HD local channels on cable? (3) Are you paying for an HD box from the cable company to have the channels decoded? If in doubt contact the cable company.
Current Samsung TVs do do QAM and OTA HD. Alternatives are Dish or Direct to get satellite with an HD receiver using HDMI or 5-cable RCA. Costs are comparable but OTA wins, hands down. -Ken
Aug 18, 2009 | Samsung Televison & Video
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
Locked Channel
try settings and the set all data to factory default or restore to factory settings, then you my start new installation. Jkahangwa
Jun 05, 2008 | JVC AV-27230 27" TV
RCA P61310 TV Logo
62 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
