Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
Networking Problem Hi, Im currently using XP SP3 and currently have a cable modem ( motorola sb4 200 ) and a brand new asus wl-520gu. When i connect directly to the computer via the modem it works fine however when i go through the router it will not work. I have tried the following to fix it but still no solution; Turn off and reset about a thousand times Disable all firewalls etc etc etc Called my ISP but will not offer any support for the router. I was previously using a D LINK WRT54Gs and worked perfectly until it broke down a few days ago. Please offer some help or if possible find out if the modem and router dont match because i cannot see anywhere on the web where it says so. Cheers Shaun
  • shauntamplin Sep 01, 2008
    hey mate, nah it didnt fix it but i did get it fixed i just created a static ip address then applied the settings then reverted back to automatic config and it picked up all the new settings and works fine. Weird i kow but hey maybe it could help others if they tried that.
    Cheers for the help though.
    Shaun
  • bflo142 Jan 08, 2009
    I have CavTel DSL with slow (400-500) but usable service. When I bought and introduced a WL-520GU router, no wired or wireless internet connection could be established. After numerous powerdowns and canned remedies, and calls to both CavTel and ASUS Techs (pointing fingers at each other), the ASUS tech said the unit must be faulty. This morning I just received the replacement (out $10.00 shipping the return) and fonund the same problem.
    Another call to CavTel this time highlighted I'm 16900 feet from the DSL source, and they are NOW saying wireless routers will only support DSL up to about 12000 feet. It's obvious the router (any wireless router?) is further degrading the DSL signal to oblivion.
    This second router going back today (another $10.00 freight).
    For $20.00 I learned to live with my wired DSL.
    Thought you'd like to know.
    -Jim
    Scholar:
  • 77 Answers
When you are connected to your modem, find out what your IP address is....(double click on the icon in the lower left corner of your monitor) under the support tab it will give you your IP address you are being issued from your ISP. Now go ahead and connect the router and then connect your pc to your router. Go to your web based settings of your router....(type 192.168.0.1 or 192.168.1.1 into an open browser window) admin is usually the username and password. From there you will want to go to "status"...make sure the same ip address was assigned to your router as it was assigned to your PC. If not you will have to release and renew to have your ISP re-assign to your new router. Within those settings ensure there is nothing prohibiting you from accessing the internet....your router will have a built in firewall as well as have mac filtering and certain other security settings. Let me know if this helps....once you have done this I will check back and assist you further if this is unsuccessful.
Good Luck
Posted on Aug 28, 2008
I use the Asus WL-330ge as a network adapter for my HP Printer. This worked perfectly until I switched internet providers. I changed the IP on my printer to the same subnet as my new wireless router...
Let me state how I think you have this setup
Printer is Ethernet ---------- Ethernet (WL-330GE wireless adapter)
WL-330GE adapter >>>>>> Wireless >>>>>> New Router
eth_adapter_mode-d2r1efs5ntrf2rjwzg4ldeyi-5-0.jpg Diagram and mode is from
https://www.asus.com/Networking/WL330gE/HelpDesk_Manual/
ASUS WL-330gE user's manual in English
So I think you need to use Ethernet Adapter Mode !
The computer shown would be your printer
As you are using wireless you need to set up the wireless ssid and the wpa or wep encryption to match the new router I am guessing .
in section 4.3 advanced settings in the above manual link from ASUS.
Also the access point has an ip address by default as 192.168.0.1 255.255.255.0 you would have to most likely have 176.16.1.2 and the new router as 176.16.1.1 and the same subnet mask what ever it is maybe it is 255.255.255.0 then make the printer 176.16.1.5 subnet 255.255.255.0 or whatever subnet you use.
Make sure you log into the new router and alter the DHCP server to assign leases from 176.16.1.10 to 176.16.1.254 with same subnet mask.
Mar 31, 2017 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
I cant reset asus rt-n10e routr
I had same problem with my asus device. so i called Asus Tech Support At Toll Free Number 1800-585-2494 and they have fixed my problem.
Hope they will help you as well.
Jan 20, 2013 | ASUS WIRELESS ROUTER |WL-520G - RT...
I lost my installing CD - ROM and my equiment is Asus WL-520GC/WL-520GU , can u help me? anyway, i cant even install my wireless equitment
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Apr 29, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
Hi, Im using Linksys SR224 24 ports as my main switch. I got a poor internet connection, this problem occurs few weeks ago. I tried to connect my modem through a LAN cable directly to my server and...
Try a brand-new cable between the modem and the "uplink" port on the router.
Try a brand-new cable from one of the "LAN" ports to your computer, and test to see that you get a good connection.
Jan 04, 2011 | Linksys SR224 (srw224) 2x1000 Mbps...
I can't log in to my router's web interface. I've tried the password as both admin and leaving it blank while the username is admin. The IP adress I'm using is192.168.1.1 and the ASUS router model is...
if you can not remember the password than the ownly thing you can do is a reset (according to manual) than you will be able to log in using default user and password (YOU WILL LOOSE ALL SETTINGS) so you will have to re configure the router...
Have fun!
Jan 04, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
I forgot me password for an Asus WL-520GU wireless router, how do i make a new one or change it?
Hi Dillon,
Please let me know what password you have forgotten,do you mean the one which is meant for log in to the router. open your browser and type 192.168.1.1 enter it and then check for the password.
Regards,
Gary
Dec 29, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Asus WL-520GC wireless not working....
hi buddy!
first you configure the router to the modem ok
by typing the 192.168.1.1 and follow the instruction ok
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Jun 22, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Routers
Hi Like,
Unplug the router, Don't hook it to anything but you PC you are have the CD in. Use the cable that came with the unit, plug it into your pc ethernet port and one of the 4 ports marked LAN. Make sure not use the port marked WAN. Make sure you use the ethernet cable, not the USB. Power up the router, and put the easystart cd in. Once it autostarts, press the Easy Setup button on the router for about 8-10 sec. The Easy Setup on your screen should respond. From there out, follow the prompts.
For the manual, follow this link.
The quick start should solve your setup connection issues, if you have any. Also, make sure you have your firewalls disabled. And re-enable them what you are done, to be safe!
Good Luck!
Jan 06, 2008 | Computers & Internet
Computers & Internet Logo
217 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
