Question about Garmin nuvi 200W GPS Receiver
Battery replace How do you replace the batttery in the garmin nuvi 200w?
Flip the unit over so it is resting on th screen with the on switch at the top you will see the reset and S/N tag. Pull this plastic tag off with twezzers or a knife. This will expose 2 torx screws size T-5. After removing the torx screws, right under the S/N plate sticker is a mount hole, locate this then pry apart with screw driver, be careful prying apart as there is a flex cable taped down to your pcb board. Remove the flex cable by opening the latch for it, there are 2 latches one small and one large and the cables are taped to the pcb board. Remove the speaker jack wire with tweezers.Next with a small jewlers screwdriver remove 3 phillips screws size ph00 from pcb board. Lift the pcb board out and disconnect the battery wire underneath. Next remove battery, it is stuck down with double sided tape and takes quite a bit of force to remove. It is a Garmin LI-ion 3.7v, 1.25 AH battery.
Posted on Sep 02, 2008
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: how do i change the battery on a garmin 200w
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Posted on Apr 10, 2009
Tip
Download Nuvi 200W Manual Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W,...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Have you lost your Users Manual or the Quickstart Guide for your Garmin Nuvi 200 or 200W GPS?
Would you like a digital copy of the Owners Manuals for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
____________________________________
Garmin Nuvi Hard Reset Here.
Garmin Nuvi 200W Favorites Backup here
Download Garmin WebUpdater here.
on Apr 17, 2010 | Garmin nuvi 200W GPS Receiver
Tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
My garmin nuvi 200 starts and stops permanently,
defective battery is the most common cause of this, u must send the GPS back to Garmin to have the battery replaced.d
Apr 23, 2010 | Garmin nuvi 200W GPS Receiver
Garmin nuvi gps navigator
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Feb 04, 2010 | Garmin nuvi 200W GPS Receiver
Changing batterry in nuvi 200
The Nuvi series does not have a User replaceable battery with a few exceptions and your device is shipped with a User non-replaceable battery.
The exceptions include the nuvi 5xx, 8xx and the nuvi 900T. These devices have a replaceable lithium-ion battery.
http://www.garmin.com/garmin/cms/site/us/support/searchsupport?search_key=nuvi%20200
Contact a Service Center to replace the battery.
Good Luck!!!!!!!!!!!!!!
Sep 28, 2009 | Garmin nuvi 200W GPS Receiver
My nuvi 200 just stays on the screen that says Garmin like it is frozen. Am i supposed to be replacing a battery periodically?
I hope that helps.
___________________
Sep 25, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200w while charging the battery it started to flash and went dead. It will not respond.
I hope that helps.
___________________
Sep 04, 2009 | Garmin nuvi 200W GPS Receiver
Shutting off automatically or switching to battery despite being plugged into cigarette lighter
I hope that helps.
___________________
Aug 09, 2009 | Garmin nuvi 200W GPS Receiver
How do i change the battery on a garmin 200w
Mar 26, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
609 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
