Question about Cameras
Javelina camera glass cover broken which dspresserized the camera
  • 2,071 Answers
Just click below for free estimate;
http://www.advancecamera.com/repair/
hope this may help;
Regards,
VOTIT
Posted on Aug 28, 2008
    Master:
  • 521 Answers
Replace the glass cover through any repair center .and then all the problem will be solved.its because the allignment is disturbed.replacing will definately help.
please rate the solution sir.thanks.
    Master:
  • 848 Answers
Provide in more detail about your problem ..........
Glass of the cover is broken
Sorry, you can't fix that. You need to contact the manufacturer.
Mar 23, 2014 | Gordon Ramsay 6 qt. Nonstick Low Pressure...
My monitor case glas is broken is it covered of the warranty
unfortunately, no it does not cover the warranty. The broken monitor glass was an accident caused by you, so you will be the one to bear the consequence.
The warranty is void in this case. Warranty only covers factory problems.
I hope this is clear now. So you can go ahead and replace the broken glass.
Good luck.
Dec 06, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Is it possible to fix the view screen if just the glass (not the ldc) is broken? Fuji FinePix Z5fd
There is a plastic cover over the LCD. Is only the cover broken? The plastic cover is easily replaceable.
But there is also a sheet of glas over the LCD. This is a part of the LCD assy and cannot be replaced without replacing the entire LCD.
Feb 08, 2010 | Fuji FinePix Z5fd Digital Camera
Our daughters HP photosmart M637 camera's display looks like broken glass. She says she did not drop the camera but was scroling through her photos and all of a sudden the display window went blank and...
As you suspect, this simply does not happen unless the LCD panel has had a physical impact. The LCD units are stress tested when manufactured and the odd ones which crack "all of a sudden" would do so within a few months of manufacture and then get replaced under manufacturer's warranty. The broken glass which you see is the cracked LCD unit and it's behind an outer plastic protective cover.
The only way to fix it is to replace the LCD panel, but it's not a DIY job and repairs will cost more than the camera is worth. The M637 will only be about two years old but it was a budget model to start with so it would be cheaper to buy a fully functional used equivalent camera. There are even brand new models of similar or better specification which will be cheaper than a repair.
If the camera works "as is" then it may be better to put up with the fault until the camera no longer works.
Dec 07, 2009 | HP Photosmart M637 digital camera (L2455A)
I have broken the glass on the viewfinder of my powershot S3IS, can it simply to un-srewed and a replacement put in - if so where can I get one from?
If only the viewfinder glass is broken, you can put other one to replace it.
It could be glass but I do recommend you to replaced with an acrilic or a plastic part.
You can get it from different soruces: Ebay from a broken camera (S2, S3 or S5), or use transparent plastic film and cut it to the right size.
You don't need to open the camera completely. You will need just to remove the viewfinder rubber protector, and carefully, pull the viewfinder frame that holds the glass. There are four plastic locking tabs (two up, two down).
Best regards,
Jul 14, 2009 | Canon PowerShot S3 IS Digital Camera
BROKEN GLASS COVER UNDER NIGHT LIGHT
SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Broken glass on the lens
Are you kidding? A camera lens are a group of various lenses inside. I don't think it's repairable, but I'd say take it to a local photography store and you can get free advice. I think I understood you, but anyone would have to see the damage in person. From here, I'd say you are in bad luck...it's a goner. Also cameras are not designed to take a big fall like that. There is probably more damage than just the lenses.
Apr 04, 2008 | Sanyo VPC-CG65 Camcorder
Cameras Logo
42 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
