Question about Sharp Office Equipment & Supplies
We can receive but won't take the paper to send a fax out
    Problem Solver:
You have an ADF paper feed problem, try taking some rubbing alchoial and clean the ADF paper feed tires, This helps the paper to feed into the scanner unit so the fax can be sent. I have also seen part of the ADF feed unit broken.
Does the paper feed in but not transmitt out?
Posted on Aug 28, 2008
Paper jam won't go away and its no paper in the machine
was there a paper jam in the first place where you had to pull the paper out?if so try and get in there and check if there is a little peice left as i believe these have little sensors that are affected very easily by the tinyest of paper. good luck!
Feb 07, 2012 | Sharp UX 355L Plain Paper Thermal transfer...
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
Can't send fax, can only receive
you can't send the fax, the paper don't feed, you need to clean the paper path the roller that guide the paper to pass under the the scanner must be cleaned with alcohol. you need to unplug the fax from the power source. after cleaning wait for 10mn and try to send a fax.
Dec 23, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Fax will send but not receive faxes. Says printer
Mite need to clearthe memory of the fax machine
Mar 21, 2010 | Sharp Office Equipment & Supplies
Cannot sent fax because document too long
If you can copy the document, then you can send it BUT the receiving fax will probably have restricted length fax pages to prevent jammed documents at the sending end causing the receiver to use all the paper. If you have access to a service manual you can restrict the length of faxes sent and received on your machine. But it may be the receiver with the restriction.
Jul 01, 2009 | Canon FAX-L900 Plain Paper Laser
Sending and receiving fax on legal size paper on
What's the question? You can send a fax on legal size exactly as you do with lettersize. As for printing, you only have 1 size of paper available at a time (1 paper source) , so put legal in it if you want.
Apr 12, 2009 | HP LaserJet 3050 Printer
Having trouble sending a fax and receiving one,, also where does
To send a FAX load the pages in the auto feed tray on the top of the unit. To receive a FAX, load the paper in the paper feeder vertically on the back of the unit. Suggest you consult your users manual.
Jan 19, 2009 | Epson Stylus CX9400 Photo Printer
Fax Canon JX200
is there any error messages coming out from your fax machine.see the error messages first.the paper should run smoothly during sending and receiving process
May 06, 2008 | Canon FAX-JX200
Fax chews paper when receiving a fax, sends perfectly
Where it is receiving the fax and sending it are 2 different locations.
There must be a piece of paper in the paper path causing it to get "concertinaed ?????
when sending it is NOT going trough the same path.
Here is the manual, there may be some help in the troubleshooting section
http://www.retrevo.com/s/samsung+SF-3100T+manual
good luck
Dec 22, 2007 | Office Equipment & Supplies
230 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
