Question about Denon RC-8000 LCD Touchscreen Remote Control
My RC-8000 has no display...
When I touch the screen it beeps indecate it still function some how. But, without the display I can't use it at all. What could be the problem and how can I get it fixed?
  • 4 more comments
  • suzsher Oct 09, 2008
    Our Denon RC-8000 has no display, but it works if you can guess which buttons you're hitting.  Any solution to be able to fix it so you can see the screen display?
  • jerrymarconi Oct 20, 2008
    no screen but remote works
  • Anonymous Nov 04, 2008
    Same here. Remote screen shows nothing but buttons work (at least i think they do)
  • kschneider Nov 10, 2008
    My remote does the exact same thing as everybody else. Do I have to buy a new remote or can the problem be fixed?
  • redrocr Jan 13, 2009
    blank screen but volume works and i think i have just hit a wrong button...
  • bobdobilina Mar 14, 2009
    same problem - screen beeps when touched, volume and mute work, but nothing shows up on screen
What kschneider said works! Use the 2nd link he gives do download the denon software tool and update your remote. I did it and now it works again!!
http://denon2.jp/rc8000/index.html
Posted on Mar 14, 2009
I believe I have found a fix for this problem. Go to: http://oldusa.denon.com/aktis/downloads.asp
and download the software from the site. Follow the instructions on the site: http://denon2.jp/rc8000/index.html. Be sure to back up your existing file from the remote before using the update program.
This fixed my problem and I feel that this will fix all of yours too! :)
Posted on Nov 10, 2008
Our screen does not beep but you can't see the display.
Posted on Oct 09, 2008
Display shows 6's across screen & beeps
HI. the touch pad board is malfunctioning at this time. you will need to replace this damaged touch pad device asap. this will fix your issue.
Sep 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The only screen I get is5/1 nothing else on my denon rc-8000 remote. I can not get any other funtions to work. Not even the back light. Can anybody help? PLEASE
Dear granggreen....Patrick here....
Even if you have performed these functions I want you to do them again. Remove the battery cover, remove the re-chargeable battery and it's blocks that hold it in position. Install new AA batterys, press the RE-SET BUTTON and hold for three seconds. If these steps prove nothing my instinks say that one or all Joy Stick discs are flat. Surgery is needed.
Patrick
Jul 02, 2009 | Denon RC-8000 LCD Touchscreen Remote...
Found an RC 8000 on ebay with a buy it now!
Doug_ie1
Patrick here....aske the seller if the rechargeable battery and AA battery blocks are still withe the RC- 8000. In writing from the seller have them clarify that the joy stick/ selector works. Pay no mre than $125.00 if the RC-8000 is perfect.
Patrick
Feb 07, 2009 | Denon RC-8000 LCD Touchscreen Remote...
Accidentally deleted setup menu and can't restore it.
Dear dalton....Patrick here
I believe this may be impossible with normal use. Alarge magnictic force would do this. My RC-8000 had odd ball problems that it was sharing with my 5803. Once I fixed the JOY STICK all other problems went away. If it has programing issues, then Denon will have to deal with it. Use there Portland Ore. Service Center and Pay the money.
Patrick
Jan 17, 2009 | Denon RC-8000 LCD Touchscreen Remote...
Constant beeping and F7 is displayed
Hi tahitian,
The error code F7 means that the Function key is shorted or stuck. To fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Dec 16, 2008 | Magic Chef 31000 Gas Kitchen Range
I have a problem with my denon rc 8000 remote
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Jun 06, 2017 | Denon RC-8000 LCD Touchscreen Remote...
Janome 8000 on but witout functioning
Turn on the power switch while you are pressing the start/stop key,reverse key and auto-lock key.The LCD screen indicates(Press + Mark) You should see a ( + ) on the screen.
Press the center of the plus mark with a non-sharp object. The mark moves and the machine beeps.Do this until the screen says Adjustment END.
Turn off the power switch. Wait 10-15 seconds and turn on the power switch and see if you can select stitches.
If this doesn't solve your problem and you can see the patterns on the screen you have another problem which will probably involve a visit to a technician either Janome or Elna trained(Model CE20)
If you can't see any patterns or they are faint then the LCD board needs to be rebuilt and an authorized Janome Dealer can remove the board,send it to Janome for a rebuild and reinstall it for you.Plan on spending more than $300 for this. If the machine works well, it is well worth if as it is a very nice machine.
sewman7
Nov 05, 2008 | Janome 8080 Computerized Sewing Machine
Remote Control for Denon AVR-5800
I have 2 Denon Universal Remote RC-8000 AVR for sale if you like you can send email Shavoniemail@yahoo.com
Thanks, Scott
Oct 24, 2007 | Denon RC-8000 LCD Touchscreen Remote...
Denon RC-8000 LCD Touchscreen Remote Control Logo
677 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
