Question about Toshiba e805 Pocket PC
1.01.0000 Boot bin.
Exsist or it has been removed the first boot rom image language free??
    Master:
  • 903 Answers
As far as I know it is not possible to change image language on PDA and in my opinion there is no any language free file.
Posted on Sep 08, 2005
SOURCE:
I dont kno the default 4ne code for my voda4ne 125 handset
hi
Carefully reading user manuals help in most of cases :)
Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
Here is log of reset to default , read eeprom n read flash
COM3 [VCP0] selected
Device: ZTE-225
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20080118-132834.B1E.bin
loading data...
wrong database file: z225_eep65535.cfg
error: can't load database[11]
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20080118-132834.B1E.bin
Reading [eeprom-dyn]...
file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
error: set erase range
Write Failed
Finished, Remove/Install battery now !
Time used: 22 sec
Device: ZTE-225
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133742.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133742.B1E.bin
file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
Check memory...
Reading [eeprom-complete]...
file saved: backup_eeprom-complete_20080118-133750.B1E.bin
Completed
Time used: 21 sec
Device: ZTE-225
Action: read flash
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133815.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133816.B1E.bin
file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
Check memory...
Reading [flash]...
file saved: backup_flash_20080118-134506.B1X.bin
Completed
Time used: 425 sec
I uploaded all files....
http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
Plz add this model in infinity software....Thx....for ratting
May 30, 2011 | Cell Phones
Hi, I've got a Toshiba Portege M205-S810 without CD-ROM drive. Only slots fro USB and SD Card. 1. How to boot up this tablet from SD card? SD card is empty. 2. How to make an image of my CD with Win XP...
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?ct=SB&soid=886254&ref=EV
If you want to use an external cd drive these are the ones that will work and only these..
The procedure is getting into BIOS settings (press F2 on start ) and on boot sector select the external drive as boot device )
If you want to boot from a SD card or USB memory stick ..than you have to make a boot-able one ..and from what I tried is kinda tricky to make a XP one..so you might consider to install windows 7 if the Ram memory is at least 1 G
But if you want to try ..here are some resources about how to make such a boot-able flash ..
here is for vista and 7 if you do nto have the cd drive ..use a virtual one like iso hunt
http://www.intowindows.com/bootable-usb/
Here is an xp ..and the tools for making a boot-able stick ..read carefully the instructions ..
it was made to install a asus eee which is also a non cd drive net-book
http://wiki.eeeuser.com/windowsxpusb
They recommend to select teh boot device on each restart ..I say to check the bios and see if the boot from usb is available and select it first boot device throughout the installation ..
Jan 27, 2011 | Computers & Internet
After hard set,it still stays in french.
Welcome to Fixya!
In first boot after the hard reset it should ask you to select your language. If it's a Canadian model it should have both English and French built-in.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Nov 22, 2010 | Toshiba e830 Pocket PC
Ihave Apc notebook and the screen just says loading os image and nothing happens please help
Is there an Image CD in the CD ROM? Make sure all media is removed from system. Also, boot into BIOS and make sure that it is set to boot to HD not anything else.
Good Luck,
Jesse
Jan 11, 2010 | Computers & Internet
IOS Recovery
You will have to boot to the boot helper using this procedure:
At the ">" promp type:
o/r 0x2101
i
The router should boot to the boot helper image. You can proceed with flashing the IOS image then.
Aug 08, 2009 | Cisco 2520 Router
Writing bottable disk
Here are the instructions, taken right out of Nero's manual for Burning ROM 8. page 42:
9.3 Creating and Burning a Bootable Disc
To create a bootable disc, proceed as follows:
1. Click on the New button in the main Nero Burning ROM screen.
�� The New Compilation window is opened.
2. If you want to create a bootable CD, select the entry CD from the combo box and the entry
CD-ROM (Boot) from the list box. If you want to create a bootable DVD, select the entry
DVD from the combo box and the entry DVD-ROM (Boot) from the list box.
�� The tabs for the bootable disc are displayed; the Boot tab is in front.
3. If the template data for the bootable disc should originate from a logical drive:
1. Select the Bootable logical drive option button in the Source of boot image data area.
2. Select the entry you want from the drop-down menu.
If the logical drive you want does not appear in the drop-down menu, the reason for this is
that the drive is bigger than the space available on the disc. Please note that for operating
systems as of Microsoft® Windows® 2000 you need to have administrator rights in order to
be able to access drives directly, which you will need to do if you are to create bootable
discs.
4. If the template data for the bootable disc should originate from an image file:
1. Select the Image file option button in the Source of boot image data area.
2. Click on the Browse button and select the desired image file.
3. Select the language that should appear while the system is booting from the Boot locale
drop-down menu.
4. Check the Enable expert features box and select the emulation type for the image file
from the Emulation type drop-down menu.
5. Select any other options required on the tabs (see New Compilation Window).
6. Click on the New button.
�� The selection screen is displayed.
7. Select the files/folders that should be written to the ISO part of the bootable disc and drag
them into the compilation area.
�� The files/folders are displayed in the compilation area and the capacity bar indicates how
much storage space is required on the disc.
�� You have now created the bootable disc and can start the burn process (see Starting
the Burn Process).
Feb 06, 2008 | Computers & Internet
1.01.0000 Boot bin.
Sep 08, 2005 | Toshiba e830 Pocket PC
1.01.0000 Boot bin.
Sep 08, 2005 | Toshiba e805
1.01.0000 Boot bin.
Sep 08, 2005 | Toshiba e800 Pocket PC
Wrong update load sequence ...
In my opinion you should try to make an update again after resetting of PDA.
Sep 08, 2005 | Toshiba e740 Pocket PC
Toshiba e805 Pocket PC Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
