Computers & Internet Logo
Posted on Jul 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant figure out the internet/wireless enabling code for my MSI a4000 laptop
Anonymous
Level 3:
Genius:
  • Master 1,542 Answers
  • Posted on Jul 18, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1542
Questions
5
Helped
287077
Points
4659
Hi
pressing the FN+F11 should hopefully enable the wireless switch if this is what you are asking
1helpful
I am looking for a user's manual for a msi A4000 laptop. I want to find details about the quick launch buttons.
You can get the manual from here:
http://www.msimobile.com/level3_productpage.aspx?id=155
You should see a button on the left side beside the image. The button says driver/manual download. You can also the website to contact MSI if you need their help.
I hope this helps.
Carlo Adrian Canon
Msi A600 CAN'T FIND ANY INTERNET
Fn+F8 is what you need to use.
Fn+F8 toggles the wireless on and off.
Can't get onto the internet wirelessly
Check you have the latest Wireless drivers:
http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1474
There are issues with this netbooks poor drivers..
Install and try again (ensure that you have enabled the wireless)
8helpful
Cant get my wireless connection to work not sure
To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
If this does not work, check if the driver is installed in your computer by going to the device manager. check under network adapters. If the driver is installed, uninstall the current driver and restart the computer.
If the issue still persists, you may download the driver update at the msi website: http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1474. Just make sure the driver you're downloading is compatible with yoru operating system
6helpful
Msi notebook can't get it set up to the wireless router to brouse the internet. Cant find button on it to flick to wireless router
I am having the same problem and am unable to connect my sons msi wind u100 to a wireless router
hope someone can help us
Why dose my laptop show that the wireless is enabled but it will not pick up a signal. when i go to fix problem it says that its not enabled.
try system restore and chose the date when you we're able to connect to the internet using wi-fi or reinstall your wireless device driver and check for updates.
1helpful
Wireless stopped working on my msi laptop
No Wireless Connection Found in Range
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
Wireless printing
access your router with following link
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
then all network members get ip from this router.
configure your router as wep.not wap
dhcp is on.
and dont give advanced security
Grand Canyon Tech
Grand Canyon Tech
