Question about Compaq Presario 700US Notebook
My presario 700 is taking time in start up and other operation more than expected
My note book is having ram 256 SD , now it is slow than my expectation tell me what i do to increase its speed, both online and offline, recomend me some software please. and tell me how i repair my SP3 if it is no geniune.
My note book Compaq presario cq 40 108 TU i had installed Windows 7, but it gets a huge time to start it take 1 - 2 hours . please help me! thanks!
Yo! i shoukd think your windows was not properly installed and if it was, your RAM has got to be too small for it. i will implore you reload another windows on your system. thanks
Jul 27, 2011 | Computers & Internet
Hi i have compaq presario c700 its too slow discr
If you have changed OS, your problem probably is not due to malware or bloat.
Upgraded to 2gb ram, new hard drive. And still you think it is too slow.
I think either you are too fussy, and expect too much OR your laptop has major problems at a chipset level.
Have you tried running some benchmark software to check if it really is running slow???
I would Do a fresh install of windows, SELL it and change to a different model.
Try checking a couple of reviews on sites like Custom PC, for a good fast laptop.
Aug 21, 2010 | Compaq Presario 700 470024-192 Notebook
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
I hace a compaq presario 700 . I added 256 memory
remove the memory ... try again ...
there is the possibility your memory was not seated correctly and/or it is not the correct memory.
remove it to get going again ...
256 is a strange number ...
please go to www.4allmemory.com and have them scan your computer. They will make recommendations based on that scan. Compare what you got with their recommendation.
Truth is a journey not a destination
Thanks for using fixya.com
Oct 26, 2009 | HP Compaq Presario 730US Notebook
Presario won't recognize second 256 RAM
Remove the original module, install just the new one and then start your computer. If it doesn't start, the memory you bought is bad. The system boards used in the Compaqs will auto-detect memory, and there are no jumpers or BIOS settings needed.
Apr 09, 2009 | Compaq Presario 5000 PC Desktop
Ram for a cumpaq presario 700
Try www.crucial.com to have their checker tell you what type and maximum ram for your system.
Feb 02, 2009 | Compaq Presario 700 470024-192 Notebook
My presario 700 is soooo slooow
Have you cleared the temporary internet files? Also, download ccleaner (its free) this will delete unneeded files from the registry. You should also run and antivirus and antispyware program followed by defragging the hard drive. That should improve your speed.
Jan 27, 2009 | Compaq Presario 700 470024-192 Notebook
Additional memory - speed?
yes even the 128 increase will be noticeable, but to be sure of what your system can take visit the crucial site and download the scanner tool to tell you what the memory capacity is
Oct 12, 2007 | Compaq Presario 700 470024-192 Notebook
Pc wor slow
you could have a driver problem, but i would expect you to require more than 256MB of ram work along side a dualcore processor, you should have atleast 1GB ram.
Sep 23, 2007 | Microsoft Windows XP Professional With...
Compaq Presario 700US Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
