Question about Everex StepNote NC1500 Notebook
Need to reinstall windows
When i try to reinstall windows it says windows cant find a hard drive. I assume i need to add the thrid party driver, where do i find this?
  • 3 more comments
  • rlarusso Aug 28, 2008
    western digital scorpio. the notebook is a va250e or stepnote.
    i dont have a recovry disk, so i am using a windows xp cd. it starts the install but the cd cant access the hard drive. I know sometimes u need a driver to insall so it can be seen
    There is a password on the bios that i didnt set. I cant get in there to see it. any thoughts on how to get around this? does it come with a factory set password?
    the battery didnt work, where are these jumpers and how do i get to them?
    yes its a laptop stepnote NC1502
  • Roberta Smith
    Roberta Smith May 11, 2010
    what is the brand and model number of the hard drive.
    Robert
    Brigadier General:
  • 5,158 Answers
Is your bios configured to use a sata drive ?
Robert
Posted on Aug 28, 2008
  • 1 more comment
  • Roberta Smith
    Roberta Smith Aug 28, 2008
    download the sata driver from western digital. put that driver on a floppy disk. when you install windows at the very beginning there is a chance to install raid ( i believe) or a sata drive by hitting F6. install the driver with the on screen instructions from there. after that you should be able to proceed to installing the operating system.
    Robert
    By the way you can reset the password by uninstalling the bios battery for about five minutes. or there is a jumper on the board.
  • Roberta Smith
    what is the model of the computer... it's not a laptop is it ?
    Robert
  • Roberta Smith
    ok ... taking the large battery out will not clear the bios password. there is an internal battery for the cmos (bios) that needs to be removed plus the main battery ... including all power to the laptop. when you have removed all power for about 10 minutes .... put it all back together. it should boot without a password.
    If you cannot access the battery. not always accessable... you will need to go ahead with downloading the driver from western digital and installing it from the floppy disk during installation of your operating system.
    Robert
I HAVE A COMPAQ ARMADA 1530DM , WHEN I TURN IT ON IT SAYS NON SYSTEM DISK OR DISK ERROR. HOW CAN I FIX THIS PROBLEM
First make sure that there is no non-boot disc in either the 3.5" or the CD drive. If those are not the problem, your hard drive has either failed or lost the Master Boot Record information. You will need a Windows Install or Upgrade CD for your computer's OS. (You may also need a 3.5" boot disc for the OS.) What OS are you using on that computer. Alternatively, some third party repair software or Partition Management software can restore the boot information if the hard drive is still viable.
Try to boot to the CD and choose repair. Go the the Command Prompt (Recovery Console). Then for XP, try the fixmbr command. You can check if there is any viable data on the hard drive by trying to change drives and then typing dir to get the directory list. Try C: (enter) dir (enter). Look for a Windows folder. (Note: some computers have a recovery partition. Don't mistake that for your Windows drive.)
If your hard drive has failed, you'll need a new drive. Then use the license on the computer and an install disc for that original license. Please note: the recovery disc if you have one often doesn't work with new hardware. You will lose any third party software that was installed by Compaq. You'll need to reinstall your own software.
I hope this helps. Please add more information about your computer for additional support. If you do not have an OS disc, search for a member of a Windows User Group in your area. They often have extra copies.
Jan 15, 2014 | Compaq Computers & Internet
WINDOWS SET UP FAILS TO LOCATE THE HARD DRIVE ACESS SEEMS TO BE DENIED
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Andrew.A
Apr 07, 2011 | Maxtor Hard Drive
I bought a third party ie seagate 160 gb sata hard disk and replaced in my laptop but windows installation disk did not find any hard disk present in the computer. how to install a third party hard disk ?
If you are installing Windows XP on a SATA hard drive, Windows installation CD does not have a SATA driver, that is why it does not detect the hard drive. please click on this link and follow my instruction to install Windows on a SATA hard drive :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Oct 31, 2010 | Seagate Barracuda 7200.10 ST3250310AS SATA...
Cant remember password for login
See this for XP http://support.microsoft.com/kb/321305
or this for Vista/Win7 http://windows.microsoft.com/en-us/windows-vista/What-to-do-if-you-forget-your-Windows-password
or you can use thrid party software from Hiren's Boot CD http://www.hirensbootcd.org/download/Hirens.BootCD.12.0.zip
Oct 03, 2010 | Sylvania G-Netbook
Sony Vaio inbuilt webcam is not working with yahoo Messenger
Webcam for vaio computer will not work with a thrid party messenger like yahoo if it is being used by another third party application.
  1. uninstall any third party applications/messenger
  2. reinstall the camera driver and software from esupport.sony.com
  3. try to use the built in camera first by uisng its own software
  4. if it will work, download and install your yahoo messenger and try to use the camera with it
Mar 14, 2010 | Logitech 961462-0403 Webcam
Will power up but theres no picture
I'd first check that you have the hard drives installed correctly as you can have a primary and secondary drive ect. If you need any of the files I'm unsure but If you don't mind those files deleted you could reinstall windows xp. But from a different computer you could get the drivers needed for xp. Install the operating system xp for example and then from another computer dvd drivers such as network(Probably the most important) you can add those and reconnect to the internet and from there download the other drivers directly (IE video drivers). At least check the hard drive connections to see that they are the way you want them. Hope that helps somewhat.
Feb 07, 2010 | Gateway 550GR PC Desktop
Cant reinstall windows because it sayd it cant find a hard drive
two things, check your jumper setting, if it is an IDE hard driver.
Second the computer usually won't recognize the Hard drive until it is formatted for the first time. Did the computer stop and say it could not find hard drive ? and you got F1 to continue, well if you did, just continue. Error 655D is a registry screw up, unplug your usb stuff if you can. remember your drivers aren't installed yet (usb requires drivers-once windows is reinstalling your get the drivers...good luck if you need any more help, just let us know
May 09, 2009 | Dell XPS™ 600 PC Desktop
Faulty HP Laptop
try installing xp with third party raid driver
May 07, 2009 | Computers & Internet
No hardware found when downgrading from vista to xp
first of all you might want to check the laptop manufacturers website to ensure that it can be down graded. after this and if it can be downgraded you might want to download the thrid party sata/scsi drivers from you hard drive manufacturers website so they can be used during set up. if all this fails perhaps using thrid party slip stream software like NLite to copy all the set up files ready for install. hope this helps.
let me know if it doesnt.
Mar 30, 2009 | Computers & Internet
Freecom 400GB Hard drive not recognized.its a Freecom mobile drive xxs 400gb , my pc just cant recgnize the hard drive
I'll assume your using Windows.
I'll assume it's a USB drive.
I'll assume it is an external drive.
And I'll assume it's formatted as NTFS.
Try using the USB (or FireWire) port for anouther drive to see if that is the problem, if it is then reinstall the driver for the port, through the Computer Managment Concole (assuming yur using windows).
If you formatted the drive as FAT, re-format it as NTFS.
Jan 02, 2009 | Computers & Internet
Everex StepNote NC1500 Notebook Logo
222 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
