Question about Maytag MAV3905EWW 13 Cycle Washer
Washer will not spin on the regular cycle but does on the delicate cycle??
When the m/c goes to the spin cycle in the regular cycle setting it will not spin. The timer still moves and you can hear it clicking. When I pull out & down on the knob it will spin. This only works 50% of the time. When it does not spin, I switch it to the spin mode on the delicate cycle, it then drains the water and spins out until it shuts off.
Is the problem with the knob or the timer on the reg stting mode??
  • 639 Answers
Dear friend,
ngfam at you service!
You have an electronic problem and have no choice but to call service!
If the washer is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide -USA
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
My washer recently hasn't drained all of the water during the spin cycle.
how is the spin in the delicate cycle compared to the reg cycle?
Apr 11, 2015 | Washing Machines
My all in one washer dryer by kenmore is direct drive. the spin rinse spin functions work on all three cycles ie. delicate, permanent press and regular. the fill and agitate functions at the beginning of...
can you get it to start by moving the timer one more click past the beginning of the cycle? Sometimes that is all that is wrong. Other than that, it's more than likely the timer has fused some of the points together and you will need a new timer in that case
Aug 24, 2009 | Kenmore Washing Machines
Whirlpool washer spin cycle works off and on
no the slowing down maybe caused by a sticking clutch and as before the lid switch may also be broken if when you depress it the reason i'll give is if you bump it it sometimes starts up replace the lid switch and once done the circiut will close properly then the delicate cyc should work
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
What does "IE" mean when it attempts spin cycle?
is it IE or LE please confirm it. if it is LE code the fixing procedure is given below This usually happens if you're washing on a delicate setting with a moderate load of clothes. Apparently, delicate also means very few items to wash. To clear the LE code - no need to unload the clothes:
1. Press the power button to turn the washer off.
2. Press the power button to turn the washer back on.
3. Cycle the spin cycle selection to 'no spin'.
4. Press start.
The washer should set to one minute, lock the doors, then drain out the excess water.
Once the 'End' cycle comes up, unplug the machine for several minutes.
Plug the washer back in, press the power button, then set the washer to 'normal' with 'low' spin setting.
Note that the only difference between the normal setting and delicate is the wash time and spin cycle speed. If you have a moderate to large load of delicates, use the normal setting on low spin cycle. The clothes really don't care. Also, make sure you're using 'HE' detergent - low suds. Regular degergent in a front load is not recommended.
Jul 19, 2009 | LG WM1814CW Front Load Washer
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Mar 12, 2009 | Amana Washing Machines
Will only work on cycle, will not agitate in the other cycles
Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't move into spin phase on the Regular Cycle setting.
Have you checked the lid switch??? This will prevent it from spinning look on the lid you will see a plunger.. watch where it goes down to you can use a pen to press the sw while the lid is up to see if it is working ...PS: dont forget to set it into the spin cycle first..let me know what happens
Feb 16, 2008 | Whirlpool LSR6232J Top Load Washer
No longer spinning/loud noise
Did all the standing water pump out?? If sou you may have broken a drive coupling
Jan 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag MAV3905EWW 13 Cycle Washer Logo
150 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
