Question about Kenmore 22422 Top Load Washer
Kemore washer MD#24902200
Washer will not spin with load in unless you give the clothes a shove and then it catches and spins okay. However it will spin when tub is empty. The washer is 6 yrs old and other than the spin cycle it works great.
  • btcasciaro Sep 07, 2008
    I have the same problem. I took the outer case off, and there is oil puddled on the floor, the outer case of the gearbox has oil on it, and there is a spray pattern on the outer case. I plan on replacing the coupler, gearcase and clutch. What do you think about doing that?
  • 5,911 Answers
This problem can be attributed to any one of the following items:
1. Worn Clutch/Brake assembly.
2. Gearcase (transmission) starting to go bad.
3. Basket Drive assembly worn or loose.
The more common problem is a worn clutch assembly, but you can't always be sure. If the gearcase fails, a common tell tale sign is a light colored oil leaking from it. You will notice puddles under the washer and/or spray pattern marks along the interior walls of the casing. Sometimes these two problems are interrelated as oil leaking from the gearcase can cause the clutch or brake to slip.
The following link explains how to replace the gearcase assembly:
http://www.fixya.com/support/r699497-replacing_gearcase
I'm not saying you have a bad gearcase at this point, but include this link because it gives information on how to remove the clutch/brake assembly. If you go to searspartdirect.com and type in your model number as "110.24902200" there are some very helpful drawings under the "Brake/Clutch/Gearcase/Motor/Pump" heading. The gearcase is listed as item 9, the entire clutch/brake assembly is listed as item 5. The Basket Drive is listed as item 1.
This problem can often be hard to diagnose as any one of these components mentioned can cause a slow spin problem. I would recommend you remove the outer casing and do a visual inspection of the gearcase and clutch assembly (under the wash tub), first. Let me know what you find. I hope this gives you some guidance.
PS A basket drive failure will require you to remove the wash tub to replace. Since the basket drive penetrates through the bottom of the wash tub, it is recommended that you also replace the wash tub seal. Let me know what your preliminary findings are before we touch on this topic.
Posted on Aug 28, 2008
Why does my kemore elite always get out of balance when spinning worst with a light load
When Loading, Always Distribute Clothes Evenly (weight wise) With A Light Load Usually Clothes Will Become On One Side Before End Of Wash Cycle--If You Look Before Spin Cycle And This Had Happened, Redistribute and restart from present position (cycle wise)
Feb 28, 2015 | Kenmore 24032\24036 Top Load Washer
Won't spin fast when fully loaded
You may have a weak clutch. If you can stop the washer during spin by hand, that's what it is.
Jan 26, 2014 | Kenmore 24422 Top Load Washer
Model 23832100
Sounds like clutch not catching,this may need to bed in .The fact it works okay with no load and no spin with load sounds like clutch/ but also could be motor torque.Ask repair man to recheck work done.
Jan 14, 2014 | Kenmore 24032\24036 Top Load Washer
I have a 4 year old Kemore HE2 that isn't spinning the water out of the clothes. I encountered this issue about a month ago and found a fix for cleaning out the hidden pump trap. After removing a large...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore washer doesn't spin
the conection b/w the motor and the gear got damage you can get the part online and do it yourself.
you just need to take the pump out and the motor wich bouth connect by clips .
hop it help you
Jan 12, 2010 | Washing Machines
Kenmore 22442 not spinning unless you physically help it along
Sounds like a worn belt problem!
Call service now before it gets worse and cost you a lot more money!
You'll be okay!
Electronic problem. just call service.
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Give me a good rating on this site , FIXYA.COM
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 23, 2008 | Kenmore 22442 Top Load Washer
Whirlpool Ultimate Care II washer will not spin...
I would say you have a burnt out clutch. did you over load it with a quilt or comforter?
Time to consider a new washing machine, unless its under warranty I would recommend replacing the washer vs. fixing it.
Whirlpool doesnt build them like they use to!
Jul 11, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Thin Twin Washer
Sounds like the transmission is gone the thing you call the spinning mechanism is call the adjatator it should move left to right I can tell you right now to replace the dog ears if it is a kenmore washer they go bad all the time they cost about 5 dollars they are under the cap on top of the adjatator you will need to pull it off to do the job good luck Ron
Jun 10, 2008 | Whirlpool LTE6234D Top Load Stacked...
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Kenmore 22422 Top Load Washer Logo
459 people viewed this question
Sal De
fordexpert
Robert Rankin
