Question about Kenmore Elite 45986 Front Load Washer
Water leaking into washer
Water keeps filling when washer is not in use. Sometimes its a lot of water, and at times there is none.
    President:
  • 1,462 Answers
Is the drain plumbed into a spigot on the sink trap? if so this may be the source of water coming in when appliance not in use.
take the drain hose as high as possible in a swan neck under the sink and see if this cures it.
other possibility is a leaking inlet water valve but would expect fault then not to be intermittant
Posted on Aug 28, 2008
Beko dishwasher doesn always fill with water but makes sounds as if it does. Other times it works great any ideas?
depending on chosen wash cycle washers are not always supposed to 'fill' just use enough for that cycle .
If you mean sometimes no water at all and sometimes water with same settings check hoses and valves .
make sure valves are fully open hoses securely attached and hoses from valves to washer are not pinched twisted or damaged.
Hopefully the water not getting in the washer isn't leaking all over your floor below the washer.
Jul 18, 2016 | Beko Dishwashers
I HAVE A GE WASHER THAT FILLS WITH WATER AND OVERFLOWS. DOESN'T MATTER WHAT SIZE LOAD, IT CONTINUES TO FILL WITH WATER AND OVERFLOWS. IT STOPS WHEN I HIT THE STOP/PAUSE BUTTON.
There is a pressure sensor that needs to be looked into. USUALLY, there is a chamber, on the outside of the washer tub, and out of the top of it is a small plastic hose. This hose runs up to an electrical switch.
Too much soap, over time, can plug up this system, so the machine has no idea how much water is going in...and keeps filling..... Sometimes the hose comes loose, but this makes a fairly immediate water leak, so I suspect something is plugged.
Doc
Jul 06, 2011 | General Electric WHDRE526EWW Top Load...
Hotpoint washing machine model vbxr1090b2ww leaking from bottom of unit
Here are some solutions.
Hope this helps you...Jim...Please leave a comment...Thanks!
LEAKS ALL THE TIME Is your GE washer leaking all the time, even when not in use? If so the problem is the fill hoses or the valve. Look behind the washer to see if water is coming from the hoses. If not, take the cover off to the control panel. Once off, you should see if the water valve and if there is leakage - it needs replacing (if it is leaking). This is the most popular water valve for GE top-loading washers made after 1995 and the part number is WH13X86 Order Here. show?id=6bjnatppuce&bids=92089.1&type=10. Note that some models have a water valve with more than two coils. In this case, you will need to order the valve by model number at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 Buy Fill Hoses Here. show?id=6bjnatppuce&bids=92089.1&type=10
LEAKS DURING FILL CYCLE Is your GE washer leaking during the fill cycle? If so the problem may be in the valve. Follow instructions above, only this time start the fill cycle before looking at the valve.
If your washer overflows with water during fill cycle your problem is the water level control or the water valve. If you must cut the water off from the house plumbing to stop the water then there is no need for testing, just replace the water valve. First, you need to turn on the washer. The washer should start to fill with water, now cut the washer off and on repeatedly (note to yourself whether the water turned off every time). If it does cut off every time you cut the washer off, then it's most likely in the water level control. If it keeps running after you cut the washer off then, the water valve is bad and needs replacing. (Note that the valve can stick intermittently so it still may be bad if it passed the test) Water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
If the water valve doesn't stick in the first test then you need to check the water level control. First, remove the front of washer (insert butter knife between the top and the front pushing on the clips) then look on the side of the tub and you should see a tube attached to a box. Remove the tube (make sure all the water is out of the tub) look in the tube to see if is stopped up. Often it will stop up near the end. If it is, you can clean it out with a toothpick. Once it's clean, reinstall it and your washer is fixed. If the tube is not stopped up reinstall the tube. Now set the water level control on the lowest setting and start filling the washer with water. If the water stops when the tub is approximately half full (this varies with every model) turn it up to the next level (you may have to reset it). Repeat until the tub is full. If at any the water level gets above the last row of holes in the tub, unplug the washer. If the water stops running when you unplug the washer, replace the water level control. If the water doesn't stop, turn the water off at the wall then replace water valve. Water level contorls and water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 . LEAKS DURING WASH Is your GE washer leaking during wash? If so the problem is the tub seal (seals around the transmission where it goes through the tub), drain hoses (including the tub to pump hose) or the pump. First take the front off the washer (insert butter knife between the top and the front, pushing on the clips) then start the fill cycle. Now start watching until you see a leak. If the leak is coming from the tub seal, the transmission needs to be replaced (note that changing the transmission is expensive and takes special tools, so you may consider replacing the washer). If the leak is coming from the drain hose or the pump you need to replace it. If you don't see it leak at all, your soap may be the problem. To check this fill the washer with water and the amount of soap you normally would use. Then start the washer and watch the tube coming from the left back of the tub (the overflow pipe). If soapsuds come out of the overflow pipe then try cutting down on your soap or switch to another brand. This may fix your problem. These parts can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
LEAKS DURING PUMP OUT Is your GE washer leaking during pump out? If so the first thing you should look at is the drainpipe (to your house plumbing). Fill the washer with water, and then turn it to spin and start it. Now while it's pumping, look at your drainpipe if water backs out (it may not back unless you have soap in the tub), then the problem is in your plumbing. If it doesn't, follow the same steps as above in "leaks during wash." Only this time watch for leaks during pump out as well.
Feb 13, 2011 | Hotpoint VBXR1090B Top Load Washer
Leaking lots of water during rinse cycle first from bottom someplace near center and then from dispenser compartment
Inspect the internal of the unit for actual holes on the tray which may cause the water to leak out. If there are none, check for any floating devices which serve as fill sensor that my need refitting or may be loose. If your unit has a pump for the water, observe it while rinsing without the panel on to check if it is working.
Nov 02, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet Sport HT - Left Front occ. leaks a lot of water
hello. i dont have to tell you that these intermittent problems are often the most difficult to isolate ...........sooooooooooooo lets look at all of the possible causes for your machine leaking
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaks water when filling up.
If the washer is leaking only during the fill and not all the time, the problem is most likely caused by a faulty air gap device, a leaking water inlet valve, or the tube. The air gap is a small device that keeps the washwater from being siphoned into the household water supply. It is usually located mid-way or at the end of the black hose that comes from the water inlet valve. Usually it is made of transluscent plastic. Look for leaks or cracks.
The tube is a rubber tube that runs between either the water inlet valve and either the air gap or the inlet spout. Check for leaks.
The water inlet spout - most washers have a plastic spout near the top of the main clothes tub that directs the flow of water into the tub. If the spout cracks or breaks free from it's mounting, it can cause leaks.
These are the things to look for if the washer is only leaking during fill. Hope this helps and best wishes.
Jul 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Water leaking
Check the fill hoses to check for tightnes, also check the other: Washer in the fill hose end, facult connection, drain hose in drain, drain pluged. If none of these, call a appliance repairman for help if cannot solve the other yourself. Hope this might help.
Jun 02, 2009 | Whirlpool LSR9434PQ Top Load Washer
Maytag atlantas top loader water keeps dripping from top of drum
Your water inlet valve is probably leaking by. If the water pressure is too, or if there is sediment build inside the valve, sometimes the solenoids will not close properly. Try cleaning the valve to see if this helps. If not, I would recommend replacing it. Depending on which valve you have, repairclinic.com has two listed for this model washer for $20 to $30. Let me know if this helps, or if you need further assistance.
Apr 23, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Washer tub slowly fills with water
Is your problem a SLOW FILL problem, or a problem with WATER DRIPPING FROM THE RUBBER DOOR SEAL - or BOTH? If you have a slow fill problem, this is generally caused by a bad fill valve, which can be attributed to hard water deposits or well water mineral deposits. Sometimes the fill valve can be removed, cleaned and reinstalled, but most of the time a new fill valve is required. If you are experiencing water leaking from the rubber door seal (bellow), it may be time to replace it. Sometimes the seal can develop a wrinkle or crease where it meets the glass, which can cause leaks. Water dripping from the door when you open after washing a load is normal. Water dripping during a load is NOT. The bellow may also have started to rip or tear inside the door which may not be noticeable until you pull the folds of the bellow back and look underneath it. I hope this helps.
Jan 17, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
63 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
