I there a way i can program the camera to take perfect pics without manually adjusting flash. All i need is to shoot at the object and get a clear pics. With this minolta i have to test several shots while adjusting the flash to appropriate exposures before I get a good pic.
What's perfect to you may not be perfect to someone else, That is why this pro grade camera offers so much in the way of adjustments. One doesn't often GET the perfect picture. More often, one must CREATE the perfect picture..
Set the flash at "0" for the most uniform pictures, and try a better lit environment and work in the 4' to 8' range. Generally, your pictures taken outside in good light, with the sun at your back will be the best. The rest, especially flash, often require some manipulation of the environment..I.E. lighting.
A perfect picture requires a perfect subject, perfect pose, perfect foreground lighting, and perfect background lighting.
So, the answer to you question is; there is no perfect setting, which will constantly produce perfect pictures.
Exposure compensation dial out of sync. When dial is turned eratic values are displayed. ie Dial...
(More)
Exposure compensation dial out of sync. When dial is turned eratic values are displayed. ie Dial Value Displayed value 0 -1 + 1/3 0 +2/3 +2/3 2 0 The flash compensation is also out of sync Mike
We dropped our %D Maxxum and the anit shake mechanism is broken. We sent it to a certified repair...
(More)
We dropped our %D Maxxum and the anit shake mechanism is broken. We sent it to a certified repair facility and they said they cannot get parts to fix it. Do you know someone who can fix it? THanks.
When powering up the camera, a clicking noise occurs for a few seconds then stops. Lens focus OK but...
(More)
When powering up the camera, a clicking noise occurs for a few seconds then stops. Lens focus OK but camera will not take picture.
camera shuts down after every picture and each picture taken is black . I have to turn off and on to...
(More)
camera shuts down after every picture and each picture taken is black . I have to turn off and on to get it to take another picture. still all black
