Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Power Board How much for a power board and how can I get one? Thanks, Al
  • 4 Answers
I need the power cord. Would you sell it to me?
Posted on Oct 12, 2008
Hello , I am told that I need a new ‘power board ‘ for my sharp al-1644 copier after a surge after a power cut? I am getting an H4 fault . Can you help with this , Thanks Terry
H4 indicates a fuser (the rollers near the exit that are hot) error. The power supply could be the cause but its doubtful. Try pressing #,*,C,*,1,4,1,enter(or copy button) to reset it. Good luck !
Mar 03, 2017 | Sharp Office Equipment & Supplies
Al-a250atx does not power on
replace power supply if it's faulty
Nov 13, 2013 | Computers & Internet
I have a phillips 42pfl3704d/f7 it's a set thats never used, except when we have guests in a spare room. after a few power surges, this set now will not come on. the standby indicator light is on...
Check if there is any leak or short-circuiting on the
primary circuit component, and service it if defective.
(C1205, D1205, D1206, D1207, D1208, Q1203,
Q1204, T1201)
Ensure the AL Power is working.
May 22, 2017 | Televison & Video
I own a sanyo "26
Tv now have it on green LED power on for good and tv flashes of pictures only for few min,than dies and have sound left only?Yes,take the tv aparts.U have all the tools and understanding basic electronic also can do basic soldering work too?Check the tv power supply board,that the board where the power a/c cord plug into it.Check the tv power supply board carefully for dead and dying components parts call capacitors.These dying and dead capacitors parts most likely all of the times,will bulges up or puffing up onto it tops.Changes all these dying and dead capacitors parts components,will solved this problems 70% of the times.If the tv power supply board it is good and no dying or dead capacitors component at all.Than the tv a long board that call the LCD inverter board it is dead.This LCD inverter long board are to helping the LCD screen panel to have a backlight to produced a picture.The tv long LCD inverter board have no parts for sale indivitually,al way have to buy a refurbish whole long LCD inverter board for the replacement.Also if you have no tools and soldering skills to fixed the power supply board by replacing capacitors component parts indivitually too.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a long LCD inverter board for the replacement.
May 28, 2011 | Sanyo DP26649 26 in. TV
E 803 when machine is turned on
Hello sir;The error code you display including so many mesnings; transfer unit level switch, left front interlock switch, DC power supply, DC fuser board, DC driver board, CPU board, DC power cut relay.
My suggestion go to check al those switch first if still don't work then go to others.
Jul 18, 2009 | Canon CLC 1120 Color Copier
No picture and the led ligth is blinking panasonic veita 52
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Jun 11, 2009 | Panasonic (TH-50PZ700U) Television
Panasonic TH42PA20 - No Picture
If you have the flashing red light of death you can use the chart below to see what the blinks indicate and call Panasonic and have the part replaced, at the bottom of this page is the meaning of terms.
Apr 13, 2009 | Panasonic (TH-50PZ700U) Television
My DFI 848P-AL 12V 4 port power connector burn
you can find that in a non working power supply, cut the damage terminal and replace that from non working. be sure for the color code of wires to be replace.
Feb 09, 2009 | DFI 848P-AL Motherboard
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
