Question about Electrical Supplies
Generator Starts but won't continue running/dumpimg fresh fuel into filter
I've had my generator in storage for a year with a gas preservative in the fuel tank. I pulled it out of storage and started it but it won't continue running. It sems to be dumping fuel into the fuel filter box and then smokes and shuts off. What do i need to do to get it running properly?
  • akimsproduct May 11, 2009
    hi all i have a 5800Watts gas generator from homelite. it starts put will only run for 20mins and if restart for about 5 to 10 mins. the the oil was changed, the choke adjusted, gas level checked, spark plug changed but to no avail. any ideas on wat could possibly be happening would be greatly appreciated
    thanks much and in advance!!
    Novelist:
  • 72 Answers
My answer:
Not knowing your exact model # or how old it is, and knowing only what you said above - TOTAL RUN HOURS unknown as well? - I can only give you several possibilities of what the problem might be - even though I don't know the exact model # and which engine you have on the Genset. Porter Cable as well as Coleman and others do not themselves mfr much of anything today, but like with many USA companies out there today it does private label out to a lot of mfg vendors (mostly in China btw), and the Genset gas engines are numerous. From Briggs & Stratton to Honda to Subaru and so forth...
I also don't know what normal LOAD you were putting on your Genset there, or have been putting on it previously, or at what RPM you are normally running the engine at - as to half throttle or full throttle setting?? I take it that it's a Briggs & Stratton 4-stroke single cyl, or is it a Honda 4-stroke single/twin cyl engine?
Any Genset that is going to be put into storage for that long a period of time I would first and foremost recommend running the Carb Bowl dry first by running the Genset at FULL speed, and while running turning off the gas until it dies. Thus removing as much gas from the Carb Float Bowl as possible!
Most people do not do this and forget about that small amount of stale gas in the Float Bowl, and that is what causes VARNISH in the Carb Bowl faster then anything else.
Just putting a gas preservative in the gas tank doesn't solve the VARNISH problem because that never gets down to the Carb to begin with if the gas line shut-off valve is closed before the preservative gets down there.
If the Float decides to stick while in storage, and then it's brought out to fire up naturally the gas will flood out the Carb and probably the Air Filter Box as well.
It's always better to store the Genset DRY! I know I do and I have NO problems at all with stale gas, etc.
Since all Gensets need to be run a minimum of 10 minutes every 30 days (every 1 month religiously), or whatever your owners manual recommends - if you haven't been doing this, or don't run the gas out of the Float Bowl before shutting the Genset down after each use - then most likely the Carb is gummy or possibly has dirty gas in the bowl and is the problem.
I seriously doubt you did any damage to the engine by the recent gas over-run and flooding.
You might try and tap carefully on the bottom or side of the Float Bowl with a hard rubber hammer first to try and see if you can dislodge the stuck Float inside. If there is a WIRE at the bottom of the Float Bowl on your model - DO NOT HIT THAT GAS SHUT-OFF SOLENOID WITH THE RUBBER HAMMER - as you will do damage to it! If this dislodges the stuck Float then your problem is solved!
You may still want to run a bottle of Carb Cleaner in the tank just in case to clean out any residual buildup in the Float Bowl, etc. If it runs fine then No Problem.
First and foremost always check your OIL LEVEL and make sure you have changed it out according to your owners manual!!!
If your Genset still runs sporadically for only a short time and then starts to cut out I would look more for like a fuel vapor lock (partially closed or clogged gas cap vent), a possible dirty fuel filter, possible water moisture in the gas tank or in the Carb bowl, possibly dirty Carb in general along with it's dirty Float Bowl, Float Pin, Float and Needle Valve, and any Adjustment Screws that go Into the Carb Body.
It's hard to say unless the Carb first is broken down, checked for proper Float action setting, and/or cleaned out accordingly if dirt is indeed present in the bottom of the Float Bowl.
If all looks good there Carb Bowl wise then you will next need to check the FLOAT adjustment itself to make sure you aren't flooding the Bowl. Your Operators/Service Manual should have that adjustment there. If not let me know and I'll post it for you. Also the air/fuel mixture Jet Adjustment Screws will need to checked as well.
Let me know if you should need that adjustment procedure as well after you first check out everything else I stated above?
That covers everything from a fuel standpoint.
Again - You do know that all Gensets should be started and run for at least 10 mins every 30 days - right? If you didn't know this - now you do! Every good operators manual should state this.
It just doesn't sound like it's starving for gas - that's for sure!
The gas tank fuel line does have an in-line fuel filter correct? If it doesn't you definitely need to add one for dirt protection!!
Having covered everything from an fuel standpoint engine wise - there is only one other thing left Genset wise.
Beings your Genset there might just have some high RUNTIME HOURS on it - it just could very possibly be what sounds like to me (and I personally HAVE SEEN this happen myself firsthand) that the generator brushes are nearly shot - as in almost worn out. They may be getting too too hot - as from excessive current draw at point of contact, and thus the generator sensing circuitry itself is doing an electrical CUTOUT!!
An added protective Genset circuit feature in that the generator itself may indeed be linked to the engine as a type of REV LIMITER or CUTOUT on the Maintenance-free Magnetron® electronic ignition. Again - your operators or service manual should have a pretty good troubleshooting section in it unless you don't have that anymore or never got one if you bought it used to begin with.
If you unscrew & remove the Generator brushes, and they are indeed below the recommended length (or worse case they are indeed totally worn down) then that too most likely could be your problem right there.
If you choose to replace the old brushes with new ones yourself - be very careful when seating the new ones - as to their insertion and cap retainer tightening. Never over-tighten those black plastic-like brush retainer screw caps - for if you break one (hard to get immediate replacements is why), or fracture one it could cause the Genset to fail under LOAD, and that very well could do some severe damage to the generator part itself. Take your time doing it, and be patient!!
It has to be one of the scenarios listed above, as I've covered every possible cause short of a broken wire somewhere - which in that case you will have to schematic trace and Ohm out wire to wire contacts. This being the least likely scenario from experience.
If you indeed find the Float Bowl assy to be the cause of dirt contamination or varnish build-up clogging the Carb, and you need a walk-through of taking it apart, cleaning it out, and then re-assembling it again - as well as re-adjusting the fuel mixture Adjustment Screws - just give me a shout here, and I'll walk you through it step by step.
Please post me a reply as to the found problem there, and the resolve to it by following my recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
PS:
GENERATOR OIL CHANGE NEGLECT
People experiencing starting issues often are not using fuel stabilizer or not changing their oil. I myself or any good repair shop will first pull the oil out, and most times we'll will find that it has metallic build up common from any small gas engine that has been neglected.
Posted on Sep 03, 2008
Carb on a generator
Hello, you have either water in carberator or problems with it, you either take off and clean or take for service.
Nov 26, 2015 | Electrical Supplies
Generator only starts when primed then immediately stalls. I 've changed plug,drained gas and cleaned carb. still won't run
Ok, is it a Briggs&Strattion engine? if so it most likley has a fuel pump that works off vacume on it, I had one go bad
Aug 27, 2011 | Coleman Powermate Powermate 5000W...
I have a 5500 ppg generator that won't start. I've verified the fuel lines to the engine are delivering fuel, but won't start. I've been able to pour a small amount of fuel down the carb...
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Aug 23, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
I own a 5000 watt generators the problem is generator starts with choke on however as soon as i start closing the choke generator shuts down, any ideal on how to correct
Get a can of carburetor cleaner. Drain the gas. Mix small quantity of fresh gas & carb cleaner about 50/50. Run a little through (it might not start, but crank it enough to get some solution through the carb.) If it runs, that's great, run about half of your solution then turn it off for an hour. Then run the rest through. If it won't start, then after the hour add a bit of fresh gas to make the remaining solution about 90% gas and run this through By the way, running the carb cleaner through the air intake will not fix this problem, because the gumming of gas is in the fuel line, float valve, needle valve - not in the air stream. Running carb cleaner through the air intake is useful if the throttle is sticking.. Good luck, Vote if you found this helpful, Al K
Jul 07, 2011 | Craftsman Electrical Supplies
Generac home generator does not start. It starts alittle bit but then dies. Maybe runs for 4-6 seconds
is this unit diesel or gas? If its gas driven, the carburetor needs to be removed and cleaned out. Also make sure your gas is fresh. If not drain fuel tank, remove carb, clean out, re-assemble & test. Check fuel filter, oil level.
Feb 05, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Sep 07, 2009 | Master Heaters MASTER HONDA POWERED...
2 year old honda eu1000i generator with new spark plug fresh oil fresh fuel clean air filter starts eazy runs for 2 mins then dies
SOUNDS LIKE TO ME YOU HAVE A PROBLEM IN THE OIL ALERT SYSTEM, IF YOU HAVE THE REPAIR MANUAL IT WILL TELL YOU HOW TO TROUBLE SHOOT IT!!!
Aug 30, 2009 | Electrical Supplies
COLEMAN 5500 GENERATOR. IVE HAD IT 3 YEARS,
Gasoline goes stale after sitting a while and makes starting hard. Three years worth, it's more like jelly! You need to clean the tank, lines, filter, and carburetor. Run it for a while on a little fresh fuel after cleaning, then let it run out of fuel. That will remove most of the fuel from the carburetor. When you want to run it again, add whatever fuel you need, but allow it to run dry again. That's not prefect, but workable.
Aug 19, 2009 | Electrical Supplies
Coleman Powermate generator will not start.
Changed plug since last year?Choke adjustment? try premium gas?
Aug 13, 2009 | Electrical Supplies
Generator won't start
i have the same problem. i took out the air filter and sprayed tb into it and it ran and died. this is the only way to get it to fire up.
i took off the carb, dissasembled it and blasted it out with tb cleaner, took out the jets too, put it all back and it still does the same thing. it is getting fuel but it won't run.
need a profesional answer on this one please.
thanks, tom.
Jun 13, 2009 | Yamaha 1,000 Watt Portable Generator...
Electrical Supplies Logo
954 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
