Question about HP iPAQ RX3100 Pocket PC
Ipaq rx3100 trouble
Hello, I have an Ipaq rx3100 that is giving me trouble, It starts up to the Windows Mobile screen and shows the "tap the screen to set up your pocket pc" but it will not read any touches to the screen. what causes this and do I need to send it in, thanks.
5 Suggested Answers
SOURCE: Screen not responding to touch
i had the same problem and figured out that when i put the screen protector on that it got between the housing and the screen and put just enough preasure on the screen it would not let you do anything.if you put your finger on the screen and apply some preasure and then try to use the stylus it will not allow you to .hope this helps someone.
Posted on Mar 04, 2008
  • 13433 Answers
SOURCE: HOw and where can I get downloadable games for my ipaq?
I had the 3985 few years ago.
here are some websites
http://www.pocketgamer.org/games/
http://www.pocketgear.com/
Basicly you run the setup program on your pc and then it installs it on the pocket pc. I can actually do you a video if you wish, would you like that?
Posted on Jun 09, 2008
SOURCE: Just a good HP iPAQ hx4700 Disassembly, Screen Removal and Repair guide
Thank you! This is a really good page!
Posted on Oct 13, 2008
  • 36 Answers
SOURCE: hp ipaq 5550
To do a full reset, you hold the calendar and itask buttons (buttons 1 and 4) down at the same time, then insert the stylus into the little hole on the bottom and press gently. Hold all for 4 seconds. The screen should begin to fade. Now release all. If successful, you will not be able to start the machine by pressing the on button. You will have to reconnect to ac power to start it.
That is all there is to it.
Posted on Mar 09, 2009
0 characters
1 Points
When unplug my ipaq from the charger it shuts off. what do i do?
I'm guessing it just needs a new battery. Batteries lose their ability to hold a charge over time. You can find batteries on Amazon or Ebay.
Hope this helps.
Ray
Mar 03, 2011 | HP iPAQ RX3100 Pocket PC
Hp 4700 ipaq does not display properly
Take a firmware update to your Hp 4700
Mar 26, 2009 | HP iPAQ HX4700 Pocket PC
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Oct 16, 2008 | PDAs
Ipaq 2495
I figured oout how to do the installation. but now I have another problem. The alignment screen does not come up on the Ipaq 2495 and I have to tap about 2 or 3 lines lower than what is showing on the screen.
thanks, Calvin
May 19, 2008 | HP iPAQ hx2495
IPAQ 6965 problem
Go to \Windows\StartUp and delete the offensive program.
May 13, 2008 | HP iPAQ hw6965 Smartphone
Screen
The nature of these devices is that there is no way to really know why it is doing this, but on the bright side there is a way to tell if it is real (ie hardware) issue or just a glitch.
To test that (and maybe fix the problem) all you need to do is backup your data paying special attention to any data and/or programs stored or installed to the system memory rather than the memory card - and then do a hard reset on the unit.
To do a hard reset on your unit, you need to:
1. Hold down the media and task launcher buttons.
2. Tap the reset button found on the bottom of the device.
3. Continue holding the media and task buttons until the screen begins to fade.
4. Release the buttons.
5. The device should begin to restore itself back to the original factory settings.
At this point you will initialize the system as if it were brand new out of the box, entering your info and calibrating the screen. This will likely solve the problem, but if it does not than at least you know it is a hardware issue at that point.
Nov 15, 2007 | HP iPAQ RX3100 Pocket PC
Hard reset does not wok in my ipaq H3955
The touchscreen may be broken, try hardreset again if it doesn't help contact your dealer or HP for possible repairs.
Sep 14, 2006 | Compaq iPAQ H3955 Pocket PC
Ipaq MAC address?
First turn the wireless on. Then go to Start > Settings > System > Asset Viewer and look for "Wireless LAN" near the bottom of that list. Click on the + which will open the information tree out and show you the MAC address.
Sep 11, 2005 | HP iPAQ RX3100 Pocket PC
Critical component is either missing or cannot start
Have you tried a soft reset or hard reset yet P ? How about a ROM update ? Seem like one of your applications on the Ipaq is having a conflict so try to remove them 1 by 1 and pinpoint the exact culprit Did you have the programs installed on the main Ipaq memory or a SD card if you have one ?
Help with syncing!
Do you have Activesync installed? What is it doing? Do you have the appropriate boxes checked in Activesync to sync files -- if that is what you really want to do?? Can you copy and paste files from the PC to your "Mobile Device" in Windows Explorer on the PC?
Sep 08, 2005 | HP iPAQ RX3100 Pocket PC
HP iPAQ RX3100 Pocket PC Logo
Top HP PDAs Experts
David Payne
David Payne
ka4iup
ka4iup
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
