Question about Toshiba e830 Pocket PC
Compact flash cards
Having problems with CF Card - only one of 5 cards is seen by PPC - anyone had similar problem?
    Master:
  • 903 Answers
You can try to do a softreset and try to read the cards again! Also cleaning the slot should also help...
Posted on Sep 08, 2005
THE CAMERA BRINGING A NOTICE ON A SCREEN ERROR CF.WHAT IS POSSIBLE THE PROBLEM.
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
Nikon D70, displaying error code 'CHA' when memory card inserted. Unable to format or use memory card. Have tried new memory card, still same problem.
CHA errors indicate a communication issue with the CF card. Your card could be going bad, you could have a broken pin, or any number of other problems.
I'm running into this same problem now. If anyone has a good step-by-step to troubleshoot which of the dozen things this error could be, I'd appreciate it.
For myself, I'm planning to start by trying a new CF card.
Sep 02, 2008 | Cameras
Pocketstudio 5
A CF card is a compact flash memory card. It's rectangular and has two rows of holes along one side which fit over the connector pins when you slide the card into its socket. Compact flash cards can be bought from electronics or photographic shops, and some department stores. They are not expensive but these days they are usually 1Gb and up. The TASCAM Pocketstudio 5 can only format up to 128Mb so most of a modern card is not used but the card will still work.
Apr 11, 2008 | Tascam Pocketstudio 5 MP3 Player
CF Excessive Power
Nikons and Fujis keep the CF slot powered, and "poll" it every now and then to see if a card has been removed or inserted. So yes, a camera may drain batteries much faster with a CF card than it does with an XD. But if it really does do this, then someone at Fuji deserves to be on the street, looking for a new job. Polling a card every few seconds does not have to be a traumatic experience to the camera. A Nikon can sleep for months, and not show appreciable battery drain. After what I've seen in the horribly slow CF write times of the S3, and the large artificial difference in write times between CF and xD on that camera, I'd say someone (or several "someones") at Fuji is doing everything in their power to make CF look bad and steer people into xD.
Sep 12, 2005 | Fuji FinePix S7000 Digital Camera
Fix for HP 315 camera - 32mb CF limit under WinXP
Yes, find a printer that has the card slots in it and upload your photo's to your computer. You have to take the larger card out of the camera and insert in the printer. Yes it works I have a lexmark and do it all the time. if you have more questions e-mail me at joal1445@yahoo.com
Sep 08, 2005 | HP Photosmart 315 Digital Camera
Compact flash cards
Sep 08, 2005 | Toshiba e805
Compact flash cards
Sep 08, 2005 | Toshiba e805 Pocket PC
Compact flash cards
Sep 08, 2005 | Toshiba e800 Pocket PC
Compact Flash card compatiblity
I don’t know why you PDA can not read your card but I found some infrmations about parts which are compatible with e800. As far as I know this types are compatible with e800. Compact Flash Memory Card 1GB (PX1076E-1NME) Compact Flash Memory Card 512MB (PX1075E-1NME)-Type I Compact Flash Memory Card 256MB (PX1074E-1NME)-Type I
NAVMAN GPS Card problems
It is not easy to say what the problem can be. In my opinion you should contact the producer of this GPS receiver and ask them what the problem is. If this has been tested the producer must be able to help the users.
Sep 08, 2005 | Toshiba e750 Pocket PC
Toshiba e830 Pocket PC Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
