Question about Mitsuba DV505 Digital Camera
It's a Mitsuba TC-5000 -- ID on the box & camera body
As noted --- everything I see indicates this is a Mitsuba TC-5000 optical zoom 35mm camera 'Made in China' and there's even a new Fuji film cassette within the camera. There's also a detachable flash setup which tightens down to the body for storage,. the cvamera body also tightens down. Is this perhaps a discontinued item....or....is this like some rip-offz idea of a {bad} joke???
  • Anonymous Jan 25, 2009
    how do i turn it on
SOURCE: How do I turn the flash on my camera? It is a Mitsuba DV304.
You move the joystick to the left to enable the flash!.... took me forever to figure it out lol.... hahaha
Posted on Oct 14, 2010
Lens size of a SVP DC- 1251
This is fixed lens camera.
Key Features Digital Zoom
8x Camera Type
Compact LCD Screen Size
2 in. Resolution
5 Megapixel Optical Zoom
Without Optical Zoom Image Quality Camera Resolution
5 Megapixel Image Sensor Type
CMOS Video Video Resolutions
640 x 480 (VGA) Lens Interchangeable Lens
Not Interchangeable Lenses Optical Zoom
Without Optical Zoom Exposure Control White Balance
Underwater (Preset) Storage Memory Type
Built-in • SD Card Built-in Memory Size
16 MB Included Features Self Timer
2 Sec. • 10 Sec. • 12 Sec. Tripod Mount
With Tripod Mount Interfaces Interface Type
USB 1.1 Power Supply Battery Type
2 x AAA Batteries Dimensions Depth
0.83 in. Height
2.3 in. Width
3.5 in. Miscellaneous UPC
859108008797 Product ID
77004823 Included Accessories
2 x AAA Batteries • USB Cable • Strap • AV Cable
Aug 04, 2012 | VuPoint Cameras
Video Problems
Auto Mode In this mode, all you have to do is press the shutter button and let the camera do everything else. 1. Turn the camera on.
2. Turn the shooting mode dial to normal_mode.gif.
mode_dial.gif 3. Aim the camera at the subject.
4. Use the zoom lever to achieve the desired composition (relative subject size in the viewfinder).
  • The angle of view can be adjusted within the 45 to 100 mm range, in 35mm film equivalent.
  • When the LCD monitor is on, the combined use of the digital zoom and optical zoom enables magnified shooting up to approx. 7x.
5. Press the shutter button halfway.
  • Two beeps will sound when the camera has finished metering, and the indicator will light green or orange. If the LCD monitor is on, the AF frame will appear green.
  • The yellow indicator will blink and the beep will sound one time if the subject is difficult to focus on.
af_frame_indicator_a70.gif 6. Press the shutter button all the way.
  • You will hear the sound of the shutter when the shutter activates.
  • The picture appears for two seconds on the LCD monitor, if it is on.
  • The indicator next to the viewfinder blinks green while data is recorded onto the SD card.
Jun 10, 2007 | Canon PowerShot A400 Digital Camera
Zoom function
Yes. This camera has 3x optical zoom and 4x digital zoom. However digital zoom cannot be used in 2880 x 2160 size. Optical zoom: It is approximately 5.6 - 16.8 mm. (equivalent to 38 - 108 mm on 35mm film camera) Digital zoom: It extends to 4x from telephoto end (108mm) of optical zoom.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
Optical components of the DiMAGE E223?
This model features a 3x zoom lens (6.2-18.6mm which equals to 38-114mm in 35mm format) built in the body, with 9 all glass elements in 6 groups including one double-sided aspheric elements (four aspheric surfaces in total).
Sep 19, 2005 | Konica Minolta DiMAGE E223 Digital Camera
What type of lens does the DiMAGE 5 use?
The DiMAGE 5 offers a 7x high power zoom lens, with a focal length of 7.2 - 50.8, which in 35mm equivalent equals 35 - 250mm. A manual zoom ring controls the optical zoom. The DiMAGE 5 has a maximum aperture of f/2.8 - f/3.5.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
30x total zoom
The IR-500 has a thin body with a folded light path lens unit, which packs the 2.8x optical zoom power into the camera's exceptionally thin body. This, along with the 11x digital zoom combine for a seamless 30x total zoom.
Sep 01, 2005 | Olympus i:robe IR-500 Digital Camera
Telephoto images
The D-545 Zoom camera has a 3x optical zoom coupled with a 4x “seamless” digital zoom to deliver a total 12x zooming feature. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Options for more telephoto zoom
The D-535 Zoom camera has a 4x digital zoom in addition to the 3x optical zoom, which gives you a total of 12x zoom overall. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Built-in lens
The built-in lens "all-in-one" designed to be digital, which means it is specifically matched to the CCD. Cameras offering interchangeable lenses are designed for 35mm film, which usually does not have sufficient resolution for a Megapixel CCD sensor. When interchangeable lenses are removed from the body, the CCD and internal mechanisms are exposed to dust in the environment. Contaminants are a much bigger problem on digital cameras since the CCD is much smaller that a 35mm film plane. One of the primary reasons for using interchangeable lenses is for a wide variety of focal lengths. The E-20N contains a 4x optical zoom 9mm-36mm (35mm-140mm equivalent in 35mm photography) built-in lens. In addition, there are wide angle, telephoto and macro add-on lenses. Some interchangeable lenses cost as much as the E-20 camera itself. Other lenses that were originally designed for film cameras do not deliver same focal length on a film camera as a digital camera. For example, a wide-angle 28mm lens attached to a digital camera would only provide 56mm equivalence. This system offers great flexibility and will suit approximately 95% of most shooting needs.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Differences between Optical Zoom and Digital Zoom
When you change the focal length of a zoom lens, the subject is magnified. Optical zoom replicates the zoom of a 35mm camera. Digital zoom takes a portion of the image's data and displays it at full size, producing a magnification of the original image, similar to the effect of using a telephoto lens. However, the process is different from the magnification produced using the camera's optical zoom, and the stronger the digital zoom, the more the image will degrade.
Aug 30, 2005 | Panasonic Lumix DMC-F1S / DMC-F1K Digital...
Mitsuba DV505 Digital Camera Logo
539 people viewed this question
Top Mitsuba Cameras Experts
Gene Haynes
Ravi
Are you a Mitsuba Camera Expert? Answer questions, earn points and help others
